Question about KitchenAid KSRB25FRBX Aluminium Side by Side Refrigerator
Refrigerator is too warm - won't cool down.Have adjusted thermostat setting. Seems to be running constantly
  • pboots Jun 23, 2009
    there is a very little frost in the back of the freezer but not at all around or in air vents. I found a lot of lint and dust on the condenser coils beneath the fridge and just cleaned it off.
    Problem Solver:
  • 4 Answers
Check to see if there is an opening between freezer and fridge ....it could be plugged with ice ...which would indicate that freezer is not defrosting and you may need a new timer.
Posted on Jun 23, 2009
  • 351 Answers
Any frost in the back of the freezer? the fan running inside the freezer...
Microwave runs intermittently...heating seems to shut off when warmed up and runs again when cooled down...is thermostat defective or does it need to be adjusted?
Some ovens have a thermal protector on the magnetron. It opens if the magnetron gets too warm. Or, sometimes they will open at too low of a temperature. Another possibility is that air flow to the magnetron for cooling is bein restricted, or the cooling fan is defective.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/david_29ad5d1dd86564b0
Jan 09, 2017 | Microwave Ovens
Vegetables in crisper are frozen, as well as liquids in bottom 1/2 of fridge door. The fridge & freezer temp controls won't adjust to our settings. Also, we're getting ice, but no water will dispense.
The freezer cools the refrigerator, so you actually get very cold air passing from the freezer to the refrig. The air from the freezer enters the refrig on the top and falls to the bottom where it is drawn back into the freezer. The temperature of the refrig is regulated by a thermostat and a fan that runs when the thermostat calls for cooling. If the refrig thermostat is faulty and causes the fan to run more than it should, there will be a freezing problem in the refrig at the bottom because cold air falls and warm air rises. If the refrig is thermostat is calling for cooling constantly, this will take more cold air from the freezer than is normal. Your freezer temp might be higher than normal and the refrig will be colder then desired. If the fan from the freezer is running constantly I would suspect a bad refrig thermostat.
May 06, 2015 | Refrigerators
Fridge is warm
Adjust the cooling knob inside the fridge according to the outside temperature.
Oct 27, 2012 | Amana ABB1927DE Bottom Freezer...
Unit will not stay cool. Is it a thermostat, compressor?
Small refrigeration units like this one like to fail to cool by developing a small leak and slowly
leaking refrigerant.
THERMOSTAT FAILURE CHECK:
A technician will check the thermostat using using a DMM (digital multimeter). But you can suspect the thermostat if you set the thermostat high and the compressor motor does not run,
then set thermostat low, and the compressor motor also doesn't run - in other words, the thermostat is failing to start the refrigerator's refrigeration system no matter what its setting - an obvious failure of the thermostat.
COMPRESSOR FAILURE CHECK:
If the compressor is dying, you would hear the compressor running almost constantly, but not
sounding quite right (uneven noise, clunking, tapping).
REFRIGERANT LEAK CHECK:
If you unit is low on refrigerant (due to a leak), the compressor motor will be running
almost constantly, but it will sound Ok.
Mar 24, 2011 | Danby DWC513BLS Wine Cooler
Frezzer not Keeping things Forzen. I turned up the adjustment, and left it over night to adjust to new Temperature setting. I woke this morning to find everything almost completely Thawed. Fridge seems to...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Mar 18, 2011 | Refrigerators
Motor seems to be running almost constantly. Food is cold and freezer is working. Only shuts off for a short time and comes back on again.
avoid frequently opening of door. check door gasket close tightly. adjust setting of thermostat to coldest setting
Jan 25, 2011 | Hotpoint HTS16HBR Top Freezer Refrigerator
Refrigerator stopped freezing & cooling
can you hear compressor working
Apr 05, 2009 | Refrigerators
Programmable Thermostat Model 43157
On my Hunter model, there is a "Span" setting that allows you to change how long the AC/Heat will run before it turns off. Basically, it sets the acceptable range (above and below) your temperature setting. To access this press both the up and down arrows and hold them. "Span" should show up with a number (1,2, or 3). For your problem, change the setting to 1 so the AC will run shorter, and more frequently to keep the temperature more constant.
Aug 29, 2008 | Hunter Fan Company 5/1/1 Programmable...
Fan in cooling compartment
The fan inside the unit should run all the time, this insures a more constant temp throughout the compartment by keeping the air moving.
May 28, 2008 | Carrier Beverage-Air UR30GEFD Beverage...
Cooler wont cool below 48 degrees.
Keep a thermometer handy. (adjust temperature control knob accordingly)
Periodically monitor temperatures inside your cooler. (adjust as necessary)
Keep the refrigerator door closed as much as possible to avoid temperature fluctuations
The temperature of the refrigerator compartment is
controlled by adjusting/setting the thermostat control
knob, located on the ceiling of the refrigerator
cabinet.
To start the refrigerator, and achieve maximum
cooling quickly;
• Turn the temperature control knob (using a coin
or screwdriver) clockwise to the furthest
(maximum) setting on the darker blue section of
the graduated control dial.
• Allow the refrigerator to run at this setting for 3~4
hours.
• When maximum cooling is achieved, turn back
the temperature control knob setting to the 2:00
o'clock position on the graduated blue control
dial.
• Correct cooling temperature is a key factor to
consider in storing and dispensing draught beer.
• Optimum temperature for serving draught beer is
between 34ºF ~ 38ºF.(1ºC ~ 3ºC)
• To maintain temperatures ranging between
34ºF ~ 38ºF.(1ºC ~ 3ºC) We recommend the
thermostat knob be positioned at the "2:00
o'clock" setting on the graduated blue control dial.
• To turn off the refrigerator, (no cooling) rotate the
control knob to the "0" position.
Jan 31, 2008 | Danby DKC646BLS Full Size / Pony Beer Keg...
KitchenAid KSRB25FRBX Aluminium Side by Side Refrigerator Logo
223 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
vince
geob91
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
