Question about Troy-Bilt 179cc 24-in Two-Stage Gas Snow Blower 31AS62N2711
How do you remove drive cable from a troy built mower m/n 12a1869f011
Having trouble removing cover to gain access to the clip holding cable in place
    Top Expert:
  • Troy-Bilt Master
  • 41,560 Answers
We all have problems there just keep at it
Posted on Feb 09, 2015
How to change shifter lightbulb
Pry out bezel around shifter very carefully, remove clip/screw for shifter handle after pushing down small chrome cover on bottom of handle. Remove shifter cover (screws or clips hold it in place) to gain access to blub. 1/8 turn to left on socket and it is out
Sep 01, 2014 | 2006 Nissan Sentra
How to change drive belt on tor o 8-25?
disconnect the spark plug wire from the spark plug
Remove the battery pack cover, the battery and the fuse.
Remove the screw inside the battery cover and the screws that hold the belt cover underneath the mower.
Remove the screw from the battery bracket.
Flip the mower on its side to access the bottom and remove the belt cover.
Remove one of the screws holding the belt guide in place. Loosen the second screw holding the belt guide.
Move the belt guide away from the belt driver assembly.
Loosen the drive belt by loosening its tension around the pulley and pry the belt from the fingers of the bracket.
Jun 04, 2014 | Toro Garden
The Cover is held in place by 6 bolts, we move the Bolts and the cover comes off. What problem are you having removing the Bolts?
May 16, 2014 | Troy-Bilt 179cc 24-in Two-Stage Gas Snow...
I need a manual or step by step instructions to change the belt on my Toro Personal Pace mower
The mower should be drained of gas and drain the motor oil before starting procedure.
Disconnect spark plug wire from spark plug.
Motor side of the belt:
Remove two bolts under the lawn mower body which holds the top cover over the drive belt.
Remove the belt guard that is around the pulley on the crank shaft.
Then work the belt around the blade and off the the drive pulley.
While blade is removed, sharpen or replace as necessary.
Transmission side of the belt:
Remove the "S" clip on handle for speed / traction cable
Remove the plastic "Rear Baffle" two screws on each side on frame in front of rear wheels one screw in the rear
With the baffle removed, rotate the drive shaft and transmission to gain access
to the pulley drive belt guard, it is held in place with three screws.
Once belt guard is removed, you can easily remove the drive belt
Reverse procedure to replace the belt.
Lubricate drive Axel bearings, wheel bearings, control cables, as necessary.
Replace all fluids as necessary.
Read more: http://wiki.answers.com/Q/How_do_you_change_drive_belt_on_toro_lawn_mower#ixzz1MMJlZFMZ
May 14, 2011 | Toro Personal Pace CARB Walk Power Mower
Please describe how to remove back tire from lawn tractor troy built
The back wheels are held on by a bolt threaded into the rear axle. To gain access you need to pop off the little black cap with a screwdriver, Then with a 12mm socket remove the bolt and large washer( used to hold the plastic cap), then slide the wheel off. If it wont slide off, due to corrosion ( Rust), then soak it with WD-40 or some type of penetrating oil. Note, some tractors have a keyed axle, if yours does....dont lose it, and when you reinstall the rear wheel, install the key AFTER you install the wheel. Do it from the out side NOT the inside, or it will ( could) push off when reinstalling the wheel. If that happens you wont have any drive on that side.
Hope this was helpful
Nov 10, 2010 | Garden
Instructions to replace drive belt on toro model14ap80rp744 and daigramn
Hi. Here's the procedure on how to replace the belt. Sad to say i dont have a diagram for that. Please see below instructions.
Aug 19, 2010 | Toro Garden
My troy built 210 6.75 hp mower self propelled mower doesnt pull
remove the front black plastic plate that is stamped self propelled and replace the wheel drive belt that attaches the engine pulley (above blade) to the transmission pulley (found under the cover). When you buy the belts, pick up two or three as I seem to go through a couple per season. Hopes this helps
May 20, 2010 | Troy Bilt 5.5hp Self Propelled Mower
How to replace belt on self propelled lawn mower
There is probably a cover on the front part of the mower that goes to the front wheels. remove the cover and you should have access to the belt. Carefully remove the belt (don't pinch your fingers) push it back towards the motor. You might have to remove the blade. Place new belt in the pulley on the engine shaft then to the pulley up front. Carefully start the belt on the front pulley and slowly turn it onto the pulley.
May 23, 2010 | Troy Bilt 5.5hp Self Propelled Mower
I have a Troy Built lawn tractor, after removing
Clearly the cable either broke, came loose.
Aug 22, 2009 | Garden
Panasonic Vacuum MC-E450UK
Panasonic MC-E 450UK upright vacuum cleaner.
Just had this problem myself...........easy to get at it when you know how.
Panasonic UK wouldn't help me so I spent some time working it out..........here it is.
Remove the hose from its mounting storage at the rear (called hose clip) where the main body of the vacuum cleaner meets the base of the handle assembly. Remove the screw at the rear of the handle assembly which is behind where the hose 'was' situated and is located inside the deep recess.
Using the soft part of your clenched hand as a hammer, knock the base of the handle assembly at the front and it will slide backwards off the main body of the vacuum cleaner. Don't be scared, give it a thump and keep moving it backwards with a few more knocks.
Next remove the two screws at the front which hold the mains cable and on/off switch cover in place.
Finally looking from the rear once more, lift the plastic 'lug' at the top of the cover and which is part of the cover. This will now allow you to release the cover and pull it forward.
There you go! Told you it was easy!
Watch out for the funny little spring at the front behind the cover in the tiny plastic tube where it connects to the small rubber tubing as it could possibly try to escape.
You now have complete access in order to cut the intermittent part of the cable out and remove it from the 'choc' block.
Happy fixing!!
Jack.
Apr 07, 2008 | Vacuums
Troy-Bilt 179cc 24-in Two-Stage Gas Snow Blower 31AS62N2711 Logo
115 people viewed this question
Top Troy-Bilt Garden Experts
Jay Finke
Jay Finke
Roland W VanLue
Roland W VanLue
Tim Whalen
Are you a Troy-Bilt Garden Expert? Answer questions, earn points and help others
