Question about Hardware & Accessories
Transformer part# and photo see below. Can't find
Transformer part# and photo see below. Can't find one anywhere!!! Help!
    Sergeant:
  • 384 Answers
What is it out of. What its purpose
Posted on Jun 17, 2014
Landscape lighting transformer hums only when controlled thru photo-cell, and not when powered directly.
1) Copy following link for Intermatic/Malibu power pack photo-eye instructions, general troubleshoot, manuals, replacement trippers, and tips to prolong life of power pack:
http://waterheatertimer.org/Malibu-power-pack-stopped-working.html
2) Brand and model of transformer and photo eye are unknown.
Wiring changes are unknown.
Volt rating of photo eye is unknown.
Wiring of photo eye is unknown.
3) Add a comment including details, and attach photo, after reading information on link above, for live response Jan 2013
Jan 01, 2013 | Home
The set has the 3 strikes and you are out rule built into it.
Set will attempt 3 times to come on and if fails enter shutdown mode.
A short or an issue almost anywhere in power supply or high voltage circuit will cause this.
The only common cause is the set may have developed bad or cracked solder connections where the high voltage transformer solders in.
This happens because of poor soldering and expansion and contraction of the board happens when set gets hot and then cools off.
see attached photo of a high voltage transformer also called a Flyback Transformer.
SD TECH
Apr 28, 2012 | RCA Televison & Video
Astar MP-27BH power transformer.. will pay
Check this link to find the power supply you're looking for. The transformer itself it might be impossible to find it.
Good luck.
Nov 09, 2009 | Astar LTV-2701 27 in. HD-Ready LCD...
Bugs in my transformer
That is why it's not working,The bugs have shorted it out.It sounds like termites.you can get some spray and treat the area to keep the bugs away.
May 12, 2009 | Intermatic Malibu 300W Power Pack...
Picture problems
OK to help assist everyone having the BLUE HUE and CURVED LINES Issue on their Rear Projection HDTV no matter their model. Here are the steps to take. The first thing to check is the FOCUS BLOCK or G2 Focus Transformer or CRX F-Pack. I have replaced mine, however it didn't resolve the issue. I am onto the next item the CRT Board for Blue (Which is the board under one of the three color lamps inside your tv) Please see photo below (if photo is not large enough below go to link to review notes as well) If the CRT Board is not it, then the next step will be the Signal Board which is a larger board in the back. In a week I will have a picture of both.
INSTRUCTIONS:
  1. Remove the outside cover
  2. Remove the wood plank/panel
  3. In the front is the G2 Focus Block/Transformer, while set is on turn the top 3 knobs till the screen goes black/dark grey.
  4. adjusting the colors till you receive the desired or normal color/picture.
  5. Once you have received the proper color/picture tap the side of the Focus Block.
  6. IF The colors go out of wack again and the blue comes back strong then this "CAN BE" the Focus Block.
Replace the G2 Focus Block aka Focus Transformer, if Hitachi it's called a CRX F-Pack. This item will cost about $50. Not expensive. You will likely need a soldiering iron. DO TURN OFF & UNPLUG THE TV WHEN INSERTING ANY METAL OBJECTS INTO THE TV!!
FOLLOW THE PHOTOS/DIAGRAM in link below for assistance in the above instructions. I will post my next process since it was not my Focus Block that was an issue.
ONE SOLID PHOTO Go to URL CLICK HERE, click on that image to enlarge. Hope this helps you all out!
Mar 30, 2008 | Sony KP-57WV700 57" Rear Projection HDTV
No picture or sound
INSTRUCTIONS:
Feb 23, 2008 | Sony KP-57WV700 57" Rear Projection HDTV
Toshiba 42PW33Q rear projection gone blue
INSTRUCTIONS:
  7. NOTE: IF the color stays stable, then you problem is resolved and you do not need to replace it.
Nov 18, 2007 | Sony KP-57WV700 57" Rear Projection HDTV
Hardware & Accessories Logo
32 people viewed this question
Top Hardware & Accessories Experts
Gene Haynes
Hippy_dd
Are you a Hardware and Accessory Expert? Answer questions, earn points and help others
