Question about Sanyo DP26649 26 in. TV
Sanyo remote missing, cable tv wont work until i can select input on tv manually
SOURCE: need a remote code my new sanyo tv to go with
I went through all the Sanyo TV codes and then started entering in groups of 10. The U-verse offered 1103 i did 1100 to 1110 and it worked with 1107. Unfortunately at&T said you have to check the manufacturer which doesn't list universal codes. I was lucky on the Sanyo 18.5" LCD from Walmart using 1107!
Posted on Sep 13, 2009
  • 1632 Answers
SOURCE: Sanyo TV DP42647 No picture or sound, remote does nothing
This is the best solution for your problem as a 40 year experience with wires etc. Go to the source of your cable signal connector . Open it and clean the terminals with emery paper , sand the end of the cable shiny clean from corrosion , get a new barrel connectors with gold terminals if possible lengthen the ends of the cable , insert and tighten good, use thick rg-16 or rg 40 cable with good insulation ends crimped professionally with a crimpier or buy ready made , not from dollar store. Get a gold plated professional splitter if you need one or two , it will cost about 15 or more each . Make the cable runs as short as possible, using the thick good cables. If needed get a signal magnifier. From radio shack or the source etc. Connect them good and tight . Ground the splitters . Problem solved , you will get crystal clear channel 2 to 7 including 3 and 4 . Isolate the TV cable from other cables and power wires. Vitally
Posted on Apr 15, 2010
brownline45
  • 310 Answers
SOURCE: I have lost the remote to my sanyo DP32746 32 inch
just go to sanyo service center to buy a new remote control, to fix your problem
Posted on Jun 19, 2010
  • 11 Answers
SOURCE: I have a CLT2054 but i missed the power cable
I found an AC adapter for the Sanyo CLT2054 on ebay that works GREAT!!
The ebay dealer is cenyglobal, specify "Sanyo-Right-4Pin-12V5A"
AC Adapter. Price is ONLY $14.99 + $4.99 shipping.
The problem is that the CLT2054 TV has "2" different power plug hookups.
When you look at the 4-pin connector with the flat side UP, for my TV, 12V is on the RIGHT 2 pins. On the other versions12V is on the TOP 2 pins.
HOPE THIS HELPS!!
Posted on Oct 05, 2011
SD Tech
  • 14553 Answers
SOURCE: Trying to access input function on my Sanyo flat panel screen with sony DVD remote
Its 50-50 at best that it will program or work.
Another option is take the bad remote to a repair shop--where I work we fix most of them and usually under 20 dollars.
Posted on May 29, 2012
Sanyo remote missing, direct tv won't work until I can select input on tv manually
You can buy a replacement remote with all of the features of the original here: http://remotes.com/remotes/servlet/rs?a=Search&o=c&uid=0&m=DP26649&uuid=13965609760310 . This remote is guaranteed to work with your TV. Alternatively, a universal remote that was programmed after April 2010 with an input button should have a code that will work allow that button to work with this TV. You may have to try multiple codes.
I hope this helps.
(The DP26649 was available on Amazon.com starting before the end of October, 2009. Most universal remotes can control TVs made 6 months or more before the remote was programmed at the factory.)
Apr 03, 2014 | Sanyo DP26649 26 in. TV
Can't change to video mode missing remote on SANYO TV model DS25204
You must have its original remote control to select inputs.
May 12, 2012 | Sanyo Televison & Video
Tv is stuck on Video 1 and the remote is missing.Won't respond to the cable remote except on and off. HELP
Try pressing tv first on your cable remote then the video/source/input button on the cable remote. If there is no button on the television itself to switch video inputs a temporary fix for now is to connect the cable box to the video 1 female parts on your television. Buy the cables to do that if you don't have a spare set lying around. You can purchase a remote for your television with the model number from http://www.replacementremotes.com or even a Sanyo remote from a thrift store should be able to allow you to switch inputs.
Aug 21, 2011 | Sanyo Televison & Video
Connected DVD player to Sanyo DS27930 TV via input
According the manual for this TV the remote control has an input button, it is left of the power button. Make sure that the remote mode slected for TV not VCR or DVD and press input button to make a selction, make sure that the power to the DVD player is on. If yours is different try stepping through the channels buttons, some TVs input is selected through the channel buttons.
Jan 02, 2010 | Sanyo DS27930 27" TV
Need to program rca univ remote for sanyo tv & i lost the manual
Get your Sanyo TV codes and one by one program the into you RCA universal until you can turn the TV on and off. Find codes at Sanyo.com, the manual, Sat Manual, Vcr Manual etc.
Sep 19, 2009 | RCA Universal Remote Control
No picture no sound
Make sure you are selecting the correct input on your TV for your TV tuner, sat or cable box.
There are three ways to do this:
1. With the tuner or cable box turned on (you can do that manually or with its remote) use the TV's remote to cycle through all the inputs, until you find the correct one and take note of the name of the input that appears on screen, or
2. Look at the back of the TV and see where it is connected. It will say the name of the input, such as "HDMI1" or "AV2," etc. Then select that input on your TV with the cable or sat tuner turned on, if you have one.
Consult your TV's owner's manual, which will give more information on hookup and selection.
Hope this helps. :)
Nov 17, 2007 | Hitachi 50UX26B/27K 50" Rear Projection...
My Sanyo Tv wont play dvds without the remote
yot can play dvd by connectind dyd in audio &video socket without disturbing cable. a/v wire comes with dvd socket is in your tv
Sep 13, 2007 | Sanyo DS13204 TV
Manual Controls Insufficient
What is your universal remote control? if its not philips magnavox you try this universal remote control you will set the code match to your tv sanyo which you will see at the back of the instructions manual when you buy this remote control. follow the instruction of the manual on how to enter the code for tv. thanks.God bless you. i hope it will help.
Jun 11, 2007 | Sanyo DS20930 20" TV
Sanyo DP26649 26 in. TV Logo
42 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
