Question about HP Pavilion Computers & Internet
Why does my P6211f fail to boot? It runs and stops, runs and stops. No logo. Black screen.
    Master:
  • 965 Answers
If you dont see the bios splash screen, then it is the power supply or BIOS. in either case, you will need to take it tocthe repair depot.
Posted on May 16, 2014
Error code: 1000-0143
I would suspect hdd errors and replace the drive.
Sep 06, 2014 | Dell Computers & Internet
Pro-book 4520 won't boot. I switched on this morning. The windows (7) logo appeared, then blue/black screen and cursor only. Would not boot up. Ran diagnostics which said all OK. Still won'
The windows files are corrupted or the hard drive has issues, load cd installation disc if available, if that fails have the hardware checked for possible replacement.
Aug 13, 2012 | HEWLETT-PACKARD ProBook 4520s Notebook PC
Ze4610 won't boot past HP logo
The hard drive has issues, the next step is to have it tested for possible replacement.
Jun 05, 2012 | HP Pavilion ze4610 Notebook
Black screen on booting
Hello dhauser451, does you computer boots to windows or does your computer has a black screen and will not boot or no logo screen, no windows, no startup, but still running ?
Maybe your windows boot screen disable?
NO GUI boot - System Configuration
Please reply back if you want me to help you.
Nov 26, 2010 | Nvidia GeForce 6600 Graphic Card
The screen goes very dark within a minute after booting up = I can just barely see the menu page
When you say screen goes very dark when it booted to windows so it means that when you turned on the laptop when the dell logo flashes the screen was fine? if thats the case could you please try this. after turning on the laptop you will see the dell logo flashes immediately keep tapping on F2 and then it will show you the BIOS setup utility, please check if in BIOS setup display goes dark as well. If yes then try this, after turning on the computer when dell logo flashes keep tapping on F12 to boot menu then select utility partition to run the diagnostics. Please run test on the LCD check if display goes black when running the LCD test. Then try this when you sees the dell logo keep tapping on F8 to boot in safe mode check if in safe mode display goes very dark. Try this too, boot in F8 then select last known good configuration check if the settings on your display will be fix. If you can boot to safe mode no problem then uninstall the display or video driver. then restart computer.
You can also try to connect an external monitor if you have one just try to isolate if issue is on the LCD or the video card. If the display is dark as well in external monitor then video card needs to be reseated if fails then replaced. In situation like this most video cards is integrated to the motherboards. So replace motherboard.
Dec 08, 2009 | Dell Inspiron 2200 Notebook
Lap boots up, shows dell logo then screen goes black but runs.
ur unit is overheating turn off and unplug and let cool down,clean vents around fan intake (under unit) and around top each side of keyboard when cool enough plug back in and listen for fan operation while booting up if no fan it may be stuck or burnt up and may need replacement but ur biggest problem will be the hard drive if it was overheated for to long could or is damaged good luck hope ur lucky and that it just got hot
Dec 05, 2009 | Dell Inspiron B130 Notebook
Goes On ..Then Goes Black Screen I have 2 GX280s. One failed the other day after 2 years use. The BIOS screen appeared then it all went black. About every 10th attempt to get it going, it works and boots...
have you tried booting in safe mode? When it starts press F8 and select "Safe Mode" or "Last Known Good Configuration.". On that 10th try you do get it to come up make sure you install all updates for your computer. Then you can put int he Optiplex disk from Dell and run some diagnostics.
May 28, 2009 | Dell OptiPlex GX280 PC Desktop
R15s829 tablet fails to fully boot
try reinstalling windows vista. back up your data and reinstall using the recovery disc
Jan 16, 2009 | Toshiba Satellite A135-S2276 Notebook
Black screen after microsoft logo
Pls reintall the Operating system as the boot file that are required to reach the desktop night be corrupt.............reinstallaing operating system will be the best solution.......................Sameearyan
Jan 13, 2009 | HP Pavilion zd8000 Notebook
Computers & Internet Logo
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
