Question about Moen 7599C Medora Single-Handle Kitchen Faucet, with Pull-Out Spray Sp
Moen water flow stopped
Water flow stopped
    Problem Solver:
  • 5 Answers
I think it is dirt in the screens. There is a screen at the hand held end, however there usually screens at the intake conection under the sink.
Posted on Jul 05, 2014
I have a moen walden single handle faucet with side sprayer. Water volume is lessening. Had an issue when I first installed it. Hit water stopped. I flushed rubber bits from the supply lines. Was fine for...
Sounds like your washers on shut off valves are deteriorating causing the black bits etc. Try removing and cleaning the aerator at end of spout, bits will collect here and restrict flow as well. Moen has excellent customer service and lifetime replacement. call them if problem continues.
Mar 23, 2015 | Moen Plumbing
Moen faucet 7599c
Dont know the particular shower model but usually if one of the inlet filters is blocked it will automatically shut down for safety.
The filters are usually on the inlet connections directly on the mixer unit,do not forget to isolate the water supply first!
Wash out and replace
May 16, 2014 | Moen Home
Need more water flow on a moen haysfield kitchen faucet
have you tried checking to see if the screen is blocked. I installed one and that was the issue. it should just screw off right where the water comes out.
Mar 14, 2014 | Moen 87877SRS Haysfield Spot Resist One -...
Why did my moen faucet stop working? I have water flow throughout the house but the flow at the kitchen faucet just suddenly stopped!
Rubber gasket on the water shut off valve under the sink has come off and traveled up into the faucet. It's pretty difficult to get it out. If you have access to an air compressor you may get lucky by taking the faucet completely off the sink and blowing air back from the faucet outlet back into the internal piping to dislodge the rubber piece. If that doesn't work, or you can't use the air compressor method, then it's a trip to the hardware store for a new faucet.
Jan 11, 2010 | Moen 87530 Touch Control Single Handle...
I have a moen bathtub faucet with one handle. My problem is that when I rotate the handle to the hot side the water flow stops. How can i get hot water to flow?
you may have problem with your cartridge . you will have to pull it and take good look at it and look in the valve body to make sure no debri s is blocking the water port's
Dec 10, 2009 | Moen & One Handle Tub & Shower Faucet
The single handle fauchet will not stop running water.
Replace cartridge and insure that the C clip is not missing.
Sep 11, 2009 | Moen & Posi-Temp Single Handle Shower Or...
My Moen kitchen faucet stopped working suddenly in that only a thin stream of water would flow at most when I turned on the hot water handle or the cold water handle to the maximum positions. I replaced...
wow... I wish you hadn't gone thru the expense of replacing the faucet... it's perfectly good... your problem was the aerator, it unscrews at the tip of the water spout and had collected too much sediment which eventually blocked water flow. Often happens quickly after your water is shut off at the main valve. Aerators cost about 50 cents...
Aug 30, 2009 | Moen Chateau Loop-Handle Kitchen Faucet...
Water flow stops and starts
check PRV...Pressure reducing valve......Plugged ro broken.....
Apr 22, 2009 | Moen & Posi-Temp Single Handle Shower Or...
Not alot of hot water?
1st Check the temperature restricting coller behind the cover under the handle. It is used to restrict the flow of hot water to stop you from being scaulded.
2nd Those set screws will control the flow. Check to ensure both sides are open the same amount of turns. If the water pressure is good turn in the cold side.
Jan 08, 2009 | Moen 3175 Legend One Handle Shower Faucet...
Moen 7599C Medora Single-Handle Kitchen Faucet, with Pull-Out Spray Sp Logo
81 people viewed this question
Top Moen Hardware & Accessories Experts
fixzum
Level 1 Expert
Tom Chichester
Steve Mason
Are you a Moen Hardware and Accessory Expert? Answer questions, earn points and help others
