Question about Plumbing
Should my pentax pump cut off when my taps are close
  • 2,509 Answers
Yes if you fitted a pump with a flow sensor.Make sure there isn't a leak after the pump.
Posted on May 16, 2014
How do I stop pump from running? Cistern connected pump does not seem to be pressurizing. Pump not cutting off, and getting hot.
Pump probably needs to be serviced. It probably pressurizes a tank and when that tank reaches a pressure the pump is turned off. But just guessing.
May 27, 2015 | Plumbing
Pentax smart head
Check the pressure switch. Be sure you have enough water available. Check for a leak. What are you pumping. Is it pumping. I am not familiar with this pump so I am just listing some points to check. If it is a submersible well pump it can develop a lot of pressure.
Nov 29, 2013 | Plumbing
What causes a pentax smart head to cut off and on during use of water
There's not enough water running into the pump this is why its cutting out , hope this helps
Oct 09, 2013 | Plumbing
Pentax water pump 1/2 hp when pump starts works well but pump does not cut out when all taps in the house are closed
it sounds like the switch is faulty take it back to the shop and tell them ok
Mar 28, 2011 | Vacuums
Pentax smart head loosing presure system has no leaks continuosly switcing on and off ,also not switcing on when washing maching starts its rins cycle ,have to press reset button to start pump again.
hi i have a pentax water pump the smart head, it works very good .one day the pump did not come on when i turn the pipe on so i take off the switch i put it back on the pump came on water was flowing as normal when time to turn the pipe off the pump will not cut off so i switch it back off and call an electrician he check it and he said i need to change the circuit board in the pump so he did now the started to work only on the lower pipe but it takeing long to come on and cut off.the upper pipe when turn on the pump not coming on i open all the union to bleed make sure on air in the line but still having the same problem can this be the head it self need changing?
Jan 16, 2011 | Plumbing
Pentax DSmobile 600 scanner cuts off image
Try recalibrating it. If you don't have calibration sheets, buy them at:
Calibration Sheets and Cleaning Kit $2.98 plus shipping.
http://www.opticsplanet.net/pentax-dsmobile-600-calibration-cleaning-kit-206717.html
Jul 30, 2008 | Pentax DSmobile Path-Through Scanner
Plumbing Logo
90 people viewed this question
Top Plumbing Experts
Donni Steen
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
