Question about Team International Best Bikes NFL Team Logo 20" BMX Bicycle, Choose Team
Hei homse
  • 2,039 Answers
Dont understand
Posted on Jul 31, 2009
1955 olds 88 hei ignition wiring to key and ignition system
Original system has a resistor wire between coil + and ignition key, to reduce voltage and thus increase amps to give fatter spark and increase fuel mileage. For HEI system, this resistor wire must not be used, so run new primary wire straight from switch "run" to coil +. There should already be a wire from the starter solenoid to the coil + to supply full 12 volts when cranking to give higher voltage spark to plugs to help jump the gap better for use while starting. The MSD web site has much more info.
Jul 05, 2016 | Cars & Trucks
I have a 72 chevelle with a 350 ci , I put an hei distrubitor in it but now my alt wont charge and its brand new what should I do...
The HEI has nothing to do with the alternator
The HEI needs battery voltage,not the resistor,
that was there for the point ignition distributor
Unless you moved wires around to feed the HEI,
you just diagnose the alternator as usual
New doesn't mean it works
Have to know how to test it
Sep 10, 2013 | 1986 Chevrolet C1500
WHAT IS HEI ?
GM has offered High Energy Ignition (HEI) systems on vehicles starting with selected '74 models. HEI was standard on '75 and newer vehicles.
Check HERE for additional details.
Hope this helps (remember to rating this answer).
Oct 10, 2011 | Cars & Trucks
Fireing order for 5.3 engine
Hi!!
Here are the two engine configurations WITH AND WITHOUT HEI SYSTEM, they both have the firing order 1-8-4-3-6-5-7-2 and the distributor ROTATES CLOCKWISE.
NO HEI SYSTEM
HEI SYSTEM
Good Luck!! A HELPFUL - 4 THUMBS - rating for this solution would be greatly appreciated. Thank you for using FixYa.
Mar 19, 2011 | Chevrolet Chevette Cars & Trucks
64 chevelle 327 starts periodically runs about 1-2 minutes & cuts off same thing while driving tuneup done new fuel filterstill does same
Is it equiped with hei distributor?Or points?The module could be the problem ,or the capacitor,if it is hei ignition.
Jul 27, 2010 | Chevrolet Malibu Cars & Trucks
What is the firing order for a 455 olds with hei
i am not shure i guess 18436572 turn like clockwise
Mar 07, 2010 | 1970 Oldsmobile 442
Late for everything...
Do you have any idea what ignition system it has, as there were 2 or 3 used in around those years on the AMC products. If it's the HEI system, I'd suspect (1) pickup coil in distributor, or (2) module in distributor. If it's not HEI, let us know and we can help further.
Nov 10, 2009 | 1983 AMC American Motors Eagle
460 points out hei in
I would run .044 to .052.
Oct 25, 2009 | Ford F-250 Cars & Trucks
Where do i connect the green wire on atachometer on a HEI gmc ignition w/the coil seperate from the distributor?
GM HEI
Either go to the TAC terminal on the distributor or to the C- terminal/wire, which is typically a brown wire.
Oct 15, 2009 | 1987 Chevrolet Suburban
Team International Best Bikes NFL Team Logo 20" BMX Bicycle, Choose Team Logo
97 people viewed this question
Top Team International Cycling Experts
Marvin
Marvin
Michial Gueffroy
Andrew Taylor
Andrew Taylor
Are you a Team International Cycling Expert? Answer questions, earn points and help others
