Question about Panasonic TC P42S1 42 in. Plasma HDTV
How to Repair panasonic plasma HDtv model tc-p42s1 the power red indicator light is blinking 11 times?
The power red indicator light is blinking 11 times?
SOURCE: 4 blinking lights
I fixed it myself!
I bit the bullet and ordered a replacement Power Board for AUS$290 and swapped it out myself.
Only took ten minutes, most of that time was removing and replacing the 101 screws holding the back panel on!
Working fine again now.
I did sit the two boards side by side and noticed the new one had moved some of the micro components from the back of the board to the front plus some other small component changes.
If your handy with a screw driver and have some technical knowhow I recommend having a go at fixing it yourself as it wasn't hard and probably saved $200 in service charges (all this assuming you are out of warranty!)
Posted on Oct 27, 2008
SOURCE: Model TC-32LX700 Power indicator light on from is
Problem is caused by voltage irregularity. Pulled plug for an hour and then plugged it back in. TV reset and it works fine. If this does not work it needs a TV technician.
Posted on Sep 15, 2009
gripfitter
  • 557 Answers
SOURCE: Panasonic Plasma TV - Model # TH42PX77U does not
This is a difficult question to answer completely. 7 blinks indicates that one of the C boads has failed. however, there are several an SC,SD, SS and SU.
The procedure is to disconnect each of there boards until the blinking is eliminated. The labor charge is usually around 200.00 and the cost of whichever board is bad. Hope this helps.
Posted on Oct 21, 2009
lovejoy91
  • 691 Answers
SOURCE: WHY MY panasonic tc-50ps14 IS BLINKING A RED LIGHT
I have a 10 blinks and 12 blinks for that set, 10 says it possible SC board, and 12 says
Unplug the TV and disconnect connector A11 from the A board. Plug in the TV and press the power switch
Does the TV power up and
stay on?
No
Yes
If the speakers wires
are not pinched,
Replace
the speaker
Replace
the A board
Posted on Jan 17, 2011
SuperTech-11
  • 1591 Answers
SOURCE: I have a TH-42PX75U panasonic plasma HDTV and the
Ah, the dreaded 7 blinks of death.
Try this solution first (click here).
If the link doesn't work then paste this link into your browser address bar.
http://www.fixya.com/support/r8558239-lcd_or_plasma_tv_or_monitor_turn_or_stay
Posted on Mar 10, 2011
Tv will not come on, red light on front is blinking
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. Viewing it in "Mosaic" or "Magazine" will make surf easy.
Blinking codes details to many popular brand TVs are given. Surf the site with patience. Do a search by type in the brand name of the device to the search box.
Jul 22, 2014 | Panasonic TC P42S1 42 in. Plasma HDTV
Panasonic TC-P55ST30 red light blinks 7 times next to the on/off switch please diagnose, no power
These blinks are fault indication, and known as blinking codes.From the number of blinks occur at one time switch ON; you can get an idea about the faulty circuit stage inside the TV.This will make repair easy. For more information, check the link
Dec 06, 2013 | Panasonic TH-50PX60U 50 in. Plasma HDTV
Panosonic tc-p42s1 10 blinkes
This should help diagnose the problem.
Apr 04, 2013 | Panasonic TC P42S1 42 in. Plasma HDTV
I have a Panasonic Model TC-P50S1 plasma TV and the red indicator light continuously blinks and the TV never does come on. Can this be fixed?
Panasonic utilizes the blinking light as a form of self-diagnostics, similar to the "check engine" light in your car. If you've ever experienced that, you know that a check engine light could indicate anything from a loose gas cap to a major failure.
Panasonic uses the number of times the light blinks, to aid the technician in trouble-shooting the problem. The blinking light indicates an area of concern and helps the technician to isolate the problem and order the correct parts. This in turn speeds up the repair process, keeps parts cost down, and helps both you and the servicer by allowing the technician to complete a repair in one trip in most cases.
So contact an authorized service center.
May 28, 2011 | Panasonic TC-P50S1 50 in. Plasma LCD HDTV
Is this a Plasma TV?
Yes.
http://reviews.cnet.com/flat-panel-tvs/panasonic-viera-tc-p42s1/4505-6482_7-33490462.html
excellent article that goes in detail about this specific tv, but yes deffinately a plasma.
Feb 07, 2011 | Panasonic TC P42S1 42 in. Plasma HDTV
My set just shut off and is now blinking 10 times.
What can possibly cause 10 blinks
A.Missing/Shorted F_15V
B.Shorted Vsus
C.Missing/Shorted SUB5V, SUB9V, BT30V.
D.IC1100, IC9003, IC9004
E.Unplugged SC20, SC2
F.Possibly SU and SD boards
Information from Panasonic.
May 18, 2010 | Panasonic TC P42S1 42 in. Plasma HDTV
Panasonic TC P42S1 42 in. Plasma HDTV Logo
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
