Question about Canon Office Equipment & Supplies
Sir i have a canon pixma mx357 printer. it gives a code of 6000 (printer error has occurred turn off power then back on again. if the problem persists see the manual) shown in the window. will u please give me the suggestion to repair the printer. my e mail id is s_kalivarapu@yahoo.com
SOURCE: SERVICE ERROR 6000
Use this:
1. Turn off printer
2. Hold down Resume button and press Power button
3. Keep holding down Power button and let Resume button go
4. Press Resume button 2 times then let BOTH buttons go.
5. Green lights will flash and stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not, press the Power button once more
8. Your printer should respond as normal.
Posted on May 20, 2008
SOURCE: Cannon PIXMA MP520 Problem: Error code
I had this problem with the ink carriage jammed at the left hand side of the printer. I operated the lever in a hole on the top left hand side and eased the carriage along to the middle and pushed it back onto it's runners. All OK now.
Posted on Jun 29, 2008
SOURCE: CANON PIXMA IP1200 resetting
My converted iP1200 is currently blinking green, yellow, green, yellow on the power lights after start up and print request. The pop-up prompt suggests turning off the printer and turning it back on. Error 5100 is always seen.
Please Help Me...
rakibfuture
Posted on Oct 28, 2008
  • 66 Answers
SOURCE: Error E000001-0000
e001 is a fuser error. it might be able to be reset, but should be looked by a tech.
SERVICE MODE
*28*-press the additional func button, 2&8 at the same time, and the additional func button again.
when you have done it correctly, the screen will change and it will say service mode across the top.
Then select:
copier
func
clear
err
press the done or ok button on the lower right side of the screen.
turn the machine off at the black switch on the right side, wait 10secs, turn back on. should work.
****DONT MESS WITH ANYTHING ELSE IN SERVICE MODE YOU CAN REALLY SCREW UP THE MACHINE.!!!!!!!!!!!!!!!******************
Posted on Apr 23, 2009
pinic
SOURCE: I have a Canon, Pixma
Put the colors out of the printer and do it on and off a few times and put the colors back in and a few times on and off again, that was working on my 6a80 problem.
Greetings Pieter.
Posted on Sep 03, 2009
My printer canon mx328 error 6000
This information is directly from the Canon website, basically it suggests something is stuck inside. Other articles I found mentioned one person found a paperclip stopping the works.
---- quoting Canon ----
6000/P03 - Orange and green light blinking 3 times Description:
A service error has occurred.
Resolution:
  1. Turn off the printer.
  2. Disconnect the power cable.
  3. Open the printer cover.
  4. Check for any orange protective tape or white polystyrene and remove if necessary.
  5. Check that there are no foreign objects in the printer (such as a paper clip) and remove if necessary.
  6. Close the cover.
  7. Reconnect and turn on.
If the above solution has not resolved your error, please contact your nearest Canon authorised service facility using the link at the top of the page.
----- end quote ---
Best wishes -
http://www.canon.co.uk/support/consumer_products/product_ranges/printers/maxify/error_codes/#6000
PIXMA Printer Error Codes and Error Messages
Jul 05, 2015 | Canon Office Equipment & Supplies
Canon mx357 code error 6000 soultions
sir i have a canon pixma mx357 printer. it gives a code of 6000 (printer error has occurred turn off power then back on again. if the problem persists see the manual) shown in the window. will u please give me the suggestion to repair the printer. my e mail id is s_kalivarapu@yahoo.com
Jul 04, 2012 | Canon Office Equipment & Supplies
Canon mx350 code error 6000
  • 6000 is displayed:
If any object is placed in front of the machine, remove it.
Open the Paper Output Tray gently, then turn the power off and back on.
  • In other cases:
Turn off the machine, and unplug the power cord of the machine from the power supply.
Plug the machine back in and turn the machine back on.
If the problem is not resolved, contact the service center.
Jul 04, 2012 | Canon PIXMA MX350 Wireless All-in-One...
My Canon MP980 is showing Printer Error code 6000. Have turn off machine and turned on again - no change - still showing.
error [6000] or light blinking 3 times is mean there is an error occurred in the LF encoder signal.
May 20, 2010 | Canon PIXMA MP150 All-In-One InkJet...
I have a canon mini260 and its giving me an error 6000
Other than doing a reset, unfortunately your Canon may require repair. By resetting the power, you clear the print buffer and reset certain sensors which may be producing the error.
1) Turn off with power button
2) Unplug data cable
3) Unplug power cord for 10 minutes
Plug power cord back in, reattach the printer data cable and press the power button.
I hope this helps!
Dec 20, 2009 | Canon PIXMA® mini260 InkJet Photo Printer
Ip1980
Error 6000 is not completely defined but you can reset completely the printer by the following steps:----------
  • Unplug the cable to cut off electricity.
  • Press the Power Button and while doing it enter Power Cable into socket to turn on.
  • Then give the resume command 2 times. For the command you need to press the glowing orange button and then the green indicator light.
  • Then disengage all pressed buttons.
  • The printer will get warmed up and will be resetted.
Thank you Sir, Have a nice day.
Sep 23, 2009 | Canon PIXMA MP150 All-In-One InkJet...
Code error 6000 in canon pixma mp 500
Hi there it is ink error.
You can try to reset the cartages this may do it Please call back let us know if it worked for you, PLEASE.
  1. Start with printer off
  2. Press and hold resume Button (triangle in the circle) and click “Power” button. Green led should be on
  3. While holding the Power button, release the Resume Button.
  4. Without releasing the Power Button, click “Resume” button for two times and release Both Buttons.
  5. Click “Resume” for four times then soon click “Power” button, to confirm the selected action (reset counter absorber).
  6. Turn off the printer and turn on again
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Sep 07, 2008 | Canon Pixma MP500 All-In-One InkJet...
51 people viewed this question
old marine
old marine
