Question about Toshiba Estudio 200L Copier
How do I print via USB on a Toshiba Estudio 200L copier?
We just got a used Toshiba Estudio 200L copier and I am trying to set it up as a printer via USB. I got it to see it as a printer but it won't print a test page. Any help?
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 115 Answers
You might need to have an enabler, which will fix to your copier.
Posted on Jul 06, 2014
disastertech
  • 62 Answers
SOURCE: toshiba estudio 35
What is the copy count on the machine?
Toshiba copiers have service intervals to replace the drum, cleanerblade, corona wires and developer material.
That could resolve your printing problem.
Posted on May 11, 2008
  • 643 Answers
SOURCE: TOSHIBA eStudio 167, connected as
Try double check the paper size settings on the driver.
Posted on Nov 09, 2010
SOURCE: COPIERS - E-STUDIO 650 Copier: We have a Toshiba estudio 550 copier and are copyi...
Copier is copying pages with dark areas down at the bottom.
Posted on Dec 30, 2010
tonesmaker
  • 60 Answers
SOURCE: I need free Information for my prob for toshiba
Your HDD is having issues. First try to rebuild the databases by holding 0 and 8 while turning on the copier, when the machine comes ready key in 684 then reboot the machine. If this doesn't work you can try formatting the HDD (make sure you backup templates and address book if you use them.) To format HDD hold 0 and 8 while turning on the copier, when the machine comes ready key in 690 and hit start. It will then display "2 2", hit start again. Wait for it to say please reboot the machine, turn it off and back on. Hopefully this will work but if not, your HDD will need replacing.
Posted on Jun 16, 2011
  • 3278 Answers
SOURCE: Im tyring to configure an
Hello.
It turns out 4030 is an error code meaning "No print enabler/invalid" with the following corrective action: "Check if the print enabler is connected properly and it is inserted securely. Or check if the trial period is expired."
It's referring to a device (part GM1070) or a "dongle" that is needed to plug into your copier to be able to print directly off the network. I've seen new ones priced online around $500 (USD) or less for used devices.
If your printer is new or still under warranty, be certain that your supplier provides the print enabler / dongle.
Hope this helps.
Posted on Aug 26, 2011
Copies not dark on copy machine
check your print quality settings, your settings may be in draft mode. if correct, I.e. document or picture, check and replace your toner, printer cartridge
Dec 18, 2012 | Toshiba Estudio 200L Copier
How can print with toshiba 230? from pc!!
it very easy. connect the printer to the pc with a usb cable, ensure that u have the driver of the printer that will be install on the pc. put the printing paper to the print and send print from your pc.
Feb 06, 2011 | Toshiba Estudio 200L Copier
When I print a word file it prints but it can not print the email.What should be the problem?
If you are using Windows 7, you may need to download the registry for Toshiba products ( including printers) at this site:
pahttp://www.csd.toshiba.com/cgi-bin/tais/support/jsp/outFrm.jsp?ofId=AskIris&searchString=printer&x=10&y=7tch
otherwise start at toshiba.com and add your model number in the search box.
Aug 20, 2010 | Toshiba Estudio 200L Copier
How to clear toner message on estudio 200 toshiba copier
Did u mean toner low message?
If the message still occur after u replaced new toner, then try to pour out some powders from the developer unit.
Jun 24, 2010 | Toshiba Estudio 200L Copier
Need driver for used eStudio 200L Printer
please find in attached your driver
http://www.printcountry.com/drivers/TOSHIBA_DRIVERS.asp
remmenber to vote for me it counts
Mar 18, 2010 | Toshiba (GM1030) for E-Studio 200L Print...
Toshiba e-studio 200L. Wireless or LAN connection to MAC 10.5 via airport extreme is unpredictable and usually not available. I'm close enough to connect via a USB. Can I access the copier's hard drive...
you have a problem with the reception thats for sure ,anything from a mobile phone mast to a neighbour using a cb or ham radio could cause this,evan a ham radio user with direction beam aerial at some distance can do this ,use the usb cable evan if you need to buy a longer one as this will cure the problem and once the usb is connected it should overide the wireless connection automaticlly. Once the usb cable is connected then the computer will say found new hardware ,put the disk in and let the wizzard finish off making the connection for you.
Dec 23, 2009 | Toshiba Estudio 200L Copier
Can't email from Toshiba estudio 200L copier/printer
Did u check back the POP3 and SMTP configuration, did it match your new office?
Dec 05, 2008 | Toshiba (GM1030) for E-Studio 200L Print...
Toshiba studio 281C problems
You should be able to print on both, but I wouldn't advise it at all. The envelopes are going to jam a LOT and you WILL eventualy get a label stuck inside the machine. Possible....yes. But I don't recommend it. :)
C
Jun 02, 2008 | Toshiba Estudio 200L Copier
Printing Problems to my new Copier
TURN ON APPLE TALK IN NETWORK SETTINGS OF PRINTER THEN ADD PRINTER ON YOU COMPUTER.IT SHOULD FIND IT ON THE NETWORK AND PESTO YOU CAN PRINT
Jun 26, 2007 | Toshiba Estudio 200L Copier
94 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
