Question about HP Pavilion ze5375us Notebook
How do i fix my hp laptop screen displaying white
The computer boots but the display remains white.i can hear the speakers as the windows xp boots.i try tongling using f5 but it remains the same.
antiochpc
  • 1314 Answers
SOURCE: Vertical white line on laptop display
Yes, this is a defective screen. The only fix is to replace the screen. It's called a column of dead pixels. Since it is under warranty, contact HP to have them warranty it out or take it back to the place you purchased it from for an exchange. Please take a moment and give this answer a good rating of fixya. Thank you.
Posted on Dec 26, 2008
falsafat
  • 31 Answers
SOURCE: HP laptop stuck in quickplay mode
When Quickplay start try pressing ALT+F4
Posted on Apr 12, 2009
  • 788 Answers
SOURCE: HP laptop display issue
If you are recving 1 long and two short beeps, it is not a memory problem.
It is not a Lid closing or lid switch problem.
If you are able to switch to and from your LCD and Monitor, you are lucky.
I have been up and down the road with several HP DV6000 series units, all have had the 1 long and 2 shot beeps.
HP is aware of this problem and has offered an extended 1 year from date of original warranty expiration. Another words 2 years from date of purchase. HP will ask for $365.00 + or - ? for this repair.
Their repair consists of a motherboard replacement.
If you go to HP's web site, you can look up your model and if in warranty, have it sent back for repair.
The problem will not get better in time but only worsen. The heat sink on the dual core units is not handling the heat transfer properly.
The board is a 2 sided wafer which has displayed failure in several places, due to the heat load and transfer design. Area of problem is directly under NVIDIA chip look for craters. Theses are solder points the size of a pins head which because of the heat and the stress of the transfer bracket above, have separated making in some cases an intermittent connection to chip.
The best thing to do is have a technician remove the board from inspection and blow out the heat sink and surrounding areas.
Apply new heat sink tape and grease where needed and re-assemble.
You must update your BIOS ver. to current.
This new version will address the Voltage and Fan Control Speeds in a better manor.
If your unit is just now giving you these errors, now is the time to act.
Just like in a A/C unit at home, a restricted air flow will make unit run longer and hotter.
Their are no filters here, once lint and dust have collected in the coils, it is just a matter of time.
Hope this helps you in your problems.
Anybody reading this note having a DV6000 series unit, should check at their web site for warranty and call back issues.
John
john@johnrraycomputer.com
P.S. if you are a technician and feel you want to repair the board yourself, drop me an email with the model number and I will explain in more detail.
Posted on Jun 11, 2009
babes_ganda0
  • 381 Answers
SOURCE: hp mini 1000 - no startup display
you got error this windows/OS system so u need to re-install the OS/Windows..good luck and have nice day
Posted on Jun 18, 2009
chryssthina
  • 77 Answers
SOURCE: My HP 6530b laptop will not boot up, I get a blank
remove the battery and adapter. press power button for 30 sec. then connect the adapter. press power button. if this didnt work. you need to ask for an help of a local tech to check for the video card and cable.
Posted on Apr 06, 2010
How to restore corrupted BIOS of presario cq60 laptop
Whenever you upgrade the BIOS on your notebook, a copy of the previous version is stored in the HP TOOLS partition of your hard disk drive. Many HP notebook computers have an emergency BIOS recovery feature that allows you to recover and install the last known good version of the BIOS from the hard drive, as long as the hard drive remains functional. This emergency recovery feature is separate from the BIOS and is designed to work in the event of a catastrophic BIOS failure.To recover an earlier version of the BIOS on your notebook:
  1. Turn off the computer.
  2. Plug the notebook into power using the power adapter.
  3. Press and hold the Windows key and the B key down at the same time while the computer is off.
  4. Still pressing those keys, press and hold down the Power button on the notebook for 3 seconds and then release the Power button and the keys. The screen remains blank for about 40 seconds before anything appears on the display. You might also hear beeping sounds. Eventually, an HP BIOS Update screen displays.note.pngNOTE:If the computer fails to display an HP BIOS Update screen, press and hold the Power button for 5 seconds to turn off the computer. Wait 5 seconds and try again. If, after repeated attempts, you cannot open the HP BIOS Update screen, your computer does not support this function or it has a hardware problem that is preventing the tool from opening.Figure 1: HP BIOS Update screenc03376208.jpg
  5. When the BIOS has been recovered, a Continue Startup button displays and timer counts down. You can click Continue Startup to restart the computer or you can allow the timer to reach zero and the computer will restart automatically.Figure 2: HP BIOS Update screenc03376209.jpg
  6. After restoring the BIOS, if the computer repeatedly displays a message that the BIOS has been reset, then perform the steps in HP BIOS Application Selected is Corrupt or Missing .
  7. After restarting, Windows may display a message stating that the computer was improperly shut down or that a boot problem was detected. Read and respond to the screens to continue.
Sep 22, 2012 | Maxtor Personal Storage 3200 (U01E200) 200...
No display in Acer aspire 4520g laptop
Have your laptop check up the technician, it has somethingt to do with your video card
Nov 05, 2009 | Acer Aspire 4520-5582 Notebook
Will not boot up. Screen displays Window XP
Use your original Windows XP CD and run the recovery console when starting up the pc. Thats should repair any files which are hanging the pc at the XP logo
Oct 13, 2009 | HP vs17
Screen goes black after Windows Vista boot
Hello There is chance of serious problem with the screen of the Your laptop. This problem is often seen in case of HP laptop which are more then 6-7 months old. So if the laptop is under warranty they(customer care) will replaced the screen for free. If not the will charge few $ and provide you with original screen. Please check with the vendor from where you have bought your laptop. Regards Gizokieth
Oct 06, 2009 | HP Pavilion dv2310us Notebook
Hp mini 1000 - no startup display
Jun 18, 2009 | HP Mini 1000 Netbook
My HP monitor (f50) has malfunctioned
Try these 2 steps if they don't work get back to me :)
Step 1. Connect the video cable and turn on the computer. What happens?
  • If the monitor screen remains blank (no startup screens or onscreen display messages), the monitor must be connected to another computer using a different cable to determine if the monitor is bad. Skip to the Step to connect the monitor to another computer.
  • If the monitor is capable of displaying boot screens but is unable to display Windows, use the following steps to set the computer to a compatible resolution:
    NOTE: Find the native display resolution for your monitor in the User Manual or in the product specifications for the monitor model. If you are unable to find the native display resolution for your monitor model, temporarily use 1024x768 for troubleshooting purposes.
    1. Turn on the computer and press the F8 key repeatedly when the first startup screen appears.
    2. If you are using Windows Vista, select Enable low resolution video (640 x 480) , press Enter , and wait until Windows opens. To set display settings that match the monitor, use the steps in the HP support document, Changing Display Settings, Background Image, and Screen Saver in Windows Vista . If you are using Windows XP, select Enable VGA Mode , press Enter , and wait until Windows opens. Continue using these steps to set display resolution. If you are using Windows 98 or ME, select Safe Mode and perform the following steps to enter into a standard VGA mode:
      1. Once Windows opens to the desktop in Safe Mode, click Start , and Run .
      2. In the Open field type msconfig and press Enter . The MS Configuration Utility window appears.
      3. Click the Advanced button, and select VGA 640 x 480 x 16 if it is available.
      4. Click OK and restart the computer.
      5. After Windows opens, click Start , and then click Run .
      6. In the Open field type msconfig and press Enter .
      7. Click the Advanced button, and remove the checkmark next to VGA 640 x 480 x 16 .
      8. Click OK . Do NOT restart the computer.
    3. After Windows opens, right-click on an open area of the desktop and select Properties (Windows XP, 98/Me) or Personalize (Windows Vista).
    4. In Windows Vista, Scroll down and click Display Properties . In Windows XP, 98, or Me, click the Settings tab.
    5. In Windows Vista, select the native display resolution size using the Resolution slider. Set Colors to Highest (32 bit) . In Windows XP, select the native display resolution size using the Screen resolution slider. Set Color Quality to Highest (32 bit) . In Windows 98 or Me, select the native display resolution size using the Screen Area slider. Set Colors to True Color .
    6. Click Apply after you have made your adjustment. The screen should blank out temporarily and come back.
    7. If you are satisfied with the new display settings, click Yes on the Monitor Settings windows. If you are not satisfied or if the screen just goes black, wait: Windows sets the screen back to the way it was before. Try another setting until you find a display configuration that is compatible with the monitor and meets your needs.
      NOTE: If the native resolution is not available, download and install updated video driver software for your computer. Updating the video driver software can add more resolutions (graphics modes).
    8. Restart the computer. The monitor should now display a full screen image in high quality. You are done.
Step 2: Connect to another monitor
Using a different cable, connect the monitor to another computer that has video. Turn on the monitor and the newly connected computer. What happens?
  • If the monitor works, the video hardware on the original computer is likely to be the source of the problems. You can try connecting the original computer to another monitor that works to update its video drivers.
  • If the monitor remains blank, repair or replace the monitor.
Dec 27, 2008 | HP Pavilion F50 17" Flat Panel LCD Monitor
HP Pavilion ze5375us Notebook Logo
13 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
