Question about Lexmark Wheelwriter 10 Series II Typewriter
Why is this brand new typewriter acting out?
We just pulled this typewriter out of the box and when you type, all the lights on the right side turn on and it beeps at you 3 times, the device returns to the beginning of the line and the printwheel spins and freaks out. Is there a solution to this problem? Thank you!
    Top Expert:
  • Lexmark Master
  • 36,311 Answers
Return it to the point of purchase as defective right out of the box.
Posted on May 16, 2014
JayBlair
  • 328 Answers
SOURCE: typewriter won't type
All of the lights need to be flashing if the batteries are dead. Any other combination means either the keyboard , power supply or main logic board is bad.
Posted on Aug 07, 2007
  • 3594 Answers
SOURCE: Beeps 6 times, lights blink
The prinwheel sensor is likely the issue.  Move the carrier to the right, on the left side of th carrier toward the rear of the machine there should be a small black "flag" sticking out of the carrier.  this should move freely in and out if it is not there or does not move the machine cannot detect the printwheel the sensor will need to be replaced.
  You ca also check for debri down in the area where the printwheel sits.
Posted on Oct 24, 2007
JUSTOLDJIM
  • 454 Answers
SOURCE: IBM wheelwriter 6 Series II
try turning the machine off put a SMALL amount of oil on the large round rod running across the typewriter manually push the print head left and right a few times to see if it will loosen up. The problem is usually caused be drying oil you may consider having it serviced by a pro.
Posted on Nov 01, 2007
  • 3594 Answers
SOURCE: flashing lights
You have a keyboard problem. The rt. connector has 7 contacts bussed together, wrap a piece of foil over that portion of the connector and plug it back in. BE SURE TO COVER ONLY THE 7 BUSSED CONNECTORS!
Posted on Dec 22, 2007
  • 3594 Answers
SOURCE: IBM Wheelwriter 10 Series II 6 Beeps 1,2,3 Blinking
Check in the area where the printwheel is installed for paper or other debris. If it does the same thing with the printwheel out then it is probably a printwheel sensor.
DickyO
Posted on Jul 14, 2009
I recently bought a 1964 Hermes Ambassador typewriter. The typewriter is in very good shape, -but the carriage is slid all the to right (as if ready to start typing)and will not move. It acts as if it is...
I worked on typewriters for many years. If the unit has been sitting for years, it is in need of a good cleaning when you depress a key, it activate a mechanism that rotates a pawl on a toothed rack under The carriage. Plus there is a final stop that stops the carriage from going to far too the right. Flip the unit up and push the carriage lightly and watch the mechanisms spray light lube and keep moving the mechanism it should loosen up. Depress space bar and gently pull the carriage to the left. You may also have lost the tension cord. That's a spring assisted coil that pulls the carriage. You have an old unit there. It was great in it's time.
Feb 08, 2015 | Office Equipment & Supplies
How do I fix my Smith Corona SC110 Typewriter?
make sure the right hand platen knob is tight hold the platen and turn the knob top toward the back of the typewriter until it is tight
Aug 17, 2014 | Smith Corona Wordsmith 100 Typewriter
Brand new typewriter. Set up according to
When turned on the carrier must move to the left side frame, where it seneses the LEFT limit, then moves towards the right and parks at the Left Margin Position. Your problem sounds like something is interfering with the carrier movement to the LEFT limit (could be packaging). Turn the power OFF. Manually move the carrier to the RHGHT. Look inside the machine on the left side to check for foreign materials. Also check that the ribbon, correction lift-off tape, and printwheel are installed properly. GOOD LUCK!
Dec 29, 2009 | Brother EM-630 Typewriter
How do I change the font and type size on a swintec typewriter
To change the font you must change the printwheel. Remove the ribbon and L/O tape, Pull the lever just to the right of the print solenoid. Remove the printwheel by pulling on the knob in the center. To change the pitch move the slide sitch on the L. side to the setting you want. DickyO
May 30, 2009 | Swintec 7040 Typewriter
No Characters Typing
could be the ribbon is not lifting, do you see an image on the ribbon, also may be twisted inside the cartridge the shiny side has to be facing the keyboard.
Jul 09, 2008 | Brother EM-630 Typewriter
New typewriter
On the right side of the typewriter, just beneath the carriage (as you are facing the typewriter) there is a small metal lever which you need to push back. It is the carriage lock used to hold the carriage in place when it's being transported in the case.
May 17, 2008 | Olivetti MS25 Typewriter
Cannot get daisy wheel to type correct letters
Turn oFF the typewriter, take the ribbon out.....use the lever on top to release and remove the print wheel cartridge. Lightly rotate it to see if it will move and reinsert the cartridge. snap it back into place.
Turn on the machine, the typewriter should move the carrier to the left and reset the printwheel....if it is snapped back properly.
Jan 14, 2008 | Brother GX-6750 Typewriter
Lexmark Wheelwriter 10 Series II Typewriter Logo
52 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
