Question about Sewing Machines
Consew 206rb1 stopped sewing
I'm in the middle of an upholstery job and my consew stopped working correctly. I believe everything is threaded correctly. And I've used this machine on several occasions with no issues what so ever. I'm assuming it may have something to do with the timing. Everything was going just fine then all of a sudden I noticed that it was just leaving holes in the fabric while sewing. I figured the bobbin might have been out of thread. So I checked it and still had more than a half spool left. I reinserted it and the upper thread pulls the bobbin thread up without any issue. But whenever I start to sew it still just leaves a trail of holes in the fabric. Any help would be greatly appreciated.
  • Kathleen DeChellis
    Kathleen DeChellis May 18, 2014
    Also the take up lever being incorrectly threaded can cause problems.
  • 77 Answers
Have you tried a new needle? Needles should be changed out before each project and if a large project, several times during the project.
Posted on May 17, 2014
  • Mike Chisolm
    Mike Chisolm May 18, 2014
    The needle looked to be in great shape. However I did change the needle several times trying to resolve this issue. Thanks for the advice though. I appreciate it.
    Sometimes needles look good when they are not. Unfortunately, a dull needle is hard to spot. Sorry it was not the issue. That is the easiest to solve.
SOURCE: Upper thread wraps around bobbin mechanism, while sewing
IT PROBABLY IS THREADED INCORRECTLY. GO SLOWLY BY THE DIAPHRAGM AND MAKE SURE IT IS THREADED CORRECTLY. ALSO MAKE SURE SPOOL PIN HOLDERS ARE IN PLACE THAT HELPS TO GUIDE THE THREAD CORRECTLY.
Posted on Sep 22, 2008
  • 192 Answers
SOURCE: Designer One "broken thread"
If the upper thread spool is spinning allowing slack to the inlet of the tension assy and the machine gives a broken thread indication shortly afterward, the pre-tension assy needs to be adjusted. If the machine has the original "snap in" tension assy that was in the first generation of Designer 1, have it replaced with the modern "lay in" tension assy. Slack at the spool should never cause a broken thread indication as long at the thread is in the pre-tension assy.
Sulky thread will work as well in a Designer 1 as any other embroidery thread as long as it is properly adjusted.
One thing that you can look for, when the machine is sewing, watch the thread as it passes out of the left hand side of the tension disks. It should exit the disks at the 9 o'clock position. If it starts to drift up to the 10 or 11 position and then you get a broken thread warning, the pre tension must be increased.
Posted on Apr 08, 2008
  • 323 Answers
SOURCE: Consew 206RB, threading problem?
This machine has a safety clutch which is designed to protect the hook mechanism.To access it, place the machine on it's back. About 8-10 inches from the right side you will see an assembly on the main shaft. You need to hold this assembly with a push button located on the bed of the machine while you turn the handwheel. It will click in place when it is in the correct position. Once you've done this the machine should be back in time so it will sew.Hold the top thread ,turn the handwheel and draw the bottom thread up before you begin sewing. Place a piece of fabric under the foot , turn the wheel by hand to make sure there is no binding and that the thread is being picked up.
sewman7
Posted on Aug 29, 2008
SOURCE: Bernette sewing machine making a mess of thread on back of fabric
I once heard from a great sewing instructor that if the problem is on the back of the fabric then it is a spool to needle problem.... if the problem is on the top of the fabric, then it is a bobbin problem. Check your machine for dust and stray threads. Check your bobbin casing for dust and stray threads.
Posted on Dec 14, 2008
  • 19 Answers
SOURCE: Singer Simple bottom thread is loose
hi there
raise pressure foot up thread making sure thread passes between thread guide this should solve problem never alter bobbin tension,
mary h
Posted on Dec 30, 2008
I have a consew sewing machine model 260 what is the use?
Heavy duty fabric sewing....canvas for tents and awnings, leather maybe, upholstery fabrics.....
Feb 07, 2015 | Consew Sewing Machines
I need a needle thread guide for a 206RB1 consew sewing machine
Parts for these machines can be found at many parts providers. Dunlap Sunbrand in Ky will have them. Henderson Sewing is another. Just google--there are a lot of them
Jul 09, 2014 | Consew 206RB
My consew model 225 just had a new belt and oiled was sewing this morning and last night leather but will not pick up the bobbin thread just poking holes into the leather. Please help
Check bobbin threading and tension. Make sure correct needle is installed and threaded right. Belt and oil have zero to do with the problem.
Jun 28, 2014 | Consew Sewing Machines
How to thread a consew 7360R
There is below the link to the Instruction Manual for your Consew 7360R sewing machins.
Enjoy!
http://consew.marginspluslive.com/images/products/pdf10/7360r-rh-rbboth.pdf
Sep 02, 2011 | Consew 7360R-1 Mechanical Sewing Machine
I was sewing on my Consew 206Rb-4 when the thread jammed in the shuttle area. I have removed the shuttle, needle, and pulled what thread I could see out. Turning the wheel to raise the needle is not...
There is still thread binding in the bobbin area. My advise is the remove the bobbin shuttle, I believe there is still thread locking your machine up. This is not an easy task and whatever you do don't lose the small screws. I can talk you through this the best I can, but if you are not comfortable taking the the bobbin shuttle out, please contact a commercial sewing machine repair shop.
Apr 19, 2011 | Consew Sewing Machines
I have a consew 230 and it is gathering on the bottom how do i ajust it
Pull the bobbin thread as it comes through the machine. Does it feel too tight? if so check the threading. if threaded correctly and still too tight back off small tension screw 1/2 turn at a time. see if that helps. carefull not to undo too far as the small screw will come right out and may be difficult to put back. This machine is for heavy, stiff fabric. If you're using thin fabrics, stop right there make no adjustment. You'll need a lighter machine. This is for upholstery and leather work. Even curtain/drape fabric may be too light. Thats the best I can do without seeing the machine.
Dec 11, 2010 | Consew 226R2 Sewing Machine
Tension problem, consew 225
The bobbin should have a thin metal peice that the thread goes under to create tension, the screw closes to end the thread comes out of is the one to adjust. If they were sewing with a light thread on the machine the tension on the bobbin is probably set pretty tight loosen it a little at a time, turning the screw counter clockwise. You might need to check your top tension also if it is showing a knot on the bottom. The bottom is to tight or the top is to loose.
Nov 03, 2009 | Consew 226R-1
Cannot get tension balance correct
Try this. reomove thread and bobbin from machine.. Set thread tension to the middle number. Rethread machine carefully making sure the thread is thru the tension wheel. Replace bobbin making sure that thread is thru it's tensioner.
Rule of thumb. Loops on the bottom, problem is on the top. Loops on the top, problem is with the bobbin.
Apr 16, 2009 | Consew 199R-1A Sewing Machine
Sewing Machines Logo
61 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
