Question about Refrigerators
Maytag mfi2568aeb Replaced compressor 90 days ago. Freezer steady at 22 degrees. Refrigerator at 40 degrees. Icemaker production slow and ice not very solid. Air vents clear. What could be the problem?
  • alan kundtz May 17, 2014
    Thank you for your response. The compressor was replaced by a licensed technicain after the refrigerator virtually "shut down". The new compressor included a new overload relay/capacitor. My symptoms started after that work, but aside from soft ice cream I did not pursue a fix until now. Researching the problem has led me to believe that it is a defrost heater issue, including the build up of ice on the back wall of the freezer (but no leaks onto the floor). However, there were too many other possibilities that i could not rule out with my limited DIY skills, so I have a repairman coming today to diagnose the situation. Hopefully he can evaluate the previous compressor replacement work as it may relate to the current problems.
  • 34 Answers
The EPA recommends keeping refrigerators at 37? F and freezers at 3? F, so your freezer temperature is obviously too high. How was it determined that the compressor was the problem rather than some related parts?
When you say, "Replaced compressor...", do you mean you did the work or had a tech do the job? Were any related parts checked/replaced, e.g., start relay?
Some repairs can be made by someone with basic electrical/mechanical skills, e.g., replacing a defrost timer or ADC.
But a refrigerator compressor should be installed by a trained and licensed appliance repair technician. This is NOT a do-it-yourself project.
A compressor replacement and charging requires specialized tools and some expert knowledge. Perhaps you have the appropriate tools, gauges and knowledge.
If a bad compressor was the original problem, and you replaced it with a new compressor (there is a chance you might have purchased a defective unit), and you have checked the related electrical parts, you may not have the correct amount or the correct refrigerant in the system. If you had a leak, the unpleasant smell might be a tell-tell sign. Check: Refrigerator Parts Compressor System Testing
Posted on May 16, 2014
  • 13 Answers
SOURCE: I have a Samsung SR-S2028CSS
Are you sure about these temps C or F? At 2 deg on either scale, food would freeze! And -23 is unreachable.
Water running down the door sounds like a seal leak, check by putting a dollar bill between the seal and the frame. It should NOT pull out easily. Or there may be an air leak in the ice/water dispenser. Look at these parts closely. Or the "stile heater", a heater in the door frame to prevent condensation, may be broke. This is expensive to fix.
Posted on Apr 08, 2008
SOURCE: refrigerator side not cooling - freezer side icing up
I have repaired my Sears refrigerator/freezer many times since I bought it in 1971. Recently, the refrigerator freezer section started to ice up and the temperature in the freezer started to slowly rise to about 20 degrees F and would not go any lower.
This happened once before and it turned out to be a defective Defrost Timer.
This time the problem was a defective Bimetal (Temperature Switch) that shorted against a metal tube in the refrigerator.
I replaced the Bimetal and now the refrigerator is fine - no frost and it now goes down to 0 degrees F, as it should.
I have taken a series of photos of the problem and repair of my refrigerator plus a schematic diagram. Follow this link for all the photos.
http://www.esnips.com/web/RefrigeratorProblem
Also, make sure that you don't cover any holes or vents that are in the freezer section
Posted on Jul 02, 2008
SOURCE: RS2630SH icemaker slow production
Fan's on this unit must be junk... I've had mine for 2 years... squeals something terrible. My old hotpoint 14 years before any problems.
Posted on Sep 22, 2008
shinn8
  • 85 Answers
SOURCE: Whirlpool ET21DMXDW05 top freezer. icemaker not working
Give it some more time. The icemaker has an internal thermostat and it will not come back on until it reaches 16 degrees. It takes a while after it gets warm. if it doesn't start functioning in a few more hours you may have other problems. Hope this helps
Posted on Jun 07, 2009
  • 363 Answers
SOURCE: maytag french door frig - Freezer works, frig warm
sounds like the freezer fan motor is worn out
Posted on Jul 22, 2009
Frigidaire FGHN2844LP ice freezing together. Replaced filter. Twenty hours later, ice maker not working, freezer warm, refrigerator temp. steady 40.
Hello Pat Havard,
I was pulling your owners manual to TRY to determine what could be done to block your freezer door or ice chute open during the filter changing process...
Today the ambient air temperature was at least 90 - 100°F
(degrees Fahrenheit)... To maintain 40°F your refrigerator
has to be working...
You need to look at your FREEZER side...
Your food, a pizza box... ice tray...
SOMETHING... in your immediate WORK area
is blocking vents... or proper closure...
Look at the door switch... make sure your light is OFF
My best guess... FILTER FIASCO induced.
http://www.appliancepartspros.com/frigidaire-ice-maker-243297606-ap5809314.html
The icemaker won't run unless you can freeze cubes...
Carnac the Magnificent
Jul 16, 2017 | Frigidaire Refrigerators
My maytag mfi2568aeb french door bottom freezer has ice on coils in freezer and ice maker wont make ice
Sounds like the icemaker drain is clogged and the fill process overflowed the unit. the water then froze the drain and all overflowed water from icemaker. Remove icemaker and remove all ice from freezer and icemaker. Clean all drains. Reinstall.
Nov 19, 2014 | Refrigerators
Maytag fridge works but freezer doesn't
Try the control relay/ condenser thats attached to the compressor and provides a momentary spike to start the compressor start windings prior to the unit going into run mode. reasonable and easy to fix
Apr 04, 2014 | Maytag Refrigerators
Temperature issues in GE Profile Refrigerator Freezer, what to do?
Sounds like an inefficient compressor or possible overload/relay issue
Jul 25, 2013 | Maytag MZD2768G Side by Side Refrigerator
Slow to cool changed the defrost board since it the coils was freezing up. the fan works, but the air to the fridge side seems slow. I have to turn the thermostat to 5 which is 1 higher to reach 0 dergrees...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Mar 31, 2011 | Maytage MSD2652KE 26 cu. ft. Side-By-Side...
Refrigerator stopped cooling 2 days ago. Freezer works fine. What is broken? Appliance is four years old. Replaced compressor almost exactly 1 year ago.
Check the fan in the freezer and be sure it's working, isn't blocked by product or isn't clogged with ice. If this fan isn't working the refrigerator section won't cool properly.
Jul 18, 2010 | Maytag Refrigerators
Water and ice despencer
Production of ice cubes depends on freezer temperature. zero degrees turns out ice more often than 15-20 degrees. Slow water?
You may have a partial clog in the supply line to the water sloenoid vavle. Are the ice cubes normal size when dumped?
Jun 20, 2009 | Maytag MSD2351HEB 33" 23 Cu. Ft....
Ice maker wont make ice
CHANGE THE FREEZER TEMP TO -2 AND THE REFRIGERATOR TEMP TO 44 AND IT WILL START MAKING ICE AGAIN
Nov 25, 2008 | Maytag MFI2568AES Stainless Steel Bottom...
My Amana AFD2535DEW freezer problem
Sound like the compressor is having trouble starting. You can purchase a RCO810 to assist the compressor's start winding. If the unit is under 5yrs there should be some warranty (no electrical parts) left in the compressor. It will need to be replaced.
Oct 16, 2007 | Amana AFD2535DES French Door Refrigerator
Refrigerators Logo
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
