Question about Siemens Dishwashers
Reprogram control module
Se26T252GB/90
I hsve a 2008 saturn sky base 2.4L. The dealer says I need a new body control module. My question does the new BCM require reprogramming? If it doesn't then I will replace myself. Thanks
Body Control Module (BCM) Replacement and Reprogramming
If the BCM is replaced or requires reprogramming, the following procedures must be performed in the specified order:
BCM Setup -- Using a scan tool, go to Vehicle Control Systems » Computer/Integrating Systems » Module Setup » Body Control Module. Select Setup BCM and follow the on-screen instructions, making sure to select the proper RPOs and input the VIN correctly.
BPP Sensor Calibration--Refer to Brake Pedal Position Sensor Calibration
Program Key Fobs--Refer to Transmitter Programming
Setup SDM Part Number in BCM -- Using a scan tool, go to Vehicle Control Systems » Computer/Integrating Systems » Module Setup » Body Control Module. Select Setup SDM Part Number in BCM and follow the on-screen instructions.
Dec 28, 2016 | Saturn Cars & Trucks
Bcm removal on 2008 saturn outlook
Component Name
Preliminary Procedure Remove the left side instrument panel insulator panel. Refer to Instrument Panel Insulator Panel Replacement - Left Side .
Body Control Module
Procedure
  1. Disconnect the electrical connectors.
  2. Reprogram the module if replaced. Refer to Control Module References .
Tip
Push tab to release the body control module from the bracket.
Jul 22, 2015 | Saturn Cars & Trucks
Don't tell me what to do....
Ok seriously, which module are you interested in reprogramming and why?
All of the modules on this vehicle require at least a Tech-2 scan tool and subscription to GM's technical information service.
Still not dissuaded? Well if you program certain modules incorrectly you will lose the odometer reading and have it reset to ZERO miles.... yes you can make your car virtually worthless in less than 5 minutes.
Feb 15, 2015 | 2003 Saturn L-Series
How to reprogram my 98 chevy tahoes electronic control module
ECM, Engine control module. You can't do it. There are shops that can do it, but most likely a dealership.
Jul 23, 2014 | 1998 Chevrolet Tahoe
Where abs control module located?can i just replace part or it has to be reprogrammed?
remove the battery and battery tray , the abs module and pump are locate there, if you have the original module repaired then you wont have to have it reprogrammed, if you go for a new module then it will need reprogramming
Jul 04, 2014 | 2004 Mercury Sable
03 Escape radio volume raises by itself. What could be the problem ?
Assuming your truck has cruise control, this has been a common thing with these vehicles. The radio's volume is designed to increase if the vehicle's Body Control Module sensed that:
-you rolled a window down
-you accelerated
Ford's recommended repair is to reprogram the BCM. Runs about $90-120 at most dealers.
May 08, 2014 | 2003 Ford Escape
Where's the coolant level sensor located on a 6.0 '02 Chevy 2500 HD Silverado?
this might be important for you to know
Quote:
08-08-49-002: False Triggering of Low Coolant Level Warning Message (Reprogram HVAC Control Module) - (Feb 13, 2008)
Subject:
False Triggering Of Low Coolant Level Warning Message (Reprogram HVAC Control Module)
Models:
2007-2008 Chevrolet Silverado 2500 and 3500 Heavy Duty Series Only
2007-2008 GMC Sierra 2500 and 3500 Heavy Duty Series Only
with 6.6L Diesel Engine (VIN 6 -- RPO LMM)
Condition
Some customers may comment that a "COOLANT LEVEL LOW ADD COOLANT" message is displayed in the Driver Information Center (DIC) even though the coolant level is normal.
Cause
This condition may be caused by a false reading during off-road driving or in high slush conditions.
Correction
Do This - Reprogram the HVAC control module.
Don't Do This - Do not replace the coolant level sensor, HVAC control module or radiator surge tank.
A revised calibration has been developed to address this condition. Technicians are to reprogram the Heating Ventilation and Air Conditioning (HVAC) control module with the latest software available on TIS2WEB. Refer to the Service Programming System procedures in SI. As always make sure your Tech 2 is updated with the latest software version.
Warranty Information
For vehicles repaired under warranty, use:
Labor: Operation D4707
Description: HVAC Control Head Module or Assembly Reprogramming with SPS
Labor Time: Use Published Labor Operation Time
Dec 02, 2013 | 2002 Chevrolet Silverado 2500HD
What is ecm update
A ecm update is a reprogramming of the engine control module the dealer will reprogram the engine control module with new priamiters .
Oct 07, 2010 | 2007 Hyundai Azera Limited Sedan
DISABLING SERVICE RIDE CONTROL via REPROGRAMMED BCM
bottom of sterring colum under under trim panel
Jul 19, 2009 | 2005 GMC Yukon Xl Denali
Dishwashers Logo
90 people viewed this question
Top Siemens Dishwashers Experts
valuesrespec
aliasger yq
Are you a Siemens Dishwasher Expert? Answer questions, earn points and help others
