Question about Apple iPod nano
Ipod restore problems
How can i restore my IPOD nano? It suddenly lost it's picture (went flashing- blurry gray) and now won't play other than static
  • 641 Answers
Restoring iPod to factory settings Learn how to restore iPod, iPod classic, iPod mini, and iPod nano to factory settings.
Background
It's important to understand the difference between updating and restoring. Updating simply installs the software that controls iPod and does not affect the songs and files stored on iPod's disk. Restoring erases the iPod's disk and restores iPod to its original factory condition.
Warning: Because restoring erases all the songs and files on iPod, back up any files you've saved on the iPod disk. All of your songs, videos, podcasts, audiobooks, and games can be loaded back to your iPod provided that you have them stored in your iTunes Library. If you use the Nike + iPod Sport Kit, see this document for more information.
Note: See this article if you need to restore an iPod shuffle.
How to restore iPod
  1. Verify that you have an active Internet connection, because you may need to download new versions of the iTunes and iPod Software.
  2. Download and install the latest version of iTunes if necessary.
  3. Open iTunes. Connect your iPod to your computer using the USB or FireWire cable that came with your iPod.
  4. After a few moments, your iPod will appear in the Source panel in iTunes.
  5. Select your iPod in the Source panel. You will see information about your iPod appear in the Summary tab of the main iTunes window.
  6. Click Restore.
  7. If you are using a Mac, you will be asked to enter an administrator's name and password.
  8. A progress bar will appear on the computer screen, indicating that stage one of the restore process has begun. When this stage is done, iTunes will present one of two messages with instructions specific to the iPod model you are restoring.
    • Disconnect iPod and connect it to iPod Power Adapter (typically applies to older iPod models).
    • Leave iPod connected to computer to complete restore (typically applies newer iPod models).
  9. During stage two of the restore process, the iPod displays an Apple logo as well as a progress bar at the bottom of the display. It is critical that the iPod remain connected to the computer or iPod power adapter during this stage.
    Note: The progress bar may be difficult to see, because the backlight on the iPod display may be off.
  10. After stage two of the restore process is complete, the iTunes Setup Assistant window will appear. It will ask you to name your iPod and choose your syncing preferences, as it did when you connected your iPod for the first time.
Posted on May 16, 2014
  • 31 Answers
SOURCE: Frozen iPod nano
try to put the ipod into disk mode, while connected to PC, perform first hard reset by holding select and menu buttons until it restarts, when quickly change to pressing select and play buttons, then it must go into disk mode, will sync with PC and must show in iTunes, perform restore function to reformat the memory
Posted on Aug 20, 2007
  • 317 Answers
SOURCE: apple ipod nano wont play the full song
First make sure your hold switch isn't on. It's on the top or bottom and slides back and forth. It needs to be switched to the left. Once it is to the left, here's how you reset:
You can reset your ipod by holding down the menu and select (round button in the center) buttons down for at least 10 seconds. You'll see an apple logo flash, that's when you stop pressing the buttons. It will shut off, then back on.
Posted on Jan 09, 2008
SOURCE: iPod Nano problem
display screen is messed up what can i do to fix this problem?
Posted on Mar 04, 2008
  • 13433 Answers
SOURCE: 8 GB Ipod Nano went dead and now won't charge
does it work on the charger? if not, then contact apple or your dealer for more assistance or repairs.
If it works on the charger, plays music and so on, your battery is probably dead and you need a new one.
Posted on Mar 25, 2008
SOURCE: IPOD music list gray in ITUNES
Make sure that MANUALLY MANAGE MUSIC AND VIDEOS is checked.
You'll find it when you click your iPods name.
Posted on Nov 25, 2008
Ipod Nano 8gb won´t synchronize
Try this.
  1. Put the iPod into disk mode by holding the menu and middle keys together until the screen turns dark.
  2. Then quickly hold both he middle button and play/pause buttons until the iPod shows a check mark and the words disk mode at the top.
  3. ThenClick on iTunes to open it.
  4. Connect the iPod to the computer. You may have to do a restore depending on what iTunes says you need to do.
If this doesn't work, check the bottom of the ipod where you connect the cable. See if there are any bent pins. These are very fragile and can be damaged if you insert or pull the cable out the wrong way. Hope that helps.
Dec 19, 2008 | Apple iPod nano
Apple ipod nano stuck not working nor responding
The 5 R's for Apple iPods – www.apple.com/support
These are for Nano, but they apply to all iPods:
Reset, Retry, Restart, Reinstall, Restore
Remember these five basic suggestions if you have a problem with your iPod Nano. If one of the following doesn’t help, read on for solutions to specific problems.
- Reset your iPod Nano. See “General Suggestions,” below.
- Retry with a different USB port if you cannot see iPod Nano in iTunes.
- Restart your computer and make sure you have the latest software updates installed.
- Reinstall iPod and iTunes software from the latest versions on the web.
- Restore your iPod Nano. See “Updating and Restoring iPod Software” on page whatever.
-Tha Mp3 Doctor
Nov 13, 2008 | Apple iPod nano
Locked iPod
You can unlock your iPod nano in two ways:
A Enter the combination on iPod nano by using the Click Wheel to select the numbers
and pressing the Center button to confirm them. If you enter the wrong
combination, it flashes red. Try again.
A Connect iPod nano to the primary computer you use it with, and iPod nano
automatically unlocks.
Note: If you try these solutions and you still can’t unlock iPod nano, you can restore
iPod nano. See “Updating and Restoring iPod Software” on page 50 for more
information.
Sep 03, 2008 | Apple iPod nano
I need to unlock my screen lock but i lost my ipod drive and i cant afford another one
â Enter the combination on iPod nano by using the Click Wheel to select the numbers
â Connect iPod nano to the primary computer you use it with, and iPod nano
information.
Jun 26, 2008 | Audio Players & Recorders
My iPod nano 2gb silver is showing a blank white screen.i've had it for close to a year and it freezes sometimes but that fixes itself when i drain the battery and then sinc it. but this time it just went...
Try the Five R's suggested by your user's manual - you can get the manual from Apple's website if you have lost it:
Remember these five basic suggestions if you have a problem with your iPod nano. If
â Reset your iPod nano. See “General Suggestions,” below.
â Retry with a different USB port if you cannot see iPod nano in iTunes.
â Restart your computer and make sure you have the latest software updates
installed.
â Reinstall iPod and iTunes software from the latest versions on the web.
â Restore your iPod nano. See “Updating and Restoring iPod Software” on page whatever.
-Tha Mp3 Doctor
Jun 14, 2008 | Apple iPod nano 2nd Generation MP3 Player
Frozen Ipod
installed.
Jun 13, 2008 | Apple iPod MA446LL/A MP3 Player
Ipod Nano Sync
When you plugged the IPod into the new or cleaned computer, it was like plugging the iPod into a brand new computer with different specs. The formatting options may have changed, and when the iPod tried to adjust for this format difference, the DB or file system could have become corrupted. forutnately, Apple has ways to correct this problem.
To help you, I will need to know what OS you have? Windows XP? Windows Vista?
Of course, this is only one of many possibilities. I would start simple - do the 5 "R's" that Apple suggest in the manual:
installed.
â Restore your iPod nano. See “Updating and Restoring iPod Software” on page 50.
After doing this, try to resync thos songs.
Good luck - let me know if you need more help!
-Tha Mp3 Doctor
Jun 05, 2008 | Apple iPod nano
MY IPOD WONT PLAY MUSIC!!!
Go to www.apple.com to reacquire manual - it does help - this is a db corruption, which requires firmware, which is one of the 5 R's
installed.
Apr 05, 2008 | Apple iPod nano 2nd Generation MP3 Player
My Ipod Nano A1236 8 GB is locked
Start with these five simple solutions: Reset, retry, restart, reinstall, or restore
Select your model and go on.
http://www.apple.com/support/ipod/five_rs/
Mar 21, 2008 | Apple iPod nano
Switching on problem with I pod
Restart your ipod (hold the middle button, menu button, and play button for about 10 seconds). That will restart your ipod, and should make it work.
If that doesn't work, follow the instructions on iTunes to restore your ipod to the original factory settings.
Oct 16, 2007 | Apple iPod nano 2nd Generation MP3 Player
Apple iPod nano Logo
75 people viewed this question
Top Apple Audio Players & Recorders Experts
Sean Cole
Sean Cole
TO Lady
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
