Question about Rockford Fosgate Car Audio & Video
Faceplate issue i dont know where the button or whatever i have to do to take the 9200 face plate off i got this from a uncle and he doesn't remember and i don't see anything in the online manual plea
Its the RFX 9200 model
Duncan
  • 218 Answers
SOURCE: lost face plate
Try http://parts.pioneerelectronics.com/advancedSearch.asp?searchString=FACEPLATE
Posted on Jul 23, 2007
SOURCE: Jensen Phase Linear car radio
Take off the face plate and it is located in the lower left corner
Posted on Mar 31, 2008
  • 3 Answers
SOURCE: ribbon cable broken and now cannot open the face plate
You need to take the unit apart to fix the cable since the other end of it plugs into the board inside, it's pretty easy to take apart though. Good luck!
Posted on May 13, 2009
  • 5 Answers
SOURCE: unresponsive face plate/ buttons
check wiring to make sure all wires r properly connected, sounds like a power problem . if it is an expensive radio and it is broken then its probably worth fixing.if its a cheepie than chunk it and get a new one
Posted on Jun 28, 2009
MNfisherman
  • 11896 Answers
SOURCE: Another one with Faceplate buttons not working?
The capacitors in these plates tend to burn out quickly for being so hot and lack of air cooling circulation. You can test all connection pins on the deck and faceplate with an ohmmeter in ohm setting to see which pins is not sending 25-30 ohms or 5 volts of power
Posted on Oct 23, 2009
SRC button on faceplate doesn't work
yup. that can be a reason.
use a new one and check it.
Jul 22, 2008 | Kenwood KDC-225MR 200W Car/Marine SIRIUS...
Sony CDX-MP70 Face Plate Controls
the programmed chip is malfunctioning....
this could have occured due to some short circuits...
take to service centre..no idea whether they would reprogram the chip..
Apr 11, 2008 | Sony CDX-MP70 CD Player
Faceplate display only functions when you touch a knob or button
THE FACEPLATE HAS LIKE SOME PINS WHERE IT MAKES CONTACT THE FACE PLATE WITH THE STEREO BODY WITH A COTTON AND SOME ALCOHOL CLEAN THE CONECTOR THE ONES THAT ARE IN THE STEREO BODY AND THE FACE PLATE BUT WHEN YOU MAKE IT MAKE SURE THE CAR OR FACE ITS TURN OFF
Nov 02, 2013 | Alpine CDA-9831 CD Player
There is no display on the faceplate. The faceplate is stuck in the CD eject position. If I remove the faceplate the mechanism rotates to the position where the controls would be visible but when I attach...
I would try cleaning the connectors on the face plate with an pencil eraser and on the unit itself with a very fine sand paper. And make sure you get rid of any dust after cleaning before putting the face plate back on.
Please leave me a good feedback.
Thanks
Jan 06, 2011 | Kenwood KDC-8021 CD Player
Faceplate wont work
the new face plate needs to be coded to the deck. with the face on you need to press and hold presets #1 and #3 at the same time. keep on holding and press reset continue to hold #1 and #3 until the unit is in all lighting mode. press AM button one time. p-rom ok will display. press and hold #6 and reset at the same time. continue to hold until display comes on.
Jul 18, 2010 | Kenwood eXcelon KDC-X879 CD Player
Can I purchase this faceplate individually
sounds like the deck itself has gone bad dont waste the money on the face plate thats not ganna fix anything but make it look better just get a new deck
Mar 27, 2009 | Clarion M475 CD Player
Replacing the facepale
that hole on that model is for a locking screw, the locking screw is installed to minimize theft and for other precautions. If the face plate is having any odd reactions its normally do to the flex cable. The best sign for a dying or dead flex cable is at the joint. The joint can be viewed at the point when you remove the face plate. Immediately after pulling the face plate off look behind the pivoting frame at the orange colored ribbon, you should only be able to see a small portion of it. If there is any sign of a yellowy residue its a sign that the protective covering of the ribbon is deteriorating. A bad flex cable is everything on the moving face plates.
Sep 06, 2008 | Kenwood KDC-716S CD Player
Rfx9200
try to reset the unit... by pushing in the reset button under the faceplate... if that doesn't work call rf for technical support...
Sep 02, 2008 | Rockford Fosgate RFX-9200 CD Player
Car Audio & Video Logo
24 people viewed this question
Top Rockford Fosgate Car Audio & Video Experts
Tygh Duval
Tygh Duval
Professor_V
Professor_V
Robert Rankin
Are you a Rockford Fosgate Car Audio and Video Expert? Answer questions, earn points and help others
