Question about Troy-Bilt 179cc 24-in Two-Stage Gas Snow Blower 31AS62N2711
How do you remove drive cable
Having trouble removing rear cover to get to clip holding cable in place.
    Top Expert:
  • 2,044 Answers
The Cover is held in place by 6 bolts, we move the Bolts and the cover comes off. What problem are you having removing the Bolts?
Posted on Aug 02, 2014
How to change rear barke shoes
Brake Drums & Brake Shoes Removal & Installation To Remove:
  1. Raise and safely support rear of vehicle.
  2. Release parking brake.
  3. Remove rear wheel assemblies. NOTE: If brake drum is stuck, install two 8 mm bolts into threaded holes and tighten evenly.
  4. Remove top return spring, front and rear shoe spring clips and hold-down pins.
  5. Remove anti-rattle spring and adjuster spring. NOTE: Note position of operating lever prior to removal.
  6. Remove bottom return spring.
  7. Remove clip and washer and detach parking brake cable from rear shoe.
  8. Remove brake shoes.
To Install:
  1. Lubricate all brake shoe contact points with appropriate grease.
  2. Place operating level into position on hub.
  3. Install rear brake shoe and connect parking brake cable to rear shoe with washer and clip.
  4. Install front brake shoe and install bottom return spring.
  5. Install hold-down pins and spring clips.
  6. Position operating lever and install top return spring.
  7. Install anti-rattle spring and adjuster spring.
  8. Install brake drum and screws.
  9. Adjust brakes and install rear wheel assemblies.
Jan 21, 2011 | 2003 Kia Spectra
I do have a problem with my presario M2000 Compaq laptop which whenever i open the laptop, it keep asking me password. Futhermore, my dvd rome cannot response to cd. can u help me. Tq
  1. Disconnect the power cable and any printers, monitors or other peripherals you may have attached your M2000. Lay the laptop face down on a table, with the front of the laptop facing you. Remove the battery by sliding the release latch to the left. The front end of the battery will pop up. Rotate the battery toward the back of the laptop to disengage it from the laptop base.
  2. Locate the hard drive on the right side of the laptop. Remove the two screws holding the hard drive cover in place and remove the cover. The hard drive will have a mylar tab on it to help remove it. Grab the tab and lift up on the left side of the hard drive until it disconnects from the motherboard. Pull the hard drive straight up to remove it from the hard drive bay.
  3. Remove the single screw holding the optical drive in place. Stick the end of a bent paper clip into the disk tray release hole on the optical drive, located on the front of the disk tray. This will eject the disk tray. Grab the tray and slide the optical drive out of the laptop base.
  4. Remove the memory modules. The memory compartment is located in the center of the M2000. Remove the two screws holding the cover in place and remove the cover. Use your fingers to spread the latches on the sides of the memory modules and slide the modules out of the sockets.
  5. Remove the mini PCI card by first removing the last cover on the bottom of the M2000. Remove the screws on the cover and remove the cover to reveal the mini PCI card. Disconnect the white and black wireless antenna cables from the card. Spread the latches on the sides of the card and slide it out of the socket. Disconnect the antenna cables from the clip attaching them to the laptop base.
  6. Remove the keyboard cover and LED board by first removing the two screws in the battery bay. These hold the keyboard cover in place. Flip your laptop over and open it up. Slide a flat-head screwdriver into the notch behind the "F1" key to unlock the keyboard cover. Do the same thing at the "F5," F11," and "Insert" keys. Pull the cover up to remove it. The LED board is under the cover. Disconnect the data cable from the motherboard and remove the two screws holding the board in place. Remove the board.
  7. Remove the keyboard by first removing the four screws holding the keyboard in place. Lift the back end of the keyboard up and tip it over so it is resting face down on the palm rest of your M2000. Disconnect the data cable from the motherboard and remove the keyboard.
  8. 8 Remove the display panel by first disconnecting the video cable from the motherboard. Disconnect the wireless antenna cables from the clips attaching them to the top cover of your laptop. Remove the six screws holding the display panel in place. Lift the display panel off of the laptop base.
  9. Remove the base enclosure by removing the three screws on the top of the laptop connecting the top to the base enclosure. Flip the laptop over and lay it face down with the front toward you. Remove the 18 screws holding the base enclosure in place. Lift the rear end of the base enclosure up until it comes free from the laptop. Once it's free, slide it back to remove it.
  10. Disconnect and remove any remaining components including the speakers, Bluetooth module and USB card. All of them are removed by the same procedure. Disconnect the cables from the motherboard and remove any screws holding the components in place. Lift the components straight up to remove them.
  11. Disconnect the fan cable running from the cooling unit to the motherboard. Remove the three screws holding the cooling unit in place and lift it straight up to remove it. To remove the CPU, turn the locking screw counter-clockwise until it clicks. Grab the CPU by the edges and lift it straight up. Put the CPU in an antistatic bag for safekeeping.
  12. Remove the motherboard by first disconnecting the touchpad cable and remove the five screws holding the motherboard in place. Lift it up by the left side and remove it from the enclosure.
  13. please comment on these solution by saying how helpful.rating or voting.
Dec 24, 2010 | Compaq Presario M2000 Notebook
Instructions to replace drive belt on toro model14ap80rp744 and daigramn
Hi. Here's the procedure on how to replace the belt. Sad to say i dont have a diagram for that. Please see below instructions.
The mower should be drained of gas and drain the motor oil before starting procedure.
Disconnect spark plug wire from spark plug.
Motor side of the belt:
Remove two bolts under the lawn mower body which holds the top cover over the drive belt.
Remove the belt guard that is around the pulley on the crank shaft.
Then work the belt around the blade and off the the drive pulley.
While blade is removed, sharpen or replace as necessary.
Transmission side of the belt:
Remove the "S" clip on handle for speed / traction cable
Remove the plastic "Rear Baffle" two screws on each side on frame in front of rear wheels one screw in the rear
With the baffle removed, rotate the drive shaft and transmission to gain access
to the pulley drive belt guard, it is held in place with three screws.
Once belt guard is removed, you can easily remove the drive belt
Reverse procedure to replace the belt.
Lubricate drive Axel bearings, wheel bearings, control cables, as necessary.
Replace all fluids as necessary.
Aug 19, 2010 | Toro Garden
Trying to remove rear door handle on chrysler lhs 99
Hello, to remove and replace the rear door try the following:
1. Disconnect the negative battery cable from the battery of your Chrysler LHS. You can accomplish this with an open end wrench, to prevent any injury or short in the electrical system as you are working on the door lock switch. Place the negative battery cable out of the way so it does not touch any metal parts.
2. Undo any screws that are holding the lower door panel to the door with a screwdriver. Unclip the plastic hold clips that are attached to the back of the panel by carefully pulling them away by hand.
3. Locate the electrical connector wires. These wires run behind the panel to the door arm rest and detach each wire connector by hand. Remember how the wires were attached so you can put them back the same way when it is time to reattach them.
4. Lower the door panel away from the door. Then, remove any screws holding the upper door panel in place. Remove the door handle pull cup that covers the door lock switch and door handle by carefully popping the cover off after you have removed the screws holding it in place.
5. Detach the upper door panel from the door. You can do this by pulling it away carefully from the plastic clips. Move the upper door panel out of the way and locate the door lock actuator switch. Remove the screws from the actuator switch that are holding it in place and disconnect the electrical wires attached to the back of the switch.
6. Replace the old door lock actuator switch with a new one. This replacement can occur by connecting the electrical wires to the back of the new switch and reattaching the switch to the door frame with screws. Put the upper door panel back in place, securing it to the door frame with plastic clips and screws.
7. Reattach the door handle pull cup to the upper door panel with screws. Then, put the lower door panel in place and reattach the electrical wires to the window switches underneath the armrest. Attach the lower door panel to the door frame with plastic clips and screws.
8. Attach the negative battery cable to the Chrysler LHS battery with the open end wrench.
Thanks
Jul 27, 2010 | 1999 Chrysler LHS
How do you remove the rear axle to change the axle seal, from a 2004 Coloraro?
remove the center cover facing the rear of the truck. you will see side gears with the shafts axle end at each side gear. a C clip will have to be removed from each shaft at the end of each axle. Then remove the wheels and pull out the axles
Feb 06, 2010 | 2004 Chevrolet Colorado
How do you remove c-clips on axle of 95 ford rear end?
If you have already removed the outer axle bearing cover in the rear hub, try popping the axle out as some of them have a compression clip holding it in place in the differential. If it doesn't pop loose, you wil have to remove the differential cover and push the axle inward enough to access the retaining clip to remove it. It should slide out fairly easile once the axle is pushed in far enough to clear the retainer clip lock collar.
Aug 17, 2009 | 1995 Ford F150 Styleside Regular Cab
Remove door panel on a Ford Van
For a 1999 Ford Econoline 150 (assume the same or very similar), remove triangular plastic cover over mirror assembly by prying straight out, remove plastic door handle cover by prying up from the front side, remove electronic door switches by prying up from back side, remove round plastic cover at bottom rear of door panel. Four screws are now revealed, remove them. Lift door panel straight up, clips are hooks (not snap in). Work door switch assembly out of door panel. Set door panel aside. Reassemble in reverse order.
May 09, 2009 | 2000 Ford Econoline
Manual showing how to remove DVD-ROM Drive from case for Presario 5000?
REMOVE CASE SCREWS FROM REAR CASE COVER.CASE COVER SLIDES OFF FROM FRONT TO BACK.DVD IS HELD BY 4 SCREWS TWO PER SIDE DISCONECT POWER LEAD AND RIBBON CABLE YOU GOT IT,RICHARDM69
Dec 02, 2008 | Compaq Presario 5000 PC Desktop
Dell W1700 picture went out. Still have audio.
I have just did this here is the solution for you:
MoniServ, Inc.
http://www.moniserv.com
Tools:
Philips screw driver
Small Flat screwdriver
that’s all!
Preparation:
Make sure your desk is clean and you also need a piece of soft clothes because you need
to place your LCD Monitor face down.
How to open the back cover:
First, remove all screws on the back cover, then, use a small flat head screw driver to
push down
the plastic Clip inside the LCD Monitor star at the bottom of monitor. Then you can easily
separate the front bezel and back cover like the photos shown below.
Backlight Inverter Installation Procedures for Dell W1700
Place the Monitor
Face Down
Push This Plastic Button
Down and Remove
Swivel Base as shown
on Next Photo
Remove these
screws
Star at the bottom of monitor as
shown on photo.
Use a small flat head screw drive
to push down the plastic clip.
Do it one side at the time as
shown on next 2 photos
When you have unlocked all 4 sides of plastic clips, Place the monitor face down again
as shown on photo
Slowly tilt
upward from
left side of
back cover
Disconnect this cable and
remove back cover
Remove two
screws and Pull
out this small
circuit board
Disconnect Speaker
cable and remove
the tapes
Disconnect
Backlight cables.
Remove these screws
on the both side of
Panel
Caution!!!
Slowly tilt upward the chassis and disconnect the flat cable
between Chassis and Panel As shown on next 2 photos.
Holding the chassis upward and
Use small flat head screw drive
to unlock this plastic clip
Slowly pull it out
Remove defective inverter board and replace with our New Substitute Board
(T501045.00MSS) and re-install all disassembly components back. Now your LCD
Monitor working again.
MoniServ Substitute Board is available at
http://www.lcdpart.com/Products/t50104500mss.html
Backlight Inverter board.
Photo Shown with our Substitute Board
Remove 4
screws and
disconnect
this cable
Nov 29, 2008 | Dell W1700 17 in. HD-Ready LCD Television
Troy-Bilt 179cc 24-in Two-Stage Gas Snow Blower 31AS62N2711 Logo
50 people viewed this question
Top Troy-Bilt Garden Experts
Jay Finke
Jay Finke
Jim Parker
Jim Parker
Are you a Troy-Bilt Garden Expert? Answer questions, earn points and help others
