I have a 15" Digitrex TV and there is sound but no picture, can you help? My name is Dee and I can be contacted on 07941 378927.
I just bought a supersonice tv had it on for 2 days and now I have a 1/2 picture there is a wide lilne at top and a wide line at bottom. We have tried everything in the menu to fix to no avail please...
As the TV is new one, it must have warranty. Contact the dealer. Sounds like back-light fault. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy. Pull up older posts. Surf the site with patience. Do a search by type in the brand name of your device at its search box and press "Enter".
Jun 24, 2014 | Supersonic 15 in. LCD TV
HI, MY NAME IS S. A. ANSARI, I HAVE A SHARP AQUOS LC-32A66M LCD TV. ONE DAY SUDDENLY GOES INTO STAND BY MODE. NOW WHENEVER WE TRIED TO TURNED IT ON, IT ON FOR 30 SECOND I.E. WE CAN SEE PICTURE, HEAR SOUND...
Hi Ansari
It sounds like a main board problem. The control voltage that goes to back-light inverter board; from the main board, goes down. Contact any service technician. This is not a user repairable fault. Gopakumar Gopalan Google
Feb 27, 2014 | Sharp LC-32A66M 32 inch Multi-System Full...
Connecting my macbook pro to digitrex tv using thunderbolt and hdmi
DisplayPort to HDMI Sound is actually set up by using the MIDI setup utility found in :
Applications > Utilities > Audio MIDI Setup.
If you purchased an iWires cable direct from Apple the instructions are in the printed booklet that comes in the packaging. Most people don't read this as it's normally the case that when you plug a cable in to anything it just works (VCR, TiVo, Xbox, video camera etc). In this instance Apple are failing to live up to their catch-phrase as final setup is NOT intuitive; "it just DOESN'T work".
The booklet instructions basically say do the following,
Video
System Preferences > Displays. There are 3 tabs in the window; Displays, Arrangement and Color. Be sure you are on the Displays tab. Bottom left of the window tick "Show displays in menu bar" and then bottom right click "Detect Displays".
Now click on the tab named Arrangement. Bottom left of the window tick "Mirror Displays".
You should now only see 2 tabs, Display and Color. Be sure you are on the Displays tab. Select the desired resolution for your TV (probably 1080i). leave all other settings at their default values.
Sound
System Preferences > Sound. There are 3 tabs in the window; Sound Effects, Output and Input. Be sure you are on the Sound Effects tab. Middle of the window select your TV where it says "Play sound effects through:".
Select the middle tab named Output.
Select your TV from the drop-down list next to HDMI, below where it says "Select a device for sound output".
Using either Finder or Launchpad go to Applications > Utilities > Audio MIDI Setup.
On the left-hand side of the window you should now see HDMI. In the middle of the window, on the Output tab, where it says "Source:" select your TV from the drop-down list.
This last action below is NOT described in the iWires notes but was required in my case, it may also be required in yours. If you CANNOT see a speaker icon next to HDMI in the list on the left, do the following:
Bottom left of the window select the wheel icon with the down-pointing triangle. Make sure that sound output is selected and that you can now see a speaker icon next to HDMI in the list of devices.
If you still cannot hear sound, log out of your account and then log back in.
You may have to do some or all of the above to get sound out of your TV from your computer using the DisplayPort to HDMI cable. On my Aug 2011 MacbookPro I had to do ALL of the above. If you take your laptop to a different TV you will have to do it all again so be warned.
Hope this helps.
Feb 24, 2014 | Apple Computers & Internet
Technika universal remote need code for a digitrex tv
038,018,011,025,082,074 are the codes to check. If you wish to get more details, check this site. Pull up older posts there. Setup code list and setup proceedings to many popular brand remote controls are given. Check the site with patience. You'll surely get a solution to your problem. Search the site by 'Timeslide' option. It will make search easy. Or, type in the brand name to your device into its search box, and press "Enter."
Mar 23, 2013 | Televison & Video
Whats the code or digitrex tv
you will better read the owner manual, and get the contact with the factory or company supplier from your digitrex tv
howver try www.remotecodelist.com
God bless you
Sep 17, 2012 | Cameras
Code to enable sky remote with Digitrex TV
I have a digitrex tv with remote indicating on reverse serial numbers( CTF2685. CTF3271. CTF4071) which I couldn't turn the volume up or down change the channel etc but this worked for me 1.press the tv button
2. Press select and the red button at the same time for 2 seconds the light will blink twice.
3. enter code 2193 and the light will blink twice. Problem was then solved sky remote fully functional hope this helps people out sure helped me thanks guys
Mar 08, 2010 | Televison & Video
Grinding Noise
sounds like the light engine there are alot of problems with the light engines and quite a few have had a grinding noise. The only other possibility would be the color wheel. But I would lean heavier toward the light engine being the fault.
Apr 09, 2008 | Televison & Video
Digitrex DSC3000 digital camera
You do not need any extra software to transfer images to a Windows PC
If you have loaded some remove it
It is a hinderance to Windows
Windows can do it all by its self
Nov 06, 2007 | Digitrex DSC-2102 Digital Camera
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
