Question about Garden
Briggs and stratton lawn mower 282H07 15.5hp new carburettor no fuel going to engine
  • 86 Answers
SOURCE: Briggs & Stratton engine on Murray lawn mower
I always replace the air filter if its a paper element, and even if its a foam element I replace it rather than clean it. That said, engine stumbling is rarely and air flow problem - but it could be, so having a new filter assures no air restrictions.
I would drop the carbuerator bowl. On the bottom of the carb, near where the fuel line comes into the engine, should be a nut. Removing this nut allows the bowl to drop off the carb. Some engines the bowl screws off, you will have to look at the bowl. Often the bowl has sediment or sludge buildup inside. Cleaning the bottom of the bowl can prevent that sludge/sediment from plugging the intake tube. Even on newer mower models this is a common problem, the gas line tubing interior breaks down and the inside of the tubing can start degrading - ending up in the bowl as sludge.
After cleaning the bowl, I would add one ounce of fuel line cleaner to a full tank of fuel and run the entire tank of fuel. This will clean any deposits or "varnish" from the interior carb parts. Doing this and the first step will assure your carb is clean and functioning.
If that doesn't help, then I would look at the spacing between the magneto and coil assembly. If you want to do that I'd like you to write down all the model numbers and serial numbers on the engine nameplate, that way I can give you specific directions.
Hope this helps,
Gregg
Posted on Mar 29, 2009
jj505
  • 195 Answers
SOURCE: Have a Briggs & Stratton lawn mower engine, 4.5
Is Blade new or causeing vibration .Chge blade,
Please rate Thank you jj505
Posted on Mar 30, 2009
  • 7 Answers
SOURCE: is there an oil filter on a Briggs/Stratton riding lawn mower. Model#42A700
Yes there is a spin on oil filter. Depending on the date code when the motor was built there are two possibilities. The easiest way is to measure the length of the filter, If the filter is 2 1/4" long the Part Number is 492932.
If the filter is 3 1/4" long, the Part Number is 491056.
Posted on May 25, 2009
  • 166 Answers
SOURCE: Briggs & Stratton Quattro lawn mower
A lot of time when the small motors on these push mowers surge it is a governing spring that is weak or broke. It does not hold enough tension and causes the valve to fluctuate. I have fixed this many time for a relatively cheap amount (under $5).
Posted on Jun 16, 2009
  • 59 Answers
SOURCE: My lawn mower briggs & stratton engine 650 series will not start
check the fly wheel and coil it may have rust on it if so sand it off
Posted on Jun 26, 2009
Lawn Mower Surges
Check valves. Vacuum from the engine draws the fuel in...sounds like vacuum is surging. Also it may have a "fuel pump" that may be bad
Aug 24, 2016 | Briggs & Stratton Garden
Need to know where the fuel filter is located
FAQ: Fuel Filter Replacement ' Briggs & Stratton Engines
www.briggsandstratton.com/us/.../fuel-filter-replaceme...
Briggs & StrattonWith this Briggs & Stratton FAQ, you'll learn how a fuel filter works in small engines ...properly strain the gas before it reaches the carburetor in your lawn mower, snow ...and uneven operation; Clean filters conserve the amount of gas you need ... The fuel filter will be located either inside the fuel tank or fitted into the fuel line ...
Servicing the fuel filter - Briggs & Stratton
www.briggsandstratton.com > www > Support > FAQs
Briggs & StrattonIf you still need help, you can submit your question by clicking the Ask a Question tab.... Some filters are located inside the tank, others are fitted into the fuel line between the tank ... The size of the holes in the filter will determine the largest particles that can get through the filter, and the number of ... Lawn Mower Engines ...
Lawn Mower Engine Fuel Filter Installation - Briggs ...
Jan 01, 2016 | Garden
Wrong gas in lawn mower, what to do
if its a briggs and stratton engine with the plastic carb fixed to top of the fuel tank then you will need to replace the diaphragm and blow out the fuel pick up pipe
Jun 26, 2014 | Briggs & Stratton Briggs Stratton...
Engine RPMs keep going up and down, not a steady engine speed.
By your description, you have a Briggs & Stratton carb-on-the-tank engine?
Replace the carburettor diaphragm. It's either holed or work-hardened. Costs pennies.
May 12, 2010 | Mg International MasterCut 20" 123cc Push...
I have an old Briggs and Stratton engine 16hpv. I
I am trying to find you a spring..i have a bunch of old stuff out back. give me a couple days. It holds the diaphram steady to prevent chattering of the rubber while fuel is flowing...:)also what year is your briggs and model?
Sep 07, 2009 | Garden
Garden Logo
29 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
