Question about Asko T761 Electric Dryer
High limit thermostat
Had to reset the switch on the rear of the unit. A few times, just turned off the dryer, turned back on, and was operation usually until the clothes were dry. Now the unit does not turn on. No display.
  • Asko Master
  • 3,278 Answers
A year ago, I needed to replace a high limit thermostat, and I received ( for the money) both the high and the low!. I replaced the high therm., and a month later, the low one went out. I discovered these need to be replaced as a pair only.
Be blessed.
Posted on Jun 27, 2014
5 Suggested Answers
  • 37 Answers
SOURCE: My Asko dryer does not dry clothes. It shuts off
It is quite common for lint to cover the blower on these units, making it impossible for the dryer to move any air.
1)remove the lower panel. you will need a T20 driver for this and may need to tip the dryer slightly to the rear
2)remove the left part of the blower plenum. this is held by 3 plastic tabs and a T15 screw
You will now see the blower wheel, it is a squirrel cage type. Check for lint buildup, broken vanes, or string/thread wrapped around the shaft.
if there is no problem with the blower then there is another reason you are not moving air. let me know if this helps
Posted on Sep 02, 2009
SOURCE: Asko 760 Dryer - Just quit with no power to digital control panel
There's a chance that the over heat protection breaker was tripped. You may want to try pressing the black button in the middle of the back panel. That should reset it, then check to make sure the exhaust vent is clean.
Good luck
Posted on Jul 29, 2010
Macmarkus
  • 2605 Answers
SOURCE: When drying a load of
Hello Susan, Welcome to FixYa. Have you checked to see if perhaps one or both of the fuses may have blown at the back of the unit...I don't mean the hi-limit that you already referred to...I mean the in-line fuses the Asko machines are equipped with. Let me know and we can move forward from here. Regards, Macmarkus :)
Posted on Sep 19, 2010
FaceTheFacts
  • 245 Answers
SOURCE: installed a new automatic reset thermostat unit and asko t731 dryer still shuts off before finished
You probably have a clogged exhaust vent.
Posted on Feb 15, 2012
Problem with LER3624EQ1 Dryer. I have replaced the high limit switch twice and the thermostat. The dryer will run with hot air for a few minutes and then back to cold air with a new high limit switch. I...
The first thing you need is a multimeter, get one at Walmart you don't need a expensive one and the an be used for a lot of things around the house, pull wires off heater turn meter to ohms check between frame of dryer and each terminal it should show nothing if you are showing anything on the meter get a new heater
Aug 13, 2017 | Dryers
How do i change the high limit thermostat on a kenmore dryer # 72822
Unplug the dryer from the electrical outlet. Slide the dryer out from the wall and disconnect the dryer vent from the back of the dryer. Loosen the retaining screw on the clamp connecting the vent to the dryer's exhaust port and slide the vent off of the port.
Remove the hex nuts holding the dryer's rear panel in place and slide the rear panel off to the side of the dryer. Locate the high-limit thermostat on the heating element housing on the right side of the dryer. The oval-shaped thermostat can be found a few inches from the bottom of the heating element housing.
Unplug the two thermostat wires by sliding them off of the thermostat's contact posts. Slide the old thermostat out of the socket on the heating element housing.
Mar 12, 2011 | Kenmore 72822Gas Dryer
LER4634EQO Whirlpool Heavy Duty Extra Large Capacity 4 cycle 3 temptures My dryer is not heating. I have checked the breaker(s). There is not much lint around the dryer in the back or the vent, what...
The problem is likely in the thermal cut-off (cut-out) and the high-limit thermostat located on the heating element housing. Verify this condition by bypassing the said components. Disconnect power then remove the rear access panel to access the thermal cut-off (cut-out) and the high-limit thermostat. Disconnect the wires of each component then connect them together and insulate it properly. Reconnect power then start the dryer. The problem is indeed in the thermal cut-off (cut-out) and the high-limit thermostat if the dryer heats up. Replace both parts and it should solve the problem. It is an easy and cheap repair to make.
The
thermal cut-off (cut-out) and high-limit thermostat are sold as a kit with part number 279816 and costs about $30.
In case the dryer still doesn't heat up with the
thermal cut-off (cut-out) and high-limit thermostat bypassed, bypass the cycling thermostat then replace it if the dryer heats up. Check the heating element for broken coils if the dryer still doesn't heat up with the three components mentioned above bypassed.
Feb 10, 2011 | Whirlpool LER4634J Electric Dryer
I have a thin twin stacking whirlpool washer/dryer. The high limit switch is kicking off the element within 2 mins of running. So heating element heats up red hot, then clicks off after 2 mins. I have...
I think you are on the right track with a faulty high limit switch. When i serviced these units we always replaced the operating thermostat and the high limit switch together they came in a kit. The operating thermostat in theory should never let it get hot enough to trip the high limit switch, which is really just a safety backup for the operating thermostat. Get the kit and replace both, and also make sure your exhaust vent going outside has good flow at the outside vent,a restricted vent system will cause similar issues.. Good Luck
Oct 07, 2010 | Whirlpool LTE6234D Top Load Stacked...
The high limit thermal switch on heater burns out.
There are two thermostats, a 'limit' or 'operating' thermostat which turns the heating element on and off, and a 'high limit' or 'safety' thermostat which oversees the 'operating' thermostat by opening and removing power to the heating element when the upper limit temperature is reached. Basically, the only difference between these two are the temperature ratings. The 'high limit' is higher than the 'operating' thermostat. The thermal fuse is the last resort protection.
First and foremost, you must know that every inch of your exhaust vent pipe is clean.
Usually, a bimetallic limit switch will degenerate in the direction of too low of a temperature range because as the parts wear out inside, the mechanical tolerance widens (the tiny rod that pushes the contacts together gets shorter).
The high limit thermostat is by the thermal fuse. The operating thermostat is in the blower housing.
Check the fan impeller for broken vanes and lint. The impeller is directly coupled to the motor and should not turn without the motor. The fan housing and ducting should be free of excess lint.
Good luck.
May 02, 2010 | Samsung DV316LES Electric Dryer
Dryer overheats - need to replace thermostat?
The location of the heat sensor is mounted in a poor location on these models. Many complaints of this model has been seen in the past. I would replace it now for its is past ten years old. Just a recomendation
Jan 31, 2010 | Dryers
My dryer blows no hot air
HI
THE DRYER HEATER OPERATES ON 240VOLTS. CHECK TO BE SURE YOU HAVE 240 VOLTS AT THE OUTLET. WITH ONLY ONE SIDE OF THE CIRCUIT, THE MOTOR WILL RUN ON 120 VOLTS, BUT THE HEAT CIRCUIT WILL NOT.
MOST DRYERS HAVE A HIGH LIMIT THERMOSTAT NEAR THE HEATER ASSEMBLY. SOME HAVE A THERMAL FUSE AS WELL. THE HIGH LIMIT WILL CYCLE, BUT THE THERMAL FUSE WILL NOT RESET. CHECK FOR 240 VOLTS AT THE HEATER TERMINALS. IF YOU HAVE IT, THE HEATER IS BAD.
IF NOT, TRACE BACK THROUGH THE CIRCUIT UNTIL YOU FIND THE COMPONENT WITH THE 240 VOLTS ACROSS IT.
THAT WILL BE THE BAD COMPONENT.
MAKE SURE THE SELECTOR SWITCH IS SET FOR HEAT.
OITHER ITEM IN THE HEAT CIRCUIT:
CYCLING THERMOSTAT, TIMER, SELECTOR SWITCH, MOTOR CENTRIFUGAL SWITCH.
THANKS FOR CONTACTING FIXYA.COM
Sep 11, 2009 | Whirlpool Dryers
Dryer squeak and back panel is hot? Frigidaire Dryer FDE436RES1
It sounds like you have a rear bearing bad.
as far as over heating check the vent line. Your thermostats are ok or your high limit would blow and you would have no heat.
Sep 01, 2009 | GE DBXR463EDWW Electric Dryer
Hot point model nvl333eyoww will ot dry clothes
your dryer has a belt switch go here to see it www.repairclinic.com once there enter your model # and it will show you your parts
Mar 10, 2009 | Hotpoint NVL333EY Electric Dryer
Asko T761 Electric Dryer Logo
Top Asko Dryers Experts
Tim Whalen
Craig Butler
Craig Butler
Are you an Asko Dryer Expert? Answer questions, earn points and help others
