Question about Cuisinart Supreme Grind DBM-8 Electric Burr Grinder
Cuisinart DBM-8 timer
Timer does not work.
SOURCE: Cuisinart DBM-8 Supreme Grind Automatic Burr Mill stopped grindin
We are on our second and last machine; after this DBM 8 goes out, I am going to find the most basic grinder I can and stick with it. That said, I fixed ours by removing the clear plastic reservoir where the ground coffee ends up, and then removing the build-up of coffee grounds around the exit chute where the ground beans enter the reservoir.
So, slide the reservoir out, just as you would when emptying it in to your coffee maker and set it aside. Have a flashlight ready when you tilt the grinder forward. On the back side you will see the hole where the ground beans empty into the reservoir. Take a toothpick and get rid of all the clay-like coffee reside that has built-up around that hole. Use a can of dusting air, if possible, (the aerosol "can" type used to blow dust particles from your computer) and blow away all possible ground coffee residue in the hole and around it. This will allow the reservoir to seat snug and flush again. This process fixed ours and I don't know why for sure, other than I suspect, the clay like build-up of coffee grounds, over time prevents the reservoir from seating properly and it has to seat perfectly to work. Good luck.
Posted on Mar 28, 2009
SOURCE: Cuisinart DBM-8 Grinder Automatic Burr Mill stopped grinding
perhaps remove the hopper (top) and inspect to see if a buildup of very fine compacted grounds as accumulated. knock the stuff loose.
VtToolMan
  • 704 Answers
SOURCE: i need a replacement bottom burr for the cuisinart
Give Cuisinart Customer Service a call at 1-800-726-0190. Or you can contact them via the web at www.cuisinart.com/support/us.html
They can get you the parts you need.
Hope you found this helpful. Best regards!
Posted on Aug 04, 2009
ThaMp3Doctor
  • 8596 Answers
SOURCE: Works sporadically
Try this and let me know if it works - plug the coffeemaker in, turn the function knob to BREW, and then press all 3 buttons in the center of the coffeemaker (the 1-4 button, et, etc) and hold them for a few seconds. Let me know if the clock display comes back on.
Posted on Sep 30, 2009
SOURCE: coffee grinder not working
My burr grinder also stops if the ground spout (where the coffee shoots out) is clogged. I use my grinder for an espresso machine so i always have the setting on the finest and so with the oils and the fine grind it clogs this spout pretty often. I"d check yours out too (ie remove the coffee ground bin and you can see the spout. If it is clogged uplug the machine and take a tooth pick and un clogg it. Don't jam the tooth pick in there to deep you don't want it to get shuved into the grinder wheels.
Posted on Feb 07, 2010
How do i clean dbm-8 grinder
Do yourself a favor and got the right kind of grinder for the coffee you drink. If you have a dry coffee use a grinder. High oils in some coffee need the blade type of grinder. Usually you can tell by looking inside the bad. See oily coating get a blade type.
Feb 19, 2015 | Cuisinart Supreme Grind DBM-8 Electric...
Cuisinart DBM-8 coffee grinder started by itself.
Mine did it as well. I had an electrician out to check out the outlet. He replaced the outlet, but it still has done it. It freaks me out, so I unplug it after use.
Nov 02, 2012 | Cuisinart Supreme Grind DBM-8 Electric...
Grinder does not run at all.
MY DBM-8 CRUISINART WILL NOT GRIND COFFEE BEANS THE
Apr 04, 2011 | Cuisinart Supreme Grind DBM-8 Electric...
I have a cuisinart ccm-16pc coffee grinder. I need a couple of parts, namely the grinding wheel (that's attached to the motor) and the plastic gromet (for lack of a better word) that fits on top of the...
For future reference the Manual for the DBM-8 is here:
http://www.cuisinart.com/share/pdf/manuals/dbm-8.pdf
Available parts:
http://www.cuisinart.com/parts/coffee_bar/dbm-8.html
Here is another site for parts; they do not list what you are looking for but you can make an on-line inquiry for parts.
http://www.abtecparts.com/cuisinart_grinder_DBM8C.htm
Parts Inquiry:
http://www.abtecparts.com/parts_enquiry.htm
Unlike many appliance makers Cuisinart does not have an on-line search function for service centers. If they could not name one you might try contacting some small appliance repair shops; if not able to help they may be able to direct you.
Feb 13, 2011 | Microwave Ovens
I need a replacement bottom burr for the cuisinart dbm-8. the bottom burr broke. all i need is a new one. can't find a place to buy it. hoping for a lead.
Jul 07, 2009 | Cuisinart Supreme Grind DBM-8 Electric...
Jan 28, 2009 | Cuisinart Supreme Grind DBM-8 Electric...
Cuisinart grinder stem wobbles
Search Cuisinart's website for DBM-8 - that model has exactly the same parts as your Cuisinart. If you call them, they may even cover it under warranty.
Jun 22, 2008 | Cuisinart Supreme Grind CCM-16PC Grinder
Cuisinart grinder wobbles
The model that you have is Costco's equivalent of the DBM-8 - the parts are exactly the same, so enter "DBM-8" as your model # on the Cuisinart website for parts.
Dead machine
It's under warranty, contact Cuisinart for repair.
Jun 21, 2008 | Cuisinart Supreme Grind DBM-8 Electric...
Cuisinart Supreme Grind DBM-8 Electric Burr Grinder Logo
183 people viewed this question
Top Cuisinart Coffee Makers & Espresso Machines Experts
Greg Cann
Greg Cann
880runner
Level 1 Expert
Michael Galve
Michael Galve
Are you a Cuisinart Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
