Question about HP LaserJet Pro 200 color
Black streak on left side of paper coming out of printer
Soulvisitor
  • 1113 Answers
SOURCE: Black Streaks on Edges of Paper
This can be one of two
Print cartridge (you can do it, replace toner cartridge)
or Fuser (needs to go to doctors)
stop a print half way threw to confirm that it is print cartridge, good chance it is.
Links to my previous post on this problem below
HERE and HERE
Posted on Nov 18, 2007
Soulvisitor
  • 1113 Answers
SOURCE: HP 2600n prints black streaks on a page
Could be a few things but black cartridge is most common cause, they are not "cleanable" one just replaces them, if you carts are non gen HP then that will surely be your problem, slight chance could be transfer belt assy or fuser. they are also just a case of replacing, go for cart, replace it and see.
Posted on Dec 05, 2007
kc2mnm
  • 11 Answers
SOURCE: I have black streaks on my copy
Before you installed the cartridge was it in the box standing on end, If so remove the cartridge from the printer and gently shake the cartrige from side to side then reinstall, the toner may be packed mostly on the one side.
Posted on Feb 17, 2009
SOURCE: printer leaves black spots on paper
The black spots mean you either need a new imaging drum, transfer kit or fuser. You'll have to print some stuff and try to catch where the black marks are appearing. Try this method (it's called a Half-self test)
Load 2 -3 sheets of letter paper in tray one (manual feed) and remove paper from the rest of the trays.
From the information menu, request a demo page
The MOMENT the tail end of the paper disappears into the printer, open the right door. Open the front doors and release the levers for the imaging drum and the transfer drum. Carefully remove both pieces and examine your paper.
You should find the paper partway on the transfer belt but not in the fuser. If you see black marks here, start with the imaging drum. Open the shutter that covers the sea green shiny roller and look for marks on the drum (you'll see build up on the edges, that's normal, you should not see any scratches, pockmarks or toner on the center of the drum). If it looks clear, take a look at the transfer drum for marks or cuts on it's surface. (note: the transfer drum can be cleaned off with a dry lint free cloth, do not touch the shiny sea green roller of the image drum)
If everything looks good there, then likely the black marks are coming from the fuser. Let the printer sit, turned off for about half an hour to allow the fuser to cool. You can then remove the fuser and look at the rollers to see if there is any build up or damage there.
If you are not seeing any obvious issues with any of these parts, then start with the imaging drum. If you know that any of these parts have never been changed, then change them as they do have a limit to how many pages and how much time they can be used for.
SOURCE: STREAK LEFT ON RIGHTHAND SIDE OF PRINTED PAGE
Fuser sleeve is contaminated and needs replacing - cheaper to replace the printer.
Posted on Apr 17, 2009
Black streaks
Black streaks down left side of paper. Solution: Replace drum.
Oct 27, 2013 | Xerox Office Equipment & Supplies
Black ink streak on left side of paper on hp 1012, just put in new toner
Run a half test.
Put paper in the manual feed tray(tray 1).
Send a print job to printer. When the paper gets 3/4 of the way into the printer, open the cover. Pull out the toner cartridge, look down at the sheet inside the printer. Does it have the streak on the left side? If yes...your toner cartridge is bad. If no...replace the fuser.
Oct 21, 2010 | HP LaserJet 1012 Printer
I'm getting black streaks down the left side of the paper. There is plenty of toner left in the cartridge. We've vacuumed out the printer, cleaned the drum - nothing helps.
black streaks the toner cartridge is leaking from the left side which is easy to check pull the tone and look at the gears on the left side to see if toner is present. if these gears have toner on them the cartridge is leaking replace it. check the fuser for wear marks on the hot roller which is the top roller when these get worn through the outer coating they will create black streaks
Dec 05, 2009 | Lexmark E238 Laser Printer
Balck and white streaks on left side of paper
Usually if there are streaks you need to change the pcu that is the same color as the lines. If the streaks are gray it also could be the fuser, but i would think it is the pcu.
May 18, 2009 | Ricoh Aficio CL3500N Laser Printer
Apr 16, 2009 | HP LaserJet 1020 Printer
Scanner/Printer imageCLASS MF6550
Does it do it on prints aswell as copies?
If so open up the Left hand side door if you peer inside at the fuser (hot bit) can you see any damage. if so needs replacement.
Also could be the drum, look in the same area at the green/blue cylinder, these do up to approx 30,000 pages.
Hope this helps.
Mar 26, 2009 | Canon imageCLASS MF6550 All-In-One Laser...
Printer prints a line across the paper around three inch from the left hand side of the page.
Check your Toner Carts.
Is the line a certain color?
Black perhaps?
Lift the door of the toner cart.
If you see a streak on your toner drum, you will see a streak on your paperwork.
Look at your fuser as well.
Is there a problem with the big orange roller?
BEWARE! Don't touch the fuser roller its EXTREMELY HOT!
Let the printer cool down before inspecting.
Apr 24, 2008 | HP LaserJet 5500dtn Color Printer
What is causing black streak
You should try changing the toner cartridges first. There may be something stuck in it causing the noise and streaking
Apr 14, 2008 | Canon imageCLASS D661 Digital Printer
HP LaserJet Pro 200 color Logo
29 people viewed this question
Seeker5211
Seeker5211
