Question about Cub Cadet Garden
Need to know the pitch 8m for pto clutch
Model # 144-653-100
  • 32 Answers
If your talking about the bolt that goes through the center of the pulley your model number shows it as a 3/8-24x1.75 long. everything I see on the pto is standard not metric. this link will show you the pto breakdown for your model
Parts and Diagrams for Cub Cadet 144 653 100
Posted on May 17, 2014
2 Suggested Answers
heatman101
  • 43501 Answers
SOURCE: I have a cub cadet RZT 50 mower deck and my
The problem is the clutch it's self... it is slipping and when it gets too hot it just quits...
The clutch will need to be replaced and that often is not a fun job. You also should have specialty tools to do the job, as they are very hard to get off the shaft many times... the same heat that stops the clutch, almost welds it too the shaft...using heat to free it therefore does not work like it normally would.
Just for giggles a grins, check for power to the clutch after is stops...I think you will find that it is still getting power to it, it just is not engaging or staying engaged anymore...
heatman101
Posted on Jul 14, 2011
What are the two wires on the PTO for?
John, the wires put power to the PTO to energize clutch and make it engage when switched on. I will post a video link of simple fix for wire that have been ripped out.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How To Repair Ripped Out Wires On An Electrical PTO Blade Clutch
lawn tractor pto wire Google Search
Troubleshoot Replace mower PTO CLUTCH
Broken PTO clutch wire JD717A
Apr 22, 2016 | Garden
I NEED THE LOCATION TO ATTACH THE PTO CLUTCH SPRING.
need to know what mower exactly
Jul 29, 2015 | Garden
Ariens model 915111. Blades will not engage. Using a light voltage device. I placed the probe inside the socket which was connected to the pto clutch and it lit up. Can you tell me what part needs
If your receiving power at the PTO clutch and it is the correct voltage ie. 12vdc then you will need a new PTO clutch assembly.
Oct 28, 2014 | Garden
How do you know if it is the switch or the clutch when the blades are not engaging?
if no voltage at pto then go to switch if no voltage there check fuse if power there replace switch if voltage at at pto replace clutch switch cost 60.00 pto 200.00
Sep 01, 2014 | Garden
On a rzt 42. The pto clutch bolt loosens and clutch falls off with use of 10 minutes or less. How do I fix?
The PTO clutch has a bolt that goes through it and into the vertical shaft of the engine. MANY of the PTO clutches have a large spacing washer that goes on before the PTO clutch is slipped onto the shaft. If the washer was lost when the clutch was changed, the bolt might be bottoming out in the shaft rather than tightening on the threads like it should. I'd get a diagram for your model and make sure all parts are in place.
Jun 05, 2014 | Cub Cadet RZT S Series
My cub cadet tractor starts but the pto clutch stays engeged and i cant shut it off(pto)
The clutch has it's own brearings in it. You have to replace the hole PTO.Sometimes you can find a Aftermarket PTO clutch. There usually A little cheaper.
Jul 10, 2012 | Cub Cadet Lawn Mower Electric PTO Clutch...
NO power to pto craftsman gt 5000
could be a clutch switch look at sears parts online for the location
Apr 01, 2012 | Garden
I have a Craftsman lawn tractor model 917.288030. When you turn key to start nothing happens. Battery is ok. I have replaced ign switch. I have swaped selenoid with known good one. I have swaped out impact...
Hi and welcome to FixYa. I am Kelly.
Here are the 3 safety switches.
Seat
Clutch Brake
and PTO Clutch
More ofthen than not the PTO Clutch gets a gap greater than 0.020 between the clutch and the clutch plate and the safety switch is not made. There are 3 bolts with springs and 3 slots in the PTO clutch. Adjust the tension on the springs until the gap is 0.020. Then try a start.
If it does not work:
Check out this diagram.. it is for your mower:
http://c.searspartsdirect.com/lis_png/PLDM/P0905008-00011.png
I found your particular model here: http://www.searspartsdirect.com/partsdirect/part-model/Craftsman-Parts/Riding-mower-tractor-Parts/Model-917288030/0247/1509200/P0905008/00011?blt=06&prst=0&shdMod=917288030
Parts can be located by choosing the diagrams under the small schematic. I think if you adjust the clutch you will be fine. The seat has to be occupied / switch shorted and the clutch brake pedal made to get power to the solenoid.
Respond ehre is you need more help.... Better yet let me know if the PTO clutch adjustment corrected the problem.
Thanks for choosing FixYa,
Kelly
Jun 05, 2011 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
I need to know where the fuse is located
Hi and welcome to FixYa, I am Kelly.
Look inside the cowl on the same plane as the clutch / brake pedals. There should be a rectangular fuse recepticle with a 20 Amp plug in fuse. Just look up and down inside the cowling using the clutch / brake pedal as a reference point to start searching, You will find it. If the fuse keeps failing you will have to start chasing clutch / brake switch wires, PTO clutch wires, and Seat switch wires. Most of the time the failures are at or near the switches. As for the PTO clutch... belts over time slap the wires of the PTO clutch and either chafe the wires or break them at the PTO clutch.
Engine overspeed on this model also causes the engine alternator to fail the fuse.
Kelly
Apr 28, 2011 | Husqvarna Riding Lawn Mower Yth24v48ls 48...
Mower pto engages when initially started but after
the coil in the electric PTO shorts out when it expands by heat causing it to lose it's magnetic pull and disengages- I hate to say it,but you need a new PTO clutch.
May 07, 2009 | Garden
Garden Logo
54 people viewed this question
Top Cub Cadet Garden Experts
Tim Whalen
Matt Olenzek
Matt Olenzek
dannydoesita
Are you a Cub Cadet Garden Expert? Answer questions, earn points and help others
