Question about Blenders
How do I replace the knife unit in a krups type 243 blender?
  • Blenders Master
  • 1,316 Answers
Take the blade assembly out of the jug, hold the blades with a towel and turn the driving clutch on the other end. Whichever way the motor turns those blades when operating, you need to turn the drive the opposite way to undo it. If the nut is seized up and wrecks the drive the parts list shows all parts as being available EXCEPT the white bearing housing AND the complete assembled blade and housing.
Posted on May 24, 2014
5 Suggested Answers
  • 79 Answers
SOURCE: Krups 243 blender clutch wheel
These little jewels are threaded onto the motor shaft so they tighten up when in operation. To remove, you will have to immobilize the motor shaft. See if you can insert an icepick or screwdriver into the blades of the motor fan on the bottom. Then using a punch and hammer, gently tap the clutch disk in the direction opposite from its normal rotation.
BE CAREFUL not to use so much force that you break either the clutch disk or the motor fan blade.
Posted on Mar 15, 2008
SOURCE: Krups blender drive gear
Ed,
The problem I had was removing the grey rubber drive. The solution is that it screws off not pops off. The trick is to use narrow needle nose pliers to grab the post that attaches to the motor and turn the rubber drive counter clockwise. Removing the motor becomes easy. Pull out the 4 rubber feet under the base and the screws will be exposed. However my situation was the grey drive gear was stripped and would bottom out. My solution was to use a same size lock washer as the washer between the post and the drive. So far so good! If it fails I will need to buy another grey drive. Myron
Posted on Feb 01, 2009
SOURCE: Krups 239 blender drive gear.
Like you, I am all for repairing and keeping the world free of blenders that only need one part replaced. The rubber coupling was easily ordered online, the challenge I later found was to remove it without losing my sanity. After messing up the side grill of the blender pretty good, I realized there is an opening on the motor casing that allows access to a "gear" that is firmly attached to the axle where our little friend will hopefully screw on and restore the contraption to a working state. In order for you to see (which I must warn you, it's not much of a view) through the grill you will need a flashlight or book light. Towards the top of the aforementioned gear (not the rubber part) there is a groove in which a flat screwdriver can easily fit immobilizing the axle and allowing you to easily unscrew it. Oh, but wait, I forgot this is the faulty part and it will spin without the slightest torque on the axle thus never loosening or getting it unscrewed. My solution to this problem was to surgically remove as much rubber as possible to allow me to attach my vise grip to the nut and finally put this thing out of its misery. Using the same procedure of inserting the screwdriver to immobilize the axle I was able to screw the new part and voila the blender is fixed!!!!
Posted on Aug 11, 2010
  • 31 Answers
SOURCE: I bought a krups blender
Matt's Appliance repair in Escondido
743 East Valley Parkway Escondido, CA 92025-3089 (760) 745-7711
Posted on Mar 02, 2011
What year was the Krups 243 Blender manufactured?
Sorry we do not have that kind of info here at this website.
May 10, 2018 | Krups Blenders
I need 0914084 Blender Sealing Ring Diameter 2 1/16"or its substitute.
Unfortunately that gasket, part number MS-0914084, has been discontinued.
Here is a link to the part online: Seal MS 0914084 for Krups Appliance eReplacement Parts
Unfortunately the gasket is obsolete, and there are no known replacements. The gasket is very perticular and i do not know of any other gaskets that have a similar shape.
-Colleen@MendingShed
Apr 02, 2015 | Krups 572 Power Xtreme VI Work Top Blender
Hello, I ordered a replacement coupling gear(?) and need to figure out how to replace it. This is the little grey plastic gear that attaches to the base unit causing the blade to spin. Here are some...
Hope you have solved your problem by now, but put a flathead screw driver in the bottom of the blender to hold the blender shaft in place then turn the gear by hand or with a plyers and it should just screw off, it is reverse threaded...
Jul 14, 2011 | Krups GMA1-42 Power Xtreme VI Work Top...
I have a krups 574 blender. The male part of the
I carved off the rubber with a knife; inserted a flathead screwdriver throught the slot in the bottom to hold the gear in place; using pliers I unscrewed (COUNTERCLOCKWISE) the rubber gear.
Mar 28, 2009 | Krups 574 Power Xtreme VI Premium Work Top...
Krups Type Blender 577
Mine did the same thing. I am ordering a new one from America for around $5.
http://www.abtecparts.com/index.htm
I am in Australia and they deliver worldwide.
Caz
Jun 12, 2008 | Krups 572 Power Xtreme VI Work Top Blender
Mar 12, 2008 | Blenders
How to replace the rubber drive in Krups 572?
it's not easy. you will need a set of pliers, a flathead screwdriver, and a phillips screwdriver. first, remove the 4 rubber plugs from the bottom of the blender (just work them out with your fingers). second, use the phillips screwdriver to unscrew the 4 screws that were under the ruber plugs. the blender should come apart. right in the bottom center on the inside of the blender you should see a steel rod with a groove in it. this rod will run all the way to the top and be connected to the rubber gear drive on top. get a firm grip on the rubber gear drive with your pliers. place the flathead screwdriver into the groove of the steel rod and unscrew. it will be very tight, but eventually, it will give. you will most likely destroy the old rubber gear drive in the process, but the idea is to replace that one anyway. good luck!
Q. Mosley
Jun 09, 2007 | Krups 572 Power Xtreme VI Work Top Blender
Blenders Logo
101 people viewed this question
Top Blenders Experts
eyecam
Ross Keen
Are you a Blender Expert? Answer questions, earn points and help others
