Question about Garden
2004 JD X595. Has started and ran fine until last week. My brother was using the mower was turned off and would not restart. He jumped it and started fine. He then mowed for 10min and the deck shut down. Took it to the house and shut if off. Engine will not restart. 12.5V at battery and starter. Circuit board clicks and flashes and buzzing sound at solenoids. Instrument panel lights flash. Checked all wiring I could see for damage and found no issues. Original battery, and temp, hour and fuel gauge do not work due to weather exposure over the years. Seat safety has been jumped due to dealership service repair not leaving enough slack in wiring loom to keep the switch connected when seat is folded. This is the only known issues prior to this failure. Any ideas?
    Habit-Forming:
  • 157 Answers
Sounds like a Charging system: alternator problem... have your Auto-zone check for your alternator if it is shorted...take the alternator off or haul the whole tractor to the store...they will run a free test...
Posted on May 16, 2014
3 Suggested Answers
jdmitchell47
  • 3 Answers
SOURCE: I have a Cub Cadet 2135 mower deck issue: Started
repair the seat first remove seat and reinforce metal use metal plate on top and washers on bottom or reverse make sure seat is secure so that u do not loose the ground contact on safety switch their is also a safety switch on shifter lever and brake pedal check them for rust and a tight contact
Posted on Nov 02, 2013
  • 5 Answers
SOURCE: Why did both battery cables melt on my MTD mower?
ignition switch
Posted on Mar 17, 2014
Just purchased a toro zero turn mower at garage sale. Ran very well first couple weeks. I was running it the other day, shut it down, jumped back on 10 mins later, mower does not start.
You'll need to check all the safety switches. Probably one in the seat, one for the mower engaged, one for clutch/parking brake engaged, possibly one for reverse gear selected, and possibly for position of the steering arms.
Nov 15, 2016 | Cars & Trucks
JD X595 4x4 mower - Starts OK, BUT, as soon as the brake is released, the motor cuts out.
I would try bypassing the seat switch and the brake switch. Do this one at a time to determine if the switch is bad. Also buy some Sta-bil fuel stabilizer and gel remover. I recommend this for any seasonal equipment. Often the engine is not getting enough fuel and will stall when the pto is engaged. Sta-bil often rectifies this problem.
Mar 06, 2015 | Light Garden
I have a JD 2305. It runs/ran fine up until this morning after the 1st snow fall and cold temps, (-5C) arrived. The tractor turns over and idles great. I let it warm up at 1/3 trottle for 15 minutes b
Without being there to trouble shoot, this is just a guess. Does it have safety switches to kill the engine if no weight is on the seat?
If so, maybe it is defective.
Nov 16, 2014 | Garden
I have a kohler 23 hp command vertical brother hit something stopped deck and engine but started back up and ran good next day motor started fine half way through lawn lost power and will start but no
valve seats have come out do to hitting something motor starts and runs fine the slowly loses power from super heating and finally stops wont restart until cools down right valve jobs per cylinder 150.00 each
Sep 15, 2014 | Garden
The battery in my JD lawn tractor was dead; it started and mowed several times with a jump start but eventually only the tractor would run while the mower would not engage. With a new battery installed,...
I suspect that the alternator/generator has gone bad, preventing the battery from chargine, or generating enough voltage to keep the electric pto on your mower engaged.
I think that it is located on the engine beneath the flywheel.
I hope this helps you.
Aug 03, 2011 | John Deere Garden
I have a JD X595 Diesel. This is what happens, say if I start it, then shut it down it will not start again right away. The first time it starts the glow plug light comes on. Shut it down and try to start...
Before you do anything grab a test light, remove the wire from your glow plug, put one end of test light on positive on your battery and the other end on the glow plug, if the light comes on than your glow plug is ok, if not replace, otherwise you need to locate the relay/sensor that tells the glow plug when to go off/on which is more than likely the problem, you may be able to locate it by tracking the wire from the glow plug or your local John Deere service provider may be able to tell you exactly where it is over the phone.
Jun 09, 2011 | John Deere 26HP Hydrostatic 54" Riding...
I was gone for a week when I got back my 2004 trailblazer's battery was completly dead. I was able to get a jump and recharge it. it ran fine for a day then the 2nd day out I tried to jump someone else and...
Could be a blown fuse. While jump starting the other vehicle, you could have had a surge of voltage. A bad fuse could be the result of this. Hope this helps. Good luck
Apr 26, 2009 | 2004 Chevrolet TrailBlazer
Garden Logo
115 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
