Question about Samsung Washing Machines
Black rubbery substances in drum after washing
    Scholar:
  • 73 Answers
Sounds like the rubber cushions that keep the agitator in place have deteriorated. They're under the top and exposed pretty easy
Posted on May 16, 2014
2 Suggested Answers
SOURCE: Noisy Dryer Drum - Squealing/Grinding type Noise.
I have a Kenmore Stacked Washer/Dryer (Model 417.91702000) that has had the same thing happen. I have replace mine twice . . .It is the rear dryer bearing.
You can purchase a kit that contains everything to replace it.
You have to work from the front, all the way to the back.
Make sure that you also check the felt pad glide on the front door panel (the drum rotates on this). You may need to replace it also, it should have teflon pads built into the felt that the drum rests on . . .
Posted on Jan 21, 2008
Where to clean filters on Samsung 13kg top loader?
Sounds like you need to have your machine looked at by a professional. You should not be finding rubber pieces in the machine.
May 08, 2014 | Washing Machines
Rubbery shavings in drum of wft7016pp top loader after every wash
Possible that an inspection on the door seals must confirm this case as it could be worn out or is out of alignment.
Check the drum and door seals to confirm. If so replace the gaskets.
click this link : gasket
Jan 14, 2013 | LG Washing Machines
Dirt like substance coming out from the washine during wash cycle
Possible that there is dirt in the drum that comes up when the drum revolves. This can be due to dirt that had accumulated within and needs to be removed. Please try to watch this link and get some tips to clean the drum.
click on : cleaning the drain
Jan 01, 2013 | Washing Machines
I have an LG washing machine Model WM1814CW. It makes a loud clanking sound in the spin cycle and the back of the drum has a thick black greasy substance on it & has leaked onto the floor. What could...
Thanks for choosing FixYa and welcome to the site. It sounds like it is your spin bearings. It would explain the grease and the noise also. The spin bearings have to do with the spinning of the washer. Usually, if there are loud noises associated with the washer, it is either the motor drive or the spin bearing.
Apr 22, 2011 | LG WM2432CW Front Load Washing Machine
Frigidaire GLTF530DS Front Load Washer washes but will not drain water or spin dry? Water will drain from the drain hose into a bucket. Help
you probably have a coin or button stuck in the small motor inpellor that helps push the water out when rinse is done. its located under drum of washer should be a black rubbery hose leading from drum to small motor. its a pain to clear it but that was the problem mine had and there was change in it messing up the motor
Mar 15, 2010 | Frigidaire GLTF530DS Front Load Washer
Does my belt need replaced?
If it is greasy and not oily, the belt will need to be replaced, there is slight possibility that the bearing seal under drum is leaking oil,
Jul 09, 2009 | Washing Machines
I took the back panel off my front loader washer, then un hooked the hose it was good okay, the black rubbery thingy i squeezed it and there is something inside it can you tell me what is that rubbery...
The filter lies inside the big black hose, you can get it by unscrewing the top clamp. Clean out all the coins, hair, whatever evil and refit filter as you found it. You can disconnect other hoses with a grip plier to have better access. If you have difficulty in re-fixing with the spring clips you can refit with jubilee worm drive clips, any hardware store.
Apr 13, 2009 | Frigidaire ATF6000ES Front Load Washer
GE Profile Dryer will Not Spin
I opened the dryer panel and saw that one of the two belts that stabilize the drum had come off. It is a soft, sticky, rubbery substance and part of it and balled up so it was wedged between the drum and the dryer wall. I cut that portion off and it runs fine now.
Dec 07, 2008 | GE Profile Harmony DPGT750EC Electric...
okay this is a stack unit, what you have is a rear bearing problem, This will also cause your tub to lean. it is located in the back, to make your unit right go ahead and buy the rear bearing, it will come with a white coupler, bearing and you will need to lubricate it....
also for a couple of more dollars order you the front seal, this is the white felt that surrounds the door...
1. top felt
2. bottom felt.
thanks
Apr 02, 2008 | Dryers
Jan 21, 2008 | Kenmore 98702 Stacked Washer/Dryer
Washing Machines Logo
21 people viewed this question
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
