Question about Lite On LVW-5005 DVD Recorder
How can I record a disk by attaching a VHS recorder to the 5005?
Where do I attach the wires to each bosx and what mode do I record on?
proton77
  • 1183 Answers
SOURCE: model 5005 have used successfull
There can be two points of failure, one the software that controls the DVD player working also called a firmware , second the DVD laser inside the unit.
If you could give us the error code that is displayed on the panel in front it would help.
Also have you tested normal audio cd or a VCD in the system rather than a DVD , if it plays the same.
Thanks
Proton
Posted on Oct 17, 2008
leecom72
  • 4806 Answers
SOURCE: i need a replacement control
http://stores.ebay.co.uk/GenuineCopies_LiteOn_W0QQcolZ4QQdirZ1QQfsubZ7243871QQftidZ2QQtZkm
you will find the original remotes here
hope this hepls
and please will you rate us, regards
Posted on Nov 28, 2008
  • 39 Answers
SOURCE: i have a liteon 5005 dvd recorder and it tells me
you must use the proper recording disc for formatting compatability of your unit. i.e. r+/r- confer with owner manual for recommended discs mch
Posted on Mar 09, 2009
I have same problem like you, i replace it to a new Lite-On DH-20A4P, it work perfectly, good as new.
Posted on Aug 12, 2009
SOURCE: Lite-0n LVC-9016G DVD / VHS recorder will not recognize any type of blank recordable DVD's! Suggestions?
I have the same issue. Did you find a solution?
Posted on Jan 13, 2012
How do I attach a combination VHS recorder/DVD player to my new Sceptre 19
The best way of connecting is an HDMI cable if both have this. If both have SCART then use a SCART cable. Using the RGB input is really old skool, you will need to use the TV controls to select that input because it won't select itself.
Dec 29, 2014 | Sceptre Televison & Video
TV/VCR Recording of TV Programs Using a Digital Converter Box
Hi Rick
I think you are painting yourself into a corner. So to Speak.
Why buy a SetTop Box to convert to an old VHS Tape when you can buy a Digital Recorder for probably the same price.
The modern way to Record video is to use a Hard Disk Drive Recorder rather than a VCR. They have a built in tuner and can record 2 stations at once and have a built in Electronic Program Guide. The EPG info is transmitted with the Digital TV transmission from the broadcaster.
I bought one 2 weeks ago for an old 85yo friend so he could record late night stuff and play back later. He still uses the VCR but only for old VHS Tape playback. It was a TEAC HDR9650TS Digital Video Recorder and I picked it up new for Aus$188.
Here are the unit features
  1. Main Features:
    DVB-T Twin Digital Turners
    DVR Recording: Record three channels while watching a 4th from same network Smart Series Record feature to record a whole series at a touch of a button
    2.5" Sata Hard disk: 500GB
    Time Shift Function (Pause live TV)
    HDMI Digital Output
    Digital Audio Output
    CVBS/YPbPr/SPDIF connectors
    Supports TV formats 4:3 and 16:9
    Electronic Program Guide (EPG) up to 7 days in advance
    EPG searching and auto download
    Recorded program edit
    Parental Control
    Copy files from internal HDD to external HDD
    Built-in WiFi
    Network Playback
    USB 2.0 Interface
Now
This was my original reply until I saw the light.
So, Hopefully one of these will answer your queerie.
A digital TV picks up the new Digital Transmission and stores it in memory, then supplies the high definition to the input of your TV.
With a STB, once the digital broadcast signal is captured by the Set Top Box tuner, it is stored in memory and then it is converted to Video Format and comes out of the back connectors as a standard video & audio signal on the Red & White (Audio) & Yellow (Video) as a composite signal that can also be attached to an older VCR tape recorder.
If the STB output connectors have a Red White & Yellow RCA plugs then it is all ready to be picked up by an older TV or VCR.
Most set top boxes also have HDMI Output for high definition video & sound in the one cable, which attaches directly to the back of your TV (assuming it doesn't already have a tuner (STB) already built in).
HDMI is the state of the art cabling for modern devices. But probably not on the old VCR.
It will either use Component, Composite or SVideo cables. Match one of these cable standards up with your VCR.
Cheers.... Trevor
Was this Helpful
.......Then give me a tick of approval
Aug 18, 2014 | Panasonic PV-V4022 VHS VCR
Want to record VHS to DVD on my Toshiba DVR620KU but do not want to connect to my TV set. Is this possible? My TV is older and does not have the input/output jacks. I just want to put in a VHS tape and a...
If the entire VHS is full then you can easily transfer the VHS contents to the DVD. The video will play while it is recording onto the DVD, but you don't have to have it hooked up to any TV for it to record. Now if you don't know how long the VHS content is that you want to record to DVD, then you will have to hook up the player to a TV so that you can press stop when you reach the end of the content you want recorded. At least this is true in the way that I use to transfer VHS to DVD:
1) Turn on the unit
2) Insert VHS tape
3) Insert DVD-+R or DVD-+ RW
4) Using remote, press VCR
5)Using remote, press play then pause the tape where you want to start recording.
6)Using remote, press DVD
7) Using the remote, press DUBBING. The VHS should start to play and the DVD should start recording
When using this method, don't hit the RECORD button!
I hope this helps!
Sep 05, 2011 | Toshiba DVR620 DVD Recorder/VCR
Trying to record from a VHS. Recorder copies whatever is broadcasting not the VHS
you need to set the recorder to record the input you have attached the VHS to (input 1 or input 2)
right now it sounds like you have it set to a channel number
if you need more help send me more details and i can try to help more
Good luck
Mar 13, 2011 | Televison & Video
I would like to know if it is possible to copy two vhs movies onto one dvd disk.
Yes, this should be possible, as long as the VHS movies are not copyright protected. Just make sure that the recording mode on the dvd is set to allow enough time for both movies. Just remember: the more you record onto a single disc, the quality of the dubbing (recording of VHS to DVD) is decreased.
Sep 09, 2010 | Philips Magnavox MWR20V6 DVD Recorder/VCR
How do I record my vhs tapes to Disk
I have done a lot of dubbing on my machine. First make sure the DVD is formatted. When you put in a new disc it should ask you if you want to initialize. Once that is done, switch to VCR mode. push play on the VCR then push the DUB button on the front of the machine. I hope it helps.
Mar 02, 2009 | Insignia IS-DVD1001 DVD Recorder/VCR
Can't find manual..need to record FROM vhs to dvd. Any easy way?
Put it on VHS mode put the DVD in still on VHS then on the remote push DUBBING.
Jan 18, 2009 | Sansui VRDVD5000 DVD Recorder/VCR
LG vs Lite On
both are just the same features just to write file from your hard drive. Maybe your point is you want the video from your VHS tapes will transfer to your hard drive. The only way to copy the video from your VHS is you need an external VHS player at the same time it will record the running video to a soft copy.
Please check this maybe this will be helpful http://www.allformp3.com/dvd-copy-software/convert-vhs-to-dvd.htm
Please rate me solve if you like my solution.
Best regards,
Philip
Oct 31, 2007 | Lite On (ldw811s) DVD±RW Burner
Lite On LVW-5005 DVD Recorder Logo
Top Lite On Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Lite On Televison and Video Expert? Answer questions, earn points and help others
