Question about Janome Sewing Machines
How do I put cotton on machine
How do you set machine up with cotton
  • 55 Answers
Paul... youtube it.... It's really not difficult. Have to load bobbin with thread first... install bobbin (under the needle plate in its holder) thread cotton from top of machine through the correct catch points to the needle.... catch the thread from the bobbin..... pull threads under pressure foot (but look in youtube... loads of vids)
Posted on May 17, 2014
Machine wont sew cotton keeps coming out of needle tried everything
Do you mean cotton thread won't work in the machine ? Does polyester thread work ?
Some thread brands are not as good quality as some others. Not knowing what brand thread you have, it is possible the thread itself is causing the problem. .
If other types of thread work in this machine, it is most likely either the particular spool of thread or the brand being low quality that is the problem. I would try a brand new spool of a high quality cotton thread to see if that helps.
Oct 02, 2014 | Brother Sewing Machines
My Brother LS2521i has had issues with the top thread snapping, and bobbin thread getting tangled. I've dusted, rethreaded, and done every trick in the book. This is a BRAND new machine! I haven't been...
Check for nicks on the thread you are using. Also try turning the thread around it may be catching on a little cut at the bottem of your thread. Also are you using the white circular piece which has a hole in the center looks like cotten batten ? That helps sometime to make the thread unravel correctly. Place that on then put your thread on.
Mar 05, 2014 | Brother LS-2125 Mechanical Sewing Machine
Janome machine probs
try a ballpoint or a stretch stitch needle, that what I use when sewing
knit, t-shirt. it doesn't break the fiber in the fabric.
Jun 05, 2012 | Sewing Machines
The bobbin jammed with cotton. cotton wound around outside casing of bobbin...I twisted the black latch to release the cotton and 2 large disc components came out ...how do I put them back in...nothing...
If you go to www.singerco.com and download a free copy of your manual, you can enlarge a great diagram on page 77 of your bobbin area and how to put it back together. I enlarged it to 200% and I think that it will help you immensely. Good luck
Jan 31, 2011 | Singer 2250 Tradition
Cotton breaks on Brother Embroidery Galaxie 2100 machine
Try turning down your top tension setting a bit. If its at 4 or 5, i would turn it down to about 3 ish. Cotton thread is more brittle than polyester and rayon thread.
Hope that helps :)
Chris
Jun 05, 2010 | Brother CE5000 Computerized Sewing Machine
Tention on light cotton stitches too loose
If your sewing machine has a pressure control for the presser foot, loosen it or move to a lower number, however it is set up.
Make sure to thread your sewing machine with the presser foot up as this has a major impact on the stitch formation.
Mar 03, 2010 | Sewing Machines
Stitching tension
hi,
different fabrics and layers has diferent set up on threading. try cotton fabrics w/ thread tension of #3 to #4 and stich # 8 to #12.if you change fabric and layers gradual setting on dial tension should be done until you acquired the good set up.have a nice day.regards
May 29, 2009 | Singer 8280 Mechanical Sewing Machine
In what order do i put the tension assembly together
Probably the most important contol on your machine is this one that regulates your top thread tension there are reason for having to reset your tension.Classified your fabric that you are using there are several set up of tension in every fabric that you use.Cotton fabric is most easier other than silk fabric make a record on this set up.The required tension depend upon the stiffness of the fabric,thickness,layer of rabric to be sewn and required stitches.Try cotton fadric turn tension dial to N0. 3 and Stitch set to from 8 to 12 defend to what is nice to you.
Mar 07, 2009 | Necchi Sewing Machines
Sewing Machines Logo
Top Janome Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Irene Tulloch
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
