Question about Honda 25cc 4-cycle Mini Tiller
The tiller starts and runs well for about 10 to 15 minutes but then will bog down and stop running . It will restart and run for about 30 seconds and then stop again. Any ideas about what is causing this, the tiller is only 18 month old and should not be giving this kind of trouble
    Scholar:
  • 61 Answers
It sounds like a carburetor fuel issue. Which you could try attempting to adjust the carburetor (or have someone else do such) to see if that cures the problem.
Posted on May 17, 2014
3 Suggested Answers
  • 10865 Answers
SOURCE: Honda Tiller revs and works for 30 seconds and then shuts down.
Hello. you have some gunk in the carburator. Get a can of starter fluid or carburator cleaner aerosol and a helper. Remove the air filter and start it up. Spray a little starter fluid into the air cleaner to keep it running for three or four minutes and the problem should clear. If it does not clear the carburator will have to be disassembled, cleaned and rebuilt. j.
Posted on Jun 16, 2010
  • 6468 Answers
SOURCE: the tillers start working and right away stops, the tiller still runs just the tillers don't
check the shear pins on the tine shafts
Posted on Aug 07, 2012
Craftsman model 917.299011 carburator problems
you might want to check for spark when it stops running
Apr 04, 2012 | Craftsman Garden
My 5 horsepower pony tiller just shuts off with no warning after about 20-30 minutes of tilling and will not restart again until it cools down to the touch I have changed the spark plug, drained and...
I also was having issues with an old 5 horse Troy Built tiller that would fire when gas was in the tank then stop running. If it's a Briggs and Stratton engine like the one I have it's probably you can remove the muffler to gain access to the side of the carb. Remove the four screws and the cover off the fuel pump diphram and check to make sure that the rubber isn't cracked or degraded. I replaced the one I had and it now runs like a champ.
Mar 23, 2011 | Troy Bilt Pony 6.5 Hp Rear Tine Tiller
Tines turning, mantis 2 cycle tiller
sounds like a piston seizure. are you using correct oil and ratio. carb could be going lean and causing the cylinder to over heat, adjust high speed mixing screw and hope no damage has resulted.
Jun 30, 2010 | Mantis 2-Cycle Tiller
Jun 16, 2010 | Honda 25cc 4-cycle Mini Tiller
Engine bogs down when speed is increased.
Ok I have r Royobi Tiller (30CC Gas) And last year it ran fine after rebuilding the Carb. This year it was "hard starts" Idles fine, (Tiny whisps of blue smoke in exhaust with correct ratio) Even seems to run better with the choke "on" but still...at idle only. as soon as I touch the throttle...its bogs down in tune with how much gas I give it. Little throttle? Little bog down, Little more throttle? Almost stalls, a normal throttle rev? it stalls dead! Then starts right back up again in 1 pull and idles fine again!? WTF? So after cleaning a clean carb again, (twice) and seeing no change I thought I'd go look at the original diaphragm and compare it with the rebuild kit diaphragm (which is the one in the carb.) And guess what? The replacement has a larger rivet by a factor of "2". So basically it was flooding the carb, I bent the needle tang down, better but no cigar. But I could rev it half way now. A second disassemble to bend it yet a bit further and Vrooom vroom vrooom ****! So check your needle valve even though you think its 100%. (Especially if you rebuilt the carb with a kit!)
Mar 27, 2010 | Honda 25cc 4-cycle Mini Tiller
Kenmore 800 dryer shuts down after running down to 40 minutes on the timer. When I restart it at that point it runs for about 30 seconds and shuts down. If I turn the timer back to 90 minutes it runs down...
Sounds like you may have a bad motor. If the motor is overheating it will shut down on its overload.
If its a shorted contact in the timer you could mark the spot where it stops and restart it again. It should stop exactly at that point.
Jan 22, 2010 | Kenmore Dryers
Get your motor running
Check to see if the gas cap is clogged. If the gas cap is clogged, it will keep the carburetor from getting the proper gas flow. Try this: The next time it begins to die, loosen the gas cap. It should begin to run again. If it begins to run again, then you know it's the gas cap.
Jim
Jun 06, 2009 | Mtd Products Yard Machines 158CC Tiller
Honda 25cc 4-cycle Mini Tiller Logo
389 people viewed this question
Top Honda Garden Experts
John Trevino
JOHN LAPIER
Are you a Honda Garden Expert? Answer questions, earn points and help others
