Question about Epson Stylus DX8400 All-In-One InkJet Printer
How do I print with my Epson Stylus RX680 from an IPad?
SOURCE: Epson Stylus C86 won't print
The ssc program doesn't work if your ink light is solid red.
Posted on May 01, 2008
  • 33 Answers
SOURCE: epson stylus pro 4800 print head problem
Are you getting a nozzle check at least?
Posted on May 14, 2008
Ajkill
  • 2035 Answers
SOURCE: white lines on printed photos Epson Stylus NX400
You need to clean the print head on the cartridges , please follow these steps\
# Hold the cartridge upside down, with the bar-code label facing you and take a damp paper towel.
# Use the towel to wipe the printhead of the cartridge on the bottom (where the ink comes out). Wipe the printhead horizontally in one direction only (left to right).
# Continue doing this until it looks clean.
# Then dab the cartridge on the towel to make sure the ink is flowing.
# Next, look inside the printer and locate the carrier that holds ink cartridges. Caution: Make sure the cartridges are not installed at this point.
1. Look for a shiny piece of metal underneath the contacts at the back of the carrier.
2. Take a damp cotton swab (use water only!) and wipe along the bottom of the shiny metal piece. Note: You may need more than one swab.
# Reinstall the cartridges, making sure you snap them correctly into the printer.
Posted on Mar 15, 2009
tigertail
  • 163 Answers
SOURCE: epson stylus C88 won t print color ink black is
If you have carried out 4 to 5 head cleans, waited about 8 hours and done another 3 or head cleans doing nozzle checks after each clean (as recommended by the manual) and there is still no improvement then you will need a third party head cleaning solution such as this one:
http://websites.uk-plc.net/UK_Inkjet_Cartridges_PLUS/products/Print_Head_Cleaner.htm
Other makes & brands are available just google "inkjet head cleaning solution" Hope this helps.
Posted on Apr 03, 2009
aicaxz
  • 511 Answers
SOURCE: epson stylus photo RX680 error message says;
Yes you're right. Use SSC service utility or RX680 Adjsument program. Find at indoreset.blogspot.com. Don't forget to replace waste ink pad, or just extend outlet pipe of head cleaning mech to outside.
Posted on Aug 28, 2009
Epson Stylus Photo RX680 - Started Printing, then it everything died. Will not power-up, no lights or display. Small red light on the interior blinks once when pressing the power button. What do I need...
It's more than likely that your internal power supply has failed, you would be wise to take it to a service center if it;s a high value printer, if it's not then buy a new printer.
Jan 16, 2014 | Epson Stylus RX680 Color All-in-One InkJet...
HOW TO CLEAN ROLLERS FOR EPSON RX680 PRINTER
Follow these steps to print the nozzle check:
  1. Make sure plain, letter-size paper is loaded in the sheet feeder.
  2. Make sure the CD/DVD tray is not inserted in the Epson Stylus and the CD/DVD guide is in the paper printing position.
  3. Press the Setup button.
  4. Press cp_button_41_er.gif or cp_button_42_er.gif to select Maintenance and press OK.
  5. Select Nozzle Check, then press OK.
  7. Press cp_button_6.gif Start to print the nozzle check.
Oct 28, 2010 | Epson Stylus RX680 Color All-in-One InkJet...
Epson RX680-How to print only in B+W
You can set it to "grayscale" and supposedly print only in black/grey.
However, Epson printers use a small amount of every color even when printing black only or greyscale (black). Your printer will still not work with one color tank empty.
http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?BV_UseBVCookie=yes&infoType=FAQ&oid=90584&prodoid=63069505&foid=95907
Here is how to set it:
Open the properties page for the RX680 and on the "Main" tab, click on [Advanced]. A Note may appear egarding incorrect settings.
Click [Continue]. Find the [ ] Grayscale box and check it, the [OK]
[OK], etc.
Here is Epson's note on using grayscale / colors:
http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?BV_UseBVCookie=yes&infoType=FAQ&oid=90584&prodoid=63069505&foid=95908
Sep 24, 2009 | Epson Stylus RX680 Color All-in-One InkJet...
What is specialty print on the epson rx680?
The Specialty Print service on the Epson RX680 allows you to restore colors in faded photos, correct poorly exposed photos, reduce redeye, and even crop while you copy photos.
Aug 29, 2009 | Epson Stylus RX680 Color All-in-One InkJet...
Printing lines across the picture
http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?BV_UseBVCookie=yes&infoType=Overview&oid=90584
Q: How can I tell if the computer or the printer is causing a print quality problem? A: You can print a nozzle check pattern to determine whether the print quality problem is caused by the Epson Stylus Photo RX680 Series or some other source.
Above under FAQ
Dec 10, 2008 | Epson Stylus RX680 Color All-in-One InkJet...
Epson Stylus DX8400 All-In-One InkJet Printer Logo
41 people viewed this question
Top Epson Office Equipment & Supplies Experts
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
