Question about Troy Garden
How to replace steering belt on zero turn toro lawn mower
  • Troy Master
  • 2,760 Answers
If you mean a drive belt (not a mower belt) then im sorry to tell you your gonna need to remove the mower deck , this is only possible with help of a small crane or a stout tree limb and a bit of chain or cable (rope not good enough) , use a breaker bar to move off tension roller and fish belt around pulleys then let tension arm back down (four hands really make this easy) then lower machine back down onto cuter deck and make sure belts and pins line up right
Posted on Sep 19, 2015
  • 78 Answers
SOURCE: blade belt diagram for John Deere LX178 Riding
Remember the belt rule, V of the belt goes in V pulleys.Flat pulleys that are stationary or move get the back of the belt. You can figure it out. Its not rocket science. Remember at some point there has to be a tensioner,usually gets the back of the belt if its a flat pulley. U may have to remove the spring and then reattach the spring after the belt is routed.
Posted on Oct 29, 2009
rwvanlue
  • 486 Answers
SOURCE: Stuck pull cord on Toro 6.5 self-propelled mower
1) Common problem when a mower sits for several weeks at a time between mowing;
check for extra grass debris to be glogged between the blade and the mower shell.
2) If the mower has a 'bail' or 'zone' control handle;
this releases a brake mechanism on the flywheel to allow it to rotate, and after it is running, releasing the lever will 'kill' the engine.
NOTE* when transporting a push mower in the trunk of a car, try to keep the mower as level as possible.
*extra note when mower has been transported in the back of a car;
sometimes the mower is placed in a trunk at such a severe angle that the oil from the crankcase is forced around the rings and sits on top of the piston so that when you try to pull the rope you have a 'hydra' lock. (that is when a liquid is between the piston and the spark plug) You cannot compress a liquid, so the rope appears stuck.
If this happens, remove the spark plug (make sure the loose plug wire is fastened away from any combustable that comes out of the spark plug hole *** AND THERE WILL BE A HUGE STREAM OF OIL AND GASOLINE, SO BE PREPARED TO CLEAN UP A MESS ***
pull as normal until fluid is dispelled from internal engine
clean or replace the spark plug
a few more pulls (no choke required) and you are up and going
I’m happy to assist further over the phone at https://www.6ya.com/expert/rolandw_c013176d62ee17ae
Posted on Nov 08, 2009
  • 252 Answers
SOURCE: lawn mower belt diagram
try www.johndeere.com apply for user id and password
will need to wait for these to be issued to you via e-mail
then go to www.jdparts.com and enter your user id and pw and enter the correct site for your country and then enter model stx38
scroll through list to find deck or attachments and double click it
your deck could be a yellow or black deck
cheers
Posted on Jul 21, 2010
barterjoe
  • 344 Answers
SOURCE: how to replace the drive belt of a t zero turn
Remove the idler spring under the machine and remove the deck belt and keeper.
the belt will come off easily after that. If you have questions see a dealer like www.arcolawn.com
Good luck
Joe
Posted on Apr 05, 2011
  • 6468 Answers
SOURCE: how to replace drive belt on self propelled toro commercial push mower
the should be a plastic cover under the engine
Posted on Mar 29, 2012
Why won't my Toro aero turn
First, make sure the steer stick in moving the lever into reverse. Please check this with the engine off
Second, Check the belt tensioner. Sometimes they end up stuck which has been known to cause the belt to slip on the left transaxle only.
Third, buy a new transaxle...
Next time, include model number for a more precise answer
Apr 01, 2015 | Toro 42 In Deck 19 Hp Kohler Courage Twin...
Toro manuals
If the belt has quite a few hours it may have stretched enough to cause it to slip. May have to replace it. I replaced mine and works fine now. As a short fix you can spray with a belt dressing and will work for a while if the slippage is not too bad. The can will specify for slipping belts.
Feb 24, 2014 | Toro Titan ZX4800 23HP Zero Turning Radius...
My 42" toro zero turn
the drive belt pulley probably needs replacing or the belt popped off the pully
Apr 03, 2011 | Toro 42 In Deck 19 Hp Kohler Courage Twin...
How to replace the drive belt of a t zero turn riding lawn mower
Good luck
Joe
Nov 05, 2010 | Toro 42'' Zero Turn Lawn Mower 22hp Kawa...
Can i match a toro belt with anothere brand belt without any problems? if so where can i search?
The belt can be measured by your local hardware/lawn care dealer or by reading the numbers on the belt itself. You will find that purchase price is likely to drop significantly by buying an aftermarket belt too!
Jun 08, 2010 | Toro 50'' Zero Turn Lawn Mower Trailer...
Garden Logo
82 people viewed this question
Top Troy Garden Experts
Jim Parker
Jim Parker
Matt Olenzek
Matt Olenzek
DROPNDEAL
DROPNDEAL
Are you a Troy Garden Expert? Answer questions, earn points and help others
