Question about Amstron LG Electronics LE50 Laptop AC Power Adapter (5A 90Watts) by Amstron (Generic) AC Adapter
How to installing HDD to a laptop - Amstron LG Electronics LE50 Laptop AC Power Adapter (5A 90Watts) by Amstron (Generic) AC Adapter
Samsung NP355E5 not boot from HDD.
You may find best results finding Samsung support for this at...
http://www.samsung.com/us/computer/pcs/NP355E5C-A01US-specs
If this, my reply helps, you may show that.
A
Jun 28, 2017 | Samsung Computers & Internet
Just installed a 300gig hdd and when i switch on my laptop i just get a black screen
Did your laptop support 300gig hdd? If it is, do the new hdd had OS. If not, try to replace the hdd. Also try to check the hdd from your bios and also check the booting priorities.
Mar 19, 2011 | HP 530 Notebook
Laptop 2nd HDD(Slave) running max 20mb/s
Why not install a new 2.5" hdd in your laptop caddy.I replaced my 40gb with a 160gb, works fine and the data tranfer speed is better than a slave configuration. The average speed of around 40mb/sec Is because of the smaller platter, the amount of cache, the firmware installed and so on.
Apr 09, 2010 | Fujitsu Computers & Internet
My Gateway ML6720 laptop will not boot, nor even
any news on this? I have the EXACT same problem.
Feb 23, 2010 | Gateway Computers & Internet
Emachines model MS2257 HDD password
Can you get into it at all. If you can't, try to reset to the factory presets. You can do this with:
  • A restore CD
  • A XP/Vista disk and choose to re-format and re-install it again (probably your best bet)
  • *If you can get in as a guest* Re-install from hidden Restore drive. (Usually by pressing ALT - F10) You
Sep 04, 2009 | Computers & Internet
Can i install in my laptop hdd sataII instead od
Yes, it is compatible. If your laptop only supports SATA 1, then the drive will only run at the S-1 speed.
Aug 05, 2009 | Toshiba Satellite A105-S4134 Notebook
Non Disk error... Compaq HP NC6400 3 Gb ram 120 Gb S ata hdd toshiba 1.83 Ghz Intel Core _____________________ well everything happened as the lamp above our table in the living room fell on my laptop...
Check the boot sequence in BIOS and make sure that you no usb device connected to your computer and also try to change you Sata mode in BIOS and see if that works.
Jul 27, 2009 | HP Computers & Internet
Hdd password frozen on laptop These both worked. Thanks much to Eddie333 and howarthjd2. What I ended up doing was this: Note- I was not replacing the HDD, merely trying to reinstall WindowsXP, which...
if you download the sata drivers from the toshiba website for your specific laptop and then extract them and get nlite ( www.nliteos.com and slipstream the drivers into the xp disc you can then re install xp and it should allow you to boot.
As for the hard drive frozen password that should be in the bios on the hard drive that you set it for so it should remember it
if not you may have to contact toshiba and they should have a back door password that they can produce once you give them the asset tag ( serial number of the laptop ) and once you enter that it should resolve the hard drive frozen issue.
Had a hard drive frozen at a school once and had to call dell ( as it was a dell laptop obviously ) and gave them the serial number and they created a back door password for me - jobs a good one :D
Apr 29, 2009 | Toshiba Satellite A205-S5804 Notebook
Installing win xp and vista together on dell 1537 studio
you will not be able to put os in the same hdd on a computer.also if vista is installed on one hdd & the other partition is on the same hdd so please try not to install 2 windows on same hdd,its not possible...
Apr 24, 2009 | Dell Studio 1537 Laptop
Network Boot Windows XP?
Put the HDD in any other computer , creat a folder called XPbackup and copy the XP cd to the folder, Start the XP install from the other computer  , when the install stops for CD key , turn of the computer and remove the HDD and put the HDD on the laptop and turn it on , Mostly the installation should start from where it stoped. If the Xp install askes for the source files , browse to the folder created and point to the files. Most of the time XP will install a generic HAL so no need to worry.
Mar 09, 2009 | Microsoft Windows XP Professional for PC
Amstron LG Electronics LE50 Laptop AC Power Adapter (5A 90Watts) by Amstron (Generic) AC Adapter Logo
Top Amstron Computers & Internet Experts
Computer Links
lapkitt
Level 1 Expert
Are you an Amstron Computer and Internet Expert? Answer questions, earn points and help others
