Question about Jeep 2011 - Compass
Burning much gas
ITS A 4 CYL WHY DO I BURN SO MUCH GAS ?
  • 4 Answers
The cause is that the Compass is too heavy for any of the engine combinations offered. Further, and especially in the case of the 2.4L, the engines are far from efficient even when used in appropriately weighted vehicles.
This is the least effective product that Chrysler/Jeep has ever offered - not only my thoughts, look around (at non-Chrysler/Jeep websites).
Chrysler/Jeep does NOT have a reputation for selling vehicles that are economical - and a tank weighing some 4600lbs with only 175 horsepower (and that's with the 2.4L) on SUV-tyres should not be expected to do any better than 30-40 mpg. I'd be surprised if your mileage wasn't more realistically around 50mpg, since the ratings system used in US is somewhat 'generous' to the manufacturer.
Posted on May 16, 2014
My gas stove seems to have what i would call a after burn
If it is just short final flare, it is probably just the gas still in the supply pipe to the burner. That last bit of gas will burn off rapidly right after the valve is turned off.
Jan 03, 2015 | Kenmore Kitchen Ranges
Burns to much gas
my similar problem on 4 cyl jeep was cured by replacing both O2 sensors and coolant temp sensor (for second time). Also problem seemed to be related to putting too much oil on spector air filter and using carb cleaner which appeared to foul O2 sensors (a second time). replace sensors O2 sensors a 2nd time, stopped carb cleaner and now wipe off excess air filter oil and let dry in sun, and fuel economy went back up to 75-80+ miles per 1/4 tank of gas (vs. 55-60 miles per 1/4 tank of gas with fouled sensors).
Mar 04, 2014 | 1997 Jeep Wrangler
1989 buick lesabre bad gas mileage
well 3.8 engine is not suppose to burn much gas.check for low tire pressure.if engine got many miles on it it will burn more gas,if you live in city making short stops burn more gas,if you driving a lot of roads with steep hills and mountains car will burn more gas.lead foot quick acceleration speed driving burn lots of gas.
Nov 14, 2011 | 1989 Buick LeSabre
I have a gaz fireplace Marco DWF36CF-3 vented and would like to know if i can burn wood in it
My name is mike. YOU DO NOT want to attempt to burn wood in a gas fireplace. The reason for it, is the venting is not designed for the fumes and high heat the wood produces. Only way you can safely burn wood, in a gas fireplace is have to make sure the piping and venting is set up correct to burn wood. Your problem is not most likely your stove or fireplace for the safety, it would be your venting. Thanks Mike
Oct 22, 2011 | Heating & Cooling
How much clearance do i need to leave on top of the water heater between the insulation and the chimmney? is the insulation fireproof?
Gas or electric?
1) Electric heater can be completely covered with insulation except TP valve. Set electric heater on insulated surface. Insulate pipes completely right down to tank.
2) Gas heater is different.
No insulation over combustion area, or gas valve, or air inlet or. No insulation on top of tank that will interfere with venting of dangerous combustion products including odorless CO gas. Foam insulation on pipes should stop 10" short of tank top. No insulation within 6" of the 3-4" inch galvanized vent pipe.
Here's photo with gas water heater insulation tips:
http://waterheatertimer.org/images/Insulate-gas-water-heater.jpg
http://waterheatertimer.org/9-ways-to-save-with-water-heater.html
3) Tankless gas. No insulation on box. No pipe insulation within 12". No insulation near vent pipe.
4) How much clearance between heater and chimney?? Not sure what that means. Is that the water heater vent stack? Or where vent stack goes into chimney stack? No insulation on gas flue pipes. Or within 6 inches of 3-4" water heater vent pipes
5) Is insulation fireproof? Everything burns if it's hot enough. If you throw insulation into backyard fire, paper and foil will burn away and insulation kind of falls apart in the heat. Fiberglass insulation cannot be set on fire with a match. Foam pipe insulation will burn.
Dec 02, 2010 | Thermwell Water Heater Blanket
Very low gas mileage. most of my driving is in town. 2006 pt touring addition. 14.5/gal ? seems very low for a 4 cyl - mary
GAS MILEAGE IS MORE IN THE CITY.WHEN YOU STOP AND GO.THEN ACCELERATE THATS WHEN YOU BURN GAS.TAKES FUEL TO PUT VECHICLE IN MOTION.TRY CHANGING AIR FILTER.CHECK TIRES AIR PRESSURE.CLEAN FUEL INJECTORS.AND CHECK UNDER THE VECHICLE AND UNDER HOOD FOR GAS LEAKS.
Oct 21, 2010 | 2006 Chrysler PT Cruiser
My ventless gas heater smells like kerosene..wont burn off? makes us sick !!! bad headaches,watery eyes..gas co came , said it wasnt the gas?...no matter how long it burns, wont go away,we have cleaned it...
Stuff in the air can make you very sick when it is burned, is it Natural Gas or LP? Sometimes you can get bad LP gas that will burn your eyes. I would open a window to get more fresh air and try to let it burn to get whatever is making the problem out of the air.
Nov 12, 2009 | Heating & Cooling
We have a gas whirlpol that was converted to
on the gas valve there is a orfice a pin hole you can ajust the size of the orfice by tighting the ajustment a little a 1/4 turn . it is on the valve where the gas gos out to the bunner usualy a 1/2 in open wrench fits on it its made of brass you have to open the top to see it there is also a air ajustment where the bunner fits over the gas valve orfice if the flame is red open it more if its to hot close the air a little make the flame red then turn the gas down tell its blue agin
Oct 20, 2009 | Whirlpool Ovens
Burners burn too hot at lowest settings
what type of range? what type of gas? propane or natural gas? thats a start...
Jan 15, 2009 | Kitchen Ranges
Jeep 2011 - Compass Logo
87 people viewed this question
Top Jeep Car Audio & Video Experts
xxxxxx xxx
Tom Chichester
David Littlefield
Are you a Jeep Car Audio and Video Expert? Answer questions, earn points and help others
