Question about Fujitsu Office Equipment & Supplies
What is the solution for fujitsu fi 6770 pop up error for mechanical malfunctioning?
2 Suggested Answers
  • 8 Answers
SOURCE: Fujitsu FI 5120C pop up error for paper jam
Please clean the separation pad and the pick roller.
If this don't help change them.
The Fujitsu sparepart numbers:
pad PA03289-0003
pick roller PA03289-0001
Posted on Jul 15, 2008
What causes the error code J?
The error code J in Fujitsu fi-6140 scanner is associated with Document jam or feeding related issues. J-0 error is paper jam error caused by paper protection sensor malfunction, J-1 is also paper jam caused by US sensor malfunction and J-2 multifeed error caused by poor performance or malfunction of US sensor error.
Regards,
ScanCare
Aug 13, 2014 | Fujitsu Fi-6140 High Performance Color...
Error EF
The error code EF displayed on your fi-5750c scanner front panel explains Background switching mechanism alarm. The probable causes are:- Background detection sensor connector disconnected.
- Defective background detection sensor
- BW motor connector disconnected, Defective BW motor
- Defective background unit F
- Defective background unit B
You are rceommended to visit nearest Fujitsu service station for rectification.
Thanks & regards,
ScanCare
Nov 07, 2013 | Fujitsu fi-5750C Flatbed Scanner
I receive an error F4 on my scanner when I turn it on. Will not scan. Any suggestions?
Hello Larry,
The F-4 error in Fujitsu fi-6240 scanner indicates Background change over unit malfunction alarm. It may be caused by the malfunction of background motor or optical unit or damaged optical cable.
You are recommended to contact the nearest Fujitsu scanner service center for rectification.
Thanks & regards,
ScanCare
Sep 25, 2013 | Fujitsu Fi-6240 Flatbed Scanner
What's wrong if i get error e9
E-9 error in Fujitsu fi-6670/fi-6770 is the Image Memory Alarm which implicates scanner memory malfunction.Turn off and turn on the scanner, does the same symptom still occurs? If yes, then you may have to replace the DIMM located at the memory slots on the CGA board. If the issue still persists after replacement of DIMM, then you may have to replace the Control PCA. I would recommend to contact an authorized FUJITSU scanner service provider or the dealer where you purchased the scanner.
Hope the above information is helpful.
Thanks & regards,
ScanCare
Jul 17, 2013 | Fujitsu fi-6770 Flatbed Scanner
Error e9 on fi 6770 means what?
Thanks & regards,
ScanCare
Image on screen is distorted but prints fine
Hi,Check the SCSI/USB interface cable is connected properly. If any temporary alarm or error is indicated, then follow these steps:1.Are the cables between Control PCA and optical unit damaged or connected properly?2. If the cable is OK, then either the Optical Unit or the Control PCA is faulty, replacing the faulty parts would resolve the issue.
regards,
ScanCare
Jul 21, 2011 | Fujitsu fi-6770 Flatbed Scanner
AN ERROR "F" AND "4"
Hi,This error is Background switchover alarm. Check the background change over mechanism drive and BW motor functioning or not? Cleaning the mechanism may resolve the issue.
regards,Scancare
Jan 12, 2011 | Fujitsu fi-6770 Flatbed Scanner
Fi-6130 not grabbing paper, displays Code: DS32002
My scanner is Fujitsu M4097D. I just have problem with ADF: Error Code DS32002: Paper jam in the ADF. Here is my solution: 1. Bend two white platin pieces down a little bit in order to "sensor" the paper scanned. This problem is occurred after I am scanning 50 thick pages. Until paper count 42, it is stopped with error code DS32002. Hope help anybody having this problem.
Jan 06, 2010 | Fujitsu ScanPartner fi-5120C Pass-Through...
pad PA03289-0003
May 29, 2008 | Fujitsu fi-5120C
Top Fujitsu Office Equipment & Supplies Experts
Chris Larocque
Are you a Fujitsu Office Equipment and Supply Expert? Answer questions, earn points and help others
