I have a whirpool WFS1273BW front loader and a shirt got tangled up with the door seal and was pulled compleatly of. I can refit it but not sure what way it goes, do the 3 little holes on the seal go to the top or bottom? Appreciate any help.
    Prodigy:
    An expert who has answered 500 questions.
  • Washing Mach... Expert
  • 517 Answers
They are drain holes so keep down
Posted on May 16, 2014
catriver
  • 878 Answers
SOURCE: Leaks water from the bottom
Your pump is probably leaking. It's mounted right at the front of the cabinet to the motor. It's held on by 2 clips and 2 clamps, very easy job. Part number for the pump is 3363394.
Posted on Oct 09, 2006
SOURCE: changing front loader seal
the way i done it was open the door take take the wire band of around rubber seal__as in picture one.__2 take top of machine of and take spring of as shone in picture 2 you shold be abble to take silver band of around rubber seal
Posted on May 07, 2007
jsrock516
  • 5911 Answers
SOURCE: Washer door seal is loose
The rubber seal fits over the lip around the door opening. Carefully seat the rubber seal all the way around the door opening first. Then, place the wire hoop in the crease where the rubber seal fits over the lip. Insert the hoop with the spring pointing at the bottom. Starting at the top and work your way around the door opening to the 4 and 8 o'clock positions. While holding the hoop in place, stretch the spring apart enough to allow the rest of the hoop to snap into the crease at the bottom of the door opening. You may need a second pair of hands to help you with this. Good luck and I hope this helps you.
Posted on Sep 16, 2007
  • 209 Answers
SOURCE: Washing machine door gasket.
i am a recently retired appliance engineer of 20 years and seen every bodge job / trick and short cut in the book which people have done to save money its simple DON'T WASTE YOUR TIME its a dam sight easier to do it right the first time
Posted on Oct 04, 2007
  • 236 Answers
SOURCE: LG WM2688HM front loader is leaking water around the door seal
this may be coming from the soap dispenser and running down round the door way and to the bottom- investigate that first. otherwise the seal may be worn/ damaged and needs replacing.
Posted on Mar 16, 2009
Why are my business shirts on a gentle cycle or any wash cycle so badly tangled togther?
Hi Stella,
I suspect the tangled shirts coming out of the washer is a result of the differences between the way a front loader vs a top loader clean clothes and can not be avoided. I don't think this is the source of the wrinkles though. I suspect the wrinkles are more a result of how long clothes remain in the dryer *after* the cycle has completed. If you remove the clothes *promptly* from the dryer and use a "dryer sheet" you will reduce / minimize the wrinkling you're seeing.
Mar 28, 2015 | Washing Machines
Leaking door seal
The door seal on a front loader is usually part of the boot that seals the drum from the front panel of the machine. It is held on over lips on the door and outer drum. Pull the seal away from the front panel and it should reveal the lip, now pull the seal off the lip working around the whole area. Push the seal into the drum and work it off that lip too. Replacement is the opposite of the removal and just requires a little patience. (Take you old seal with when purchasing a new one to make sure you get the right part).
Mar 26, 2011 | Frigidaire Affinity ATF7000E Front Load...
Whirpool washer front end loader lock light is on. but i can open the door the wash is empty. unplugged replugged it and tested the GIF the plug its in had power too, other wise the light to the lock...
unplug the washer, remove the lower front panel, put your hand under the front panel and pull a little lever behind the door lock mechanism and pull the door open.
Feb 05, 2011 | Whirlpool Washing Machines
Replacing door seal front loader bosch
This video will show you how to change a door seal on this bosch
Apr 04, 2010 | Kenmore HE2 Plus Front Load Washer
Front dor seal has a tear in at at the bottom. It leaks as soon a
you will need to remove front panel 2 screws at bottom behind kickpanel removed with one screw next to filter cap one more screw behind soap draw ,then remove steel spring clamp holding door seal to outer cover push seal into drum so as not in your way pull down front panel it will then come towards you remove door lock connection and lift away fromt panel this will expose drum front there is another spring clamp on back edge of seal remove this and pull away seal reverse procedure to refit new one may need some detergent on back of seal to make refitting easier.
Feb 04, 2010 | Bosch Axxis WFL 2060 Front Load Washer
Clothes come out tangled
Things tend to intertwine in the washer, even more so in front loaders. The only things that I have found that help is to use fabric softener, a gentler cycle, and an extra rinse. This alleviates the problem some for me, but it doesn't really go away entirely.
Regards, --W/D--
Aug 01, 2009 | Kenmore Washing Machines
How do you replace the door seal on a Bosch Nexxt front load washer?
Tilt the m/c back and remove the clamp securing the seal to the front of the cabinet, double the seal back inside the washer door opening, and then pull the retaining spring off the inside of the door seal which is fitted in a groove at the back of the seal.
Refit the new seal starting at the topmake sure the seal is fittef the right way up, drainage holes to the bottom.
Work the seal on all the way round the drum, and then roll the spring into the groove at the back of the seal and work it round all the way round the seal, you will find it easier if you have someone to help hold the spring in place..
Refit the seal round the front of the cabinet,and refit clamp at front.
Plz rate this solution.
Thanks.
Dec 19, 2008 | Bosch Nexxt Premium WFMC6400UC Front Load...
WMA46 Door Seal
turn off at mains
remove clamp that holds door seal to cabinet. peel door seal off cabinet.
remove worktop
undo clamp that holds seal to tub. pull seal away from tub.
to refit
lubricate slot in seal that goes on tub rim with washing up fluid
starting at top, fit groove in seal onto rim and work your way round in both directions pushing seal on to tub rim - requires patience and you amy not suceed first time round.
refit inner clamp
fit seal rond cabinet -0 this part is easy
refit outer clamp.
test for leaks on rinse as the water level is higher
Sep 07, 2008 | Hotpoint WMA46 Front Load Washer
The top of the rubber door seal has come away from the wire that holds it in how can I put it back
first remove the wire retainer (usually has a spring attached) then fold the rubber lip of the door seal back over the metal lip on the front of the machine when correclly positioned refit the retainer by starting at the recess where the spring sits and stetching it all around the seal making sure that it is sat in the groove where it fits, it is fairly easy to replacestarting from the spring and following around clockwise making sure that it is seated right as you reach the other end of the spring the spring will stretch allowing you to finish tucking the wire in and the spring should then tuck in to the recessed part of the seal
Jul 19, 2008 | Bosch Washing Machines
Clothes got tangled with rubber seal inside and ripped it. How do I fix/get a new seal?
This part is a problem on many front-loaders and never really goes away. The rubber seal is a replaceable part and should be supplied under warranty. There is no way to fix it.You should try very hard to get Sears to pick up the labor cost as well.
Mar 14, 2008 | Kenmore Elite 45986 Front Load Washer
Washing Machines Logo
Top Washing Machines Experts
