Question about Hotpoint Ultima WF865 Front Load Washer
Why is my kenmore elite he3 coming up on screen f05
  • 641 Answers
The "F05" error code is indicating a Water Temperature Sensor Error. Does it take long time for the water to get hot when you initially start it? If the water is cold entering the tub when hot water or warm water is selected it possibly could cause the error. It only makes sense because after you cancel the cycle and restart the washer it does OK because the cold water has been purged.
There is a thermistor located on the heating element mounting bracket which is used to monitor the water temperature. The heating element w/thermistor will be located on the lower back portion of the tub. You might find a loose wire connection on the thermistor. You will need to remove the rear panel to access the heater and thermistor. You will need an ohm meter to measure the resistance of the thermistor. See images below for specifications.
NOTE: Disconnect the power cord before removing the rear panel.
If during the water heating step in the wash cycle, the water temperature sensor (NTC) value is out of range, the "F/05" error code will be displayed.
Potential Causes:
Check the Water Temperature Sensor
Check connections to the Water Temperature Sensor
I recommend calling a service technician to diagnose and repair your washer.
Posted on May 16, 2014
2 Suggested Answers
barkencoa
  • 3463 Answers
SOURCE: coming up on screen F05
Error code F05 means pressure switch jammed on full.
Remove lower rear cover of washer.
Locate and remove large black hose fastened to bottom of drum.
Remove and clean filter inside hose.
Remove hose onto pump, and check for blockage or obstruction here as well.
This should solve the problem.
Please leave feed back.
Thankyou.
Posted on Jan 10, 2010
I have a kenmore elite he3 smart heat quiet pak4 how much is a motor for this dryer
  1. Kenmore Elite He3 Parts - searspartsdirect.com‎
    Adwww.searspartsdirect.com/Kenmore-Parts‎rating for searspartsdirect.com
    Shop Today at Sears PartsDirect™. The Largest Appliance Parts Seller.
    Ratings:Shipping 9/10 - Website 9/10 - Selection 9/10 - Quality 9/10
Search Results
    MOTOR diagram for model # 41794130000 Kenmore-elite ...
    www.searspartsdirect.com/model-part/41794130000/0583/.../00004.html
    MOTOR Diagram and Parts List for KENMORE ELITE Dryer-Parts model # ... MOTORdiagram for model # 41794130000 Kenmore-elite-Parts Dryer-Parts (18).
    PUMP AND MOTOR PARTS Diagram & Parts List for Model ...
    www.searspartsdirect.com/model-part/11047789702/0583/.../00006.html
    PUMP AND MOTOR PARTS Diagram and Parts List for KENMORE ELITE ... ANDMOTOR PARTS diagram for model # 11047789702 Kenmore-elite-Parts ...
Nov 01, 2015 | Kenmore Dryers
Kenmore Elite He3 dryer..fine on timed but leaves cloths wet auto
find the metal sensors in the drum
scratchem up with sand paper
especially if you wash rugs, sneakers , or anything with acyrlic
Oct 05, 2009 | Kenmore Elite HE4 Electric Dryer
I have a Kenmore Elite front loading machine machine HE3 that keeps giving me an error code of F05. What does this mean? Obviously I've lost the manual
"F05" is a heat sensor error code. The following link explains:
http://www.fixya.com/support/r629462-f05_error_code_whirlpool_duet_kenmore
Actually, none of the error codes are included with your owner's manual. They are, however, included in the technical data sheet which should be located behind the lower kick panel directly below the door.
If you have any questions, please let me know. I hope this helps you.
Jul 11, 2009 | Kenmore Elite 45986 Front Load Washer
Check Pump on front loader kenmore HE3 elite
Remove the lower front panel 3 screws across the bottom. Pump will be behind this panel.
May 26, 2009 | Kenmore Elite 45986 Front Load Washer
My Kenmore Elite he3 is no longer drying clothes.
Hi
Please, the heater seems not working "
27593276.jpg My Kenmore Elite he3 is no longer drying clothes", what I need to check or do? thank you.
Mar 30, 2009 | Kenmore Elite HE4 Electric Dryer
Kenmore Elite HE3 Dryer clothes not dry after cycle
it sounds like a clog in vent.if yours vents up thru roof you may need to have a chimney sweep come out and sweep vent.check and make sure the vent hose is net kinked or full of lint.
Mar 06, 2009 | Kenmore Elite HE3 Steam 8674 Dryer
ERROR CODE F05, FOR KENMORE ELITE HE3 WASHER MOD.110.43862400
Click on the following link for diagnoses and troubleshooting tips for the "F05" Error code.
If you have questions and/or require further assistance, please post back and let me know. I hope this helps you.
Jun 12, 2008 | Washing Machines
F-5 error code on Kenmore elite HE3 45872
Click on the following link for a full explanation of the "F05" error code:
This is not a difficult repair. The error indicates a failure of the heating circuit. If you are not sure of how to diagnose this yourself, or require additional assistance, please post back and let me know. I hope you find this information helpful.
Jun 08, 2008 | Kenmore Elite 45986 Front Load Washer
Leaking Kenmore elite he3 washing machine
removethe lower acess panel 3 screws across the bottom , run the cycle and watch to see where exctly the leak is coming from it should be quite apparent
Mar 09, 2008 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Hotpoint Ultima WF865 Front Load Washer Logo
82 people viewed this question
Top Hotpoint Washing Machines Experts
puggy666
Level 1 Expert
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
