Question about Refrigerators
How do you flush drain on frig Model gsh25hgmb
  • Refrigerators Master
  • 4,654 Answers
You will need to remove panel number 214 in the back of the freezer in photo HERE . The drain opening will be just below the Evaporator location number 228 in same photo If you have questions I am here. Thanks John Tripp Appliance 911
Leaking Refrigerators
Contact me HERE
How do you flush drain on frig Model gsh25hgmb - 3c730d07-f00f-4aa4-b95d-61feaf7c4ae0.jpg
Posted on May 31, 2014
How do I flush the drain on my frig. Model gsh25hgmb
I don't know about flushing... I've always passed a single cable (not rigid wire) down through the vent hole to get all the gunk out.
May 16, 2014 | Refrigerators
Hotpoint model #ctxy14epjrwh slow water drip from inside of the refrigerator. inside the top of the frig, center, there are several components that appear to come down from the freezer. the lowest one...
That water is from the melting frost of the automatic defrost cycle. Their is drain in the freezer behind the back wall under the evaperator coil that is blocked, so instead of defrost water draining it's pooling in the freezer or in some case espically on models with the freezer on the top,the water is leaking from the freezer vents into the fresh food compartment.
The way to clear the drain is remove back plate and remove all ice build up and GENTLY make a small hole in drain through then totally flush w/warm water.
The exact location of drain is under the coil behind back freezer plate in the centeroldtech2332_52.jpg
Aug 24, 2011 | Refrigerators
Good afternoon........ I have a top mount frig.. we bought it in 1998. The frig works great..... The only problem we have is water seems to built up on the inside bottom of the frig.... I know it is not...
Hi Dan,
It sounds like you have a defrost drain issue. An annoyance to say the least. To repair you will need to clear the defrost drain as it can get a build up over a few years of use. On a top freezer model you will need to unload the freezer and remove the back panel, be sure the power is disconnected by unplugging the refrigerator.
With the back panel off you will see a set of coils that resemble a radiator in a car, below that coil is a pan that slopes to a hole the size of a dime, you may not be able to see that hole due to the ice build up. Clear the ice with hot water and towels to clean up the mess. Careful not to use anything sharp or damage the coil.
Once the ice is gone use a turkey baster to flush hot water down that dime sized hole until it flows clear, you will know when it is.
Reassemble and enjoy a water free frig.
Apr 18, 2010 | Maytag 21.7 Cu. Ft. Top-Mount Refrigerator...
Leaking water into frig when defrosts
The problem is the defrost drain is pluged. At the rear of the frig section up at the top you will see a small cup where the water drains into. I always used a large syringe with a rubber hose attached. Fill the syringe with hot tap water and flush the ice out of the drain tube. Once cleaned out and the water runs freely your problem will be solved.
Dec 27, 2009 | Kenmore Refrigerators
Model TBX21KLK water pooling UNDER vegetable bins
Your evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help.
Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the lower back of the freezer.
Sep 21, 2009 | Refrigerators
Model Number TBXW25FP Refrigerator has large volume 1/2 water accumlating inside on the bottom under the Veg and Fruit Trays, unable to locate any source. Need to sponge out every two days. What are...
your freezer drain is plugged and water is dripping into frig you need to get fixed and soon or it will freeze air openings to your frig and stop cooling
Aug 21, 2009 | Refrigerators
The freezer leaks water onto the bottom of frig and freezes.
Hi, It sounds like the defrost drain is plugged. You will need to remove the rear inside freezer panel and remove the ice covering the drain hole. Once the drain hole is clear, flush it out with hot water to make sure it is open. I use a baisting syreinge to flush them. Sometimes the dust from under the refrigerator gets in the drain and plugs them. I have also seen the drain tube under the refrigerator hanging down to low and blocked off where it goes into the drain pan.
Please let me know if this helps you at all or if I can assist you further.
Thanks
Vic
Jul 23, 2009 | GE GBS22HBP Bottom Freezer Refrigerator
Whirlpool drain clog
yes it is most likely the drain that is plugged and or frozen up. to repair this you will need to remove the rear access cover inside the freezer compartment clear all the ice from the drain pan and flush hot water thru the drain hole located in the drain pan. this is a fairly easy repair you can do youself. the hardest part will be removing and reinstalling the rear cover. good luck peyton.
BTW I use a turkey baster or large syringe filled with hot water to flush the drain line with.
Jul 04, 2009 | Whirlpool ED2FHEXMS Side by Side...
Roper frig, freezer on top ,frozen under tray.water in bottom of frig
sounds like you have a frozen defrost drain. This is a fairly easy repair you can do yourself.
  • Unplug refrigerator
  • unload food from freezer
  • remove icemaker if present (there are 3 screws remove the one on the bottom and loosen the 2 on top of icemaker then lift it off the 2 screws unplug from wiring harness)
  • remove 2 screws holding rear cover in place
  • move cover to the side or remove from unit altogether
  • defrost any and all ice from bottom of freezer and aluminum drain pan that is now exposed
  • flush drain hole that you will see once ice is cleared with warm water. (sometimes I use a large syringe or turkey baster to forcefully flush hot water thru the drain tube)
that should fix you up. if you have any further questions leave me a comment here and I'll gladly help any way I can. thanks Peytonreassemble in reverse order
Feb 23, 2009 | Whirlpool Refrigerators
Side by side frig
Sounds like your defrost evap. drain maybe plugged.. you didnt say what type and model it is.. Im assuming a sxs
take off back panel and find the drain hole to see if plugged... try pouring hot water down to flush after you check for blockage
& ice
Dec 01, 2007 | Refrigerators
Refrigerators Logo
24 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
