Question about Hotpoint Aquarius WF000 Front Load Washer
Leak from front
My machine has a leak internally that then emits from the bottom left of the machine, it goes through a wash correctly, just left with a small puddle after it finishes. I wanted to take the lid off so I can get visibility of the parts and hopefully find the source of the leak and stop it but can't find any guides to instructing the dismantle process. I'm an engineer...just not in washing machines, so I'm more than happy to go in to find the problem, the machine is no longer under warrantly either. Can you point me in the direction to get into the machine?
    Prodigy:
    An expert who has answered 500 questions.
  • Hotpoint Expert
  • 517 Answers
Have you cleaned the soap dish by pulling it out
Posted on May 16, 2014
  • 2,509 Answers
You take off the top to get into the machine, there are usually screws at rear top holding top panel on.
That said the most likely culprit is the pump which you get to from underneath, followed by the door seal, which you should inspect carefully for very small holes. My guess is the pump, have you checked the filter is clear?
  • 1294 Answers
SOURCE: water leaking from bottom front panel
Plug off the wall. Open the back of the machine to take a good look at the tube coming out from the bottom of the tub, open the front door to see if the door washer is loose somewhere. You could even try to reach out thru the back to locate any loose rubber gasket, the door gasket that is...... Possible you could take out the top of the machine to see if any of the normal 3 tubes entering your dispenser has come loose.....
Posted on Sep 03, 2007
  • 209 Answers
SOURCE: Leaking washing machine - hotpoint aquarius 1100 - wm63
water leaks are very hard to locate as the water always drips from the bottom, it is just a case of detailed looking, after a while there will be a dry white mark where the water has dried out, this will show where the leak originated from, there are a few things at the front of the machine that it could be, sorry can't help much more nearly all parts can be bought by the public and with common sense and taking very detailed notes where wires came from etc, most jobs can be done by a competent diy person with basic electrical knowledge remember water and electric do not mix always unplug from power supply where working on any appliance
Posted on Oct 03, 2007
BADBOYJAY
  • 264 Answers
SOURCE: whirlpool front loading washing machine leaking
you will have to be nice to it as it will come out and with some fairy up liquid you can put it back so easy
Posted on Jan 07, 2008
barkencoa
  • 3463 Answers
SOURCE: slight leak
It dpends. see if you can see any staining on front of cabinet under the door , if you can then yes it will mean new seal.
Another source of water could be water from the dispenser trickling down the front of the m/c.
Another possibility is that you have a leak from under the front of the washer. Put a piece of newspaper under the front of the washer, this should enable you to pinpoint the source of the leak.
Hope this helps
Please leave feed back
Posted on Dec 02, 2008
  • 662 Answers
SOURCE: wf310 hotpoint aquarius washing machine wont spin or drain
Power off the mains. The filter is located behind the silver plate at the back of the machine at the bottom. Four screws hold it on. Drain out all the water. The filter is inside the big black rubber hose attached between the pump and the main drum. Remove the plastic clip holding it to the pump unit and then the metal cir clip holding it to the main drum. Inside is a white molded cone and a big white ball which floats. You will find a lot of junk here, clean out thoroughly. To refit put white cone back inside just as you found it, at the bottom, fit ball back into the cone. Attach to the bottom to the drum and re-fasten the cir clip. Finally reconnect the gator to the pump unit and tighten the plastic clip. Check out the pump too before reconnecting.
And rate me nice pl for the free help!
Posted on Jun 08, 2010
The machine is approx. 10 years old and has developed a small leak at the bottom left front corner service men want to charge $120 just to come to have a look is there an easy way identify the problem
Hi,if there is a leak it should be easy to locate,what I would do is after a quick wash lean the machine against the wall and look from under the machine with a torch,look at all the rubber pipes,get a piece of tishue papper and just wipe where the joints are if the papper is marked with water then you will have found your leak,dont forget the front seal of the door,all the best.
Jan 13, 2016 | Washing Machines
Water leak in front left corner of unit. Rusty leveler near strainer.
Is the leak on the same side as the hinges? If yes I'm guessing someone overstressed the hinge when opening the door too widely or by leaning on the open door and the seal is just barely tight enough now. Crack the door open half an inch and eyeball the door gap from top to bottom on the open side to see if the door is unevenly hinged - you can use a ruler to help measure but you need to keep the door immobile while comparing top and bottom gap widths. Tape a hard wedge in place in the doorframe to help with that. Fix for that? Pressure on the door in the right direction to straighten the hinge mount.
Feb 25, 2014 | LG WM2688HWM TROMM SteamWasher
My whirpool WFS1071BD front load washing machine leaking when spinning
During drain and spin only A washer that leaks only during the spin cycle often has a leak in the main drain hose. Inspect the entire hose and correct any problem you find.
Oct 14, 2012 | Whirlpool Duet GHW9150P Front Load Washer
Water coming out of the bottom of the machine
Sometimes, what may seem like a washing machine leaking from bottom locations is actually one that leaks slowly from other spots. Slow leaks can accumulate beneath your washing machine making it seem like you have a bottom leak. For more help identifying the exact point of the leak, see Washing machine leaking.
Bottom leaks may be better identified using a newspaper. Just dry the floor and lay the newspaper beneath the washing machine before you test for leaks. Darkened sections map out your water leak. This method is not always foolproof, however. The best diagnosis will come from a qualified service professional inspecting your machine.
If your washing machine is leaking from bottom in the rear, you may need a replacement pump and professional installation. The leak could also be caused by a faulty air dome seal or a hole in the tub. For more troubleshooting steps to tackle that leak, see Washing machine leaking from bottom. I hope that helps!
Sep 27, 2012 | KitchenAid KHWS01PMT Front Load Washer
Water leaking at time the washer is being filled, not during wash cycle. Leak appears to be starting a bottom left side of the machine toward the front from the middle of the side. Observation does not...
you say water only leaks when it fills correct? am wondering if its the hose that feeds in to the washer
this would be from the inlet solenoids check the clamps in the machine.
Dec 02, 2009 | Kenmore HE2 Plus Front Load Washer
Water appearing on bottom left hand side,can find no obvious cause
either the pump is leaking or front door seal or tub is leaking. The hoses internal and external connections can leak as well.
Nov 12, 2009 | Hotpoint WF430 Front Load Washer
There is a leak at the bottom of the washing machine. Water is coming out the bottom front and bottom left.
The leak is from the drain hoses or the fill pipes.
No need to worry.It's a common issue and easy
to fix of your own.
Sep 01, 2009 | Maytag Washing Machines
Leaking from the bottom of maytag washing machine
a good possibility that the front door seal is leaking check for tears or any small holes if it is that it it is hard to do
Jun 07, 2009 | Maytag Neptune MAH6500A Front Load Washer
Hotpoint Aquarius WF000 Front Load Washer Logo
20 people viewed this question
Top Hotpoint Washing Machines Experts
puggy666
Level 1 Expert
freddyfox
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
