Question about Bemis Home
How do i remove gala metropol toilet seat - Bemis Home
3 Suggested Answers
kachbibi1
  • 979 Answers
SOURCE: I'm looking for round buffers that fit below the toilet seat to stop the seat resting on the toilet bowl. The brand is Gala.
Lowes or HD should have that or a specialty shop. Worst case, the mfr. would have that. You can take the plastic caps that cover the bolts that hold down the bowl in place on the floor and secure them to the seat. All you want is it to support the seat. There won't be any sideways pressure on it. It would just slide on the bowl if it did. If the cap is too tall for the seat, then you can grind it down some to level the seat.
Posted on Feb 23, 2013
kachbibi1
  • 979 Answers
SOURCE: looking for buffers for underneath gala toilet seat
Suggestion offered.
How to tighten a vitro nupva toilet seat.
Christina, how to tighten or install hidden fasteners on your toilet seat. check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Remove Vitra Shift toilet seat
Soft Close and Quick Release Toilet Seats Installation
How to fix loose toilet seat
http://vitraglobal.com/
Jun 27, 2016 | VitrA Home
How do I remove toilet seat?Appears to be 2 bolts with top access only.
rak soft close toilet seat - YouTube
? 0:31
https://www.youtube.com/watch?v=RLssM9BYJjg
Oct 9, 2013 - Uploaded by Paul Hooker
rak soft close toilet seat. ... How to remove and change a Villeroy & Boch toilet seat with top fixings ...
Rak Series 600 Back To Wall Toilet - YouTube
Nov 29, 2015 | Home
How do I remove expansive cap holding screw so I can replace broken toilet seat?
Porcher 70018 Bathroom Toilet Seat Round Front ... - Fixya
www.fixya.com/support/...porcher_70018_bathroom_toilet_seat.../popul...
Popular Porcher 70018 Bathroom Toilet Seat Round Front White questions, problems & fixes. Find expert solutions to common issues, DIY guides, repair tips ...
Aug 25, 2015 | Porcher 70018 Bathroom Toilet Seat Round...
How to remove a parisi nahm soft close toilet seat
there is 1 of two ways.
easy way is have a look where the seat mounts to the toilet and see if there is a cover that you can lift up and find a screw under it. there might be 2 pins on each side of the toilet seat hinge that you depress for you to remove the seat from the hinges to access the screws.
failing the above method the toilet has to be removed to access the screws / wingnuts from under neath. send closer picture of hinge on seat if you like.
Jul 12, 2014 | Toto Aquia II Dual Flush Toilet
Gala toilet seat
Assume its an old Gala Marina model which is screwed into the cistern.
Fieaga in Drogheda Ireland can supply. Delivery about four weeks. I have just got one. They have a website with contact info. Price was Euro 120. Too expensive but no choice
May 31, 2013 | Home
Feb 22, 2013 | Home
Toilet seat cover became loose on one side
I have a Toto Dorian 1.6 Gpf where the right side of the cover separated from the seat frame. I fixed it by removing the seat from the toilet base and driving the stainless steel shaft back into the cover hibge holes.
To remove the toilet seat, use a large phillips head screw drive and unscrew the two long screws that hole the seat to the base.
Then you will see the two steel rods about 1/4 inch in diameter that have worked there way out of the seat hinge. Use a hammer and a screw driver to drive these two hinge pins back out into the toilet seat cover hinge holes.
Replace the toilet seat and screw in the two seat screws being careful to not over tighten them. The seat should now work correctly.
Apr 02, 2010 | Toto Promenade, 1.6 GPF, Elongated...
What is the best way to remove stuck toilet anchors
try rotating the entire toilet counter clockwise so the bolts are in the insert slot of the toilet flange and rotate the nut and the bolt head should line up and pop free of flange.
Oct 30, 2009 | Kohler K-3384-2 San Raphael Elongated...
Home Logo
119 people viewed this question
Top Bemis Home Experts
john h
ray gallant
jdtech
Are you a Bemis Home Expert? Answer questions, earn points and help others
