Question about Panasonic Toughbook CF-29 Notebook
Panasonic Toughbook "CF-29" bios - Panasonic Toughbook CF-29 Notebook
SOURCE: Install XP on Panasonic Toughbook CF-27 ?
sxcss
Posted on Apr 30, 2008
leecom72
  • 4806 Answers
SOURCE: Panasonic c-29 toughbook BIOS Password breaking
you have to remove or unplug the cmos battery which is attached to the motherboard inside the laptop, doing this will clear all passwords. If the password clears replace the battery.
Here is some more usefull info if you want to this yourself>
The guts of the machine are usually under the keyboard. If you are okaywith opening up the laptop, you'll need to remove a few screws, thebattery and the hard drive, then carefully pry up the keyboard to gainaccess to the items that the manufacturers say you shouldn't tamperwith. If its just a matter of getting into the bios and theres apassword, you can usually simply remove the battery and leave itwithout power for at least 24hours, then it should reset....doesn'talways work but since most laptops actually do not have a standard cmosbattery, this would be one way to go about it. Of course you could justtry to figure out what the password is, someone has to have put it inthere so they should know what it is, or you could go to http://tcc.toughbook.com/ and get the bios update, which will reset it completely.
Posted on Nov 15, 2008
1234s282
  • 144 Answers
SOURCE: keyboard installation for CF-52 toughbook
Here you , this is a step by step disassembly guide with pictures
Its for a Toughbook CF-50 but it should be similar as theres not too much difference in the model number
http://www.machinaelectronics.com/store/library/article.cfm?f=key_type_k17
Posted on Jan 04, 2009
1alexh
  • 484 Answers
SOURCE: upgrade hard drive in panasonic toughbook cf-50
1 - Using a stack of DVD RW blank disks, or a large capacity USB Flash/Jump Drive, back up your Laptop computer completely. If necessary, Use WinZIP to ensue that everything has been compressed into the smallest capacity possible.
2 - When you are certain that you have backed up the drive completely, remove the older drive
3 - Line up the new drive and the old drive and ensure the jumpers are set to the same settings as they were set on the older HDD.
4 - Once you are sure, you then restore everything from the back-up drive for the old hdd to the new disk drive.
5 - Test to ensure that everything from the old drive has been backed up from the old drive to the new drive.
6 - If you are comfortable that your backup has been completly restored from the backup meda to the new, larger hard drive, then be certain that you have restored from the older drive to the new drive, tighten all screws and cables, then close all ports and ensure that everything has been done properly by and for you.
7 - Be certain that you have created the same user accounts in the new drive as you had on the older drive.
8 - Now, power off the new drive while in the laptop. Wait about 30 seconds to one minute, then restart the new hard disk drive.
9 Test everything, to be sure that everything works properly. Go through everything from the top of the menu to the bottom of the menu. Try all accessories, try all applications. Ensure that all works right and that the applications work as they used to work, when it was on the old drive.
10 - Remember, you have a warranty on the new HDD, so be sure that you have tested everything to ensure that it all works properly, before you sign off on this new drive.
11 - Once you are certain that it all works correctly, you can then be sure that it is working properly and competely, because only you know if things are working correctly as they should be.
12 - Then you can sign off and you can be sure that things work properly.
13 - As carpenters say ... measure twice; cut once. You can only do this one time, so if you measure it more than one tim, you can be certain that you will get it done correctly and be happy that you did it right. from beginning to end.
Have fun. Don't be too serious about it, but do be careful, and get it right. Remember, get it right the first time, and you will be pleased with the results at the end.
Posted on Jun 22, 2009
  • 2291 Answers
SOURCE: I have no sound from my Toughbook CF-29. I have
Open the Control panel 2. Open the "Sounds and Audio Devices" icon. 3. Verify the "Place volume icon in the taskbar" checkbox is checked. If this option is not available or is grayed out, skip to the next section of this document. 4. If you were able to check this box, click ok and close out of this window and the Control Panel. 5. Double-click the sound icon in the Systray and verify that all the sound volumes are mid-way or higher.
Check Windows services. Right Click My Computer and Manage. Choose Services and Application > Services. Choose "Windows Audio" and set to Automatic and Start. Now next you can do is If you open control panel & click device manager the window that opens will show a list of all installed hardware. Look for anything with an exclamation mark beside it, or to do with sound. If you see anything, right click it, check it isn't Disabled then select "Properties." The next window should have some tabs along the top, the one you are looking for is "Driver," you should now see an "Update driver" button. Check ur sound card information by doing this Click on start menu Click on Run Type dxdiag, enter Click on the sound tab There is button of test direct sound click on this check if there is sound Check ur registry. Check if the sound registry key is enabled or disabled. There could be an error in registry, run registry cleaner reg in out to scan for errors.
Posted on Oct 06, 2010
How do you get to the CF-29 diognostic test
All Panasonic Toughbooks built after 2009 or 2010
have a built-in DIAGNOSTIC utility Built-In at the
BIOS Level. Simply press the F2 function key while
booting and go to the last TAB (Usually SAVE/EXIT).
You will find the diagnostic utility at the bottom
of the menu. This is true for the CF31 MK1+.
This is NOT true for the CF29 which was built
between 2004 and 2006. Instead I would use a
CD Boot Disk like HIREN Boot Disk which has some
great diagnostic utilities. I like both Hiren 10.0 + 15.1.
http://www.hirensbootcd.org/
Good Luck.
Regards,
Richard - Montreal Based
Panasonic Toughbook Authorized Dealer since 1989.
May 06, 2014 | Panasonic Toughbook CF-29 Notebook
Remove bios password for a panasonic toughbook cf-30k
  • Press "F2" on your keyboard when you see the Panasonic logo appear on the screen. You will immediately be prompted to enter your Panasonic Toughbook Cf-29 BIOS password. Type the word "Biostar" into the password prompt. This is your Panasonic Toughbook Cf-29 backdoor BIOS password. Press the "Enter" key to unlock your Panasonic Toughbook Cf-29 BIOS.
  • Mar 10, 2014 | Panasonic Toughbook CF-30K (CF-30K3PAQAM)...
    Cf-29 no operating system
    You will require the internal Panasonic Toughbook CF29 optical drive (DVD). The cost of such a drive (used) in should be $50 or less.
    You will also require a Windows 7 DVD.
    You may be able to download an ISO file and burn your own.
    Try this Microsoft Website:
    https://www.microsoft.com/en-ca/software-download/windows7
    You must use the 32-bit version, NOT the 64-bit version.
    Please remember to set the DVD as the first boot device in the BIOS of the CF29.
    That is it. Good Luck and Best Regards from:
    Richard, Montreal Based Panasonic Canada Authorized Toughbook Dealer since 1989.
    Jan 27, 2014 | Panasonic Toughbook 34 PC Notebook
    Where is the fuse to the panasonic cf 29 laptop
    Here is the service manual for it. This should help
    http://www.scribd.com/doc/52162841/panasonic-CF-29-SM
    Sep 02, 2012 | Panasonic Toughbook 29 Touch (P/N...
    Battery calibration for cf-29 panasonic laptop download
    On the Panasonic Toughbook CF29 MK1 Model,
    the Battery Recalibration application is actually
    built-in on the BIOS. On all other models, it is
    a downloadable software located at this website:
    http://pc-dl.panasonic.co.jp/itn/drivers/d_menu_en.html
    Please remember to choose your operating system
    and then find the Battery Recalibration Application.
    Finally click on the "Download Now" button located
    on the right hand side.
    Good Luck!
    Regards
    Panasonic Canada Toughbook Authorized Dealer since 1989
    Aug 21, 2012 | Panasonic Toughbook CF-29 Notebook
    Touch screen do not work
    Have you checked under the device manager in to make sure that all your peripherals are recognized or enabled in the bios
    A: Activate Touchscreen in Bios
    B: Reinstall all drivers
    C: ensure OS is recognizing the peripherals.
    Good Luck
    Apr 03, 2012 | Panasonic Toughbook 29 Touch (P/N...
    I require LAN drivers for my panasonic cf-29
    This depends on the specific model number:
    CF-29C/D -- Realtek RTL8139DL 10/100
    CF-29E/F -- Realtek RTL8139DL 10/100
    CF-29H/J -- Realtek RTL8139DL 10/100
    CF-29L/M -- Marvel Yukon 88E8053 10/100/1000
    CF-29N/P -- Marvel Yukon 88E8053 10/100/1000
    Dec 28, 2010 | Panasonic Toughbook CF-29 Notebook
    Panasonic Toughbook CF-29 Notebook Logo
    50 people viewed this question
    Top Panasonic Computers & Internet Experts
    micky dee
    Computer Repairing
    Computer Repairing
    Are you a Panasonic Computer and Internet Expert? Answer questions, earn points and help others
