Question about Sharper Image 1617293 Projector
No picture lamp is on, audio works, but no picture, can anyone help?
I had the same problem. took out the buld re-inserted it and turned 'projector back on as i was tighting in the screws... picture popped right out.
Posted on Aug 09, 2009
Hello I have the infocus screenplay 5000 projector & after reading all the posts here decided I dont have a similar problem to anyone else. My bulb life expiration came up months ago but the unit works...
working with expired lamp can cause the overheat, and the power supply will be damadged, you need to replace the chemical caps at secondary parts as shown in the picture below:
Feb 11, 2014 | InFocus ScreenPlay 5000 Multimedia...
Hello, I have a Samsung DLP HLR5667 and it blew a lamp 4 months ago, I replaced the lamp and it worked fine for about 2 months and started shutting off after only running for about 90 seconds. I reset the...
You need to replace your color wheel. This is a very sensitive part and you need to take care when replacing. If you feel comfortable I can walk you through it. If not, I would take it to a authorized service center.
Apr 18, 2011 | Samsung Televison & Video
Just replaced the lamp after 2 years. TV worked
Make sure that the lamp cage is seating well .. then make sure the door is closed properly. there is a door switch and if the door dont close right the switch may be telling the set the lamp is out.
Oct 23, 2009 | Mitsubishi WD-62531 Projection Television
WD-52631 Audio works, but no picture
Probably a bad lamp. This is the first thing I would try....especially if the lamp has not been re[placed in awhile.
Oct 10, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Hi again
yes 3x its lamp cover no doubt. ballast supply will give different error on this unit. this should help hdtv man
Diagnostic Item
Description
Number of times
STANDBY or LAMP LED
lamp flashes
Probable Cause Detected Symptoms
Lamp cover error 3 times - Lamp cover is not fastened securely - No picture/No sound
Fan error 4 times
- Fan1-4 Power is not supplied.(G2 board)
- Fan connector is not seated securely
- Fan caught wires or harnesses
Temp error 4 times
- Internal temperature is too high
- IIC-E line connector is not seated properly
(WE:H3 board, WF/XS:H4 board)
Lamp driver error 5 times - Lamp driver defect - No picture/No sound
Low B error 6 times -No "DD 6V " output (G1 board) - No picture/No sound
Audio error 7 times
- Short-circuit of Audio power supply line
(KD board, G1 board)
- Blowout of a fuse
(F4702,F4703,F4704 on KD board)
- IC failure
(IC4703,IC4708,IC4710 on KD board)
D-OVP error 8 times
- Overvoltage of +3.3V or +2.5V
(A board, B board)
ATSC-OVP error 10 times
-No "DTL MODULE 5V " output
(G1 board, G2 board)
Lamp error LAMP-LED is ON. - Lamp is dead - No picture/No sound
Jul 01, 2008 | Sony Grand WEGA KDF-42WE655 42" Rear...
I bought a Samsung 46" LA46F81BD today pluged it in and tune the tv. The picture was great after about 30 minutes the TV went blank and lost picture. I still have audio. does anyone know what the...
If this is a projection TV,you may have suffered premature lamp failure.If it's an LCD,could also be a backlight lamp failure.Either way,it should be under warranty if it's new.
Mar 13, 2008 | Televison & Video
REMOTE NOT WORKING NO AUDIO AND NO PICTURE
Most times this unit goes dead because either the lamp is bad or need to be reseated. Pull the from cover off to find the lamp. First pull out the lamp, clean the contacts on the lamp by just wiping them with a soft cloth and reseat the lamp. Re-assemble and see if that helps. If not you will need to replace the lamp.
Jan 16, 2008 | RCA HD61THW263 61" Rear Projection HDTV
TV Shuts off and on by itself
this problem has been seen and repaired at Sony from a bad lamp.Especially if lamp has lots of hours of use.Try a new lamp as see what happens.I have access to Sony docs and this is what I read..goodluck
Nov 30, 2007 | Sony KDF-E55A20 55 in. LCD Television
Assistance
i would try new lamp or ballast since you have 250v from pwr sup
Oct 22, 2007 | Televison & Video
Sharper Image 1617293 Projector Logo
274 people viewed this question
Top Sharper Image Office Equipment & Supplies Experts
k24674
jasbo
jasbo
Marvin
Marvin
Are you a Sharper Image Office Equipment and Supply Expert? Answer questions, earn points and help others
