Question about THE SHARPER IMAGE Deluxe 4-piece Professional Corkscrew Set
How can I get another worm for Professional Corkscrew Set
Worm is warped and has to be replaced. Have used both. Need to get new worm
  • 778 Answers
Hello, You will have to go back to the manufacturer cust. service and ask them if they have replacement.
Posted on May 16, 2014
I need a new worm gear for my Kitchen Aid kp2671xcv but I think that model is discontinued. Can I use a worm gear from a similar model?
This is the Professional 6 quart model and parts are available for it.
I can send you a PDF file of the service manual if you will contact me at srbell@myfairpoint.net.
Oct 11, 2014 | KitchenAid KP2671 Mixer Transmission...
PS2 Worm motor
The problem can get to the point where the game won't even load. What is happening is there is a little white plastic gear with 2 teeth that screws onto the laser. Those teeth ride into the grooves on the worm gear motor shaft. As the shaft turns the little laser gear moves the laser back and forth. After time those little teeth that are suppose to be flat wear a tiny bit and have troughs wore in them. This allows it to slip off the worm gear shaft causing the clicking noise. you simply remove it and use white lithium grease and replace it and it will work like a new one.
I hope this helps!
Jul 14, 2013 | Sony PlayStation 2 (PS2) Console
I need a new worm gear for my fisher price starlight papasan cradle swing.
I found a set of worm gears that has 2 of the gears you need.
Google search, worm gear svm-103. It is a packet with a lot of worm gears but the 2 big ones work perfectly.
Jul 05, 2012 | Fisher Price Starlight Papasan Cradle...
The motor is making a grinding noise. The mixer still works, it just sounds weird.
I have fixed many mixers with the same problem. The only part that consistently wears out
is the Worm Gear Follower located inside the Transmission housing. The teeth are wearing out
and becoming chipped. The grinding noises you hear are made by the Worm Gear and the
Follower. As time goes on, the metal filings from the damaged follower will eventually destroy the Follower and the Planetary will stop rotating.
Sooner or later that gear need to be replaced. Also remember to use new Grease after
a new gear replacement (metal filings from the old gear will damage your new gear)
Apr 02, 2011 | KitchenAid KP2671 Professional 6 Series...
I have cleaned the worm and Gear segment for blade raising mechanism on my 66 and it still binds and is stiff. What do I do next?
Try lubricating with silicone spray. I use it for just such things, and I'm happy with how it works. Also, clean and lubricate the lock on the elevation control.
--W/D--
Jan 29, 2011 | Powermatic 66 10" 3 HP 1 Phase 230V Table...
What would cause my John Deere Sabre 25hp 54"cut to be hard to steer ?
Your tractor has a simple worm gear turning another worm gear system.Either the one of the spindles in the front wheels is sticking or the worm gear is not meshing or you need to replace the worm gear on the steering shaft it's self.Also,if the tie rods are not set right then the wheels may turn hard,set the tie rods so that they have 1 to 1 and 3/4 inches of tow in in the front wheels.
Sep 12, 2010 | John Deere 420,1020,2010,2020,2510,2520...
While kneading bread my mixer suddenly starting hanging up at the back side. It makes the full circle but when it gets to the back it stops and "hums" and then sometimes will go on but most of the time...
It sounds like you have lost some teeth from your worm gear. This usually happens when the mixer has been overloaded. The teeth on the worm gear are designed to fail first to prevent more serious damage. To replace the part you will need to open the head on your mixer. The gears are at the front of the mixer packed in grease. It should be obvious that the worm gear has broken once the head is open. If it is not the worm gear, with the head open it should be easy to spot the problem. The gears are available as spare parts from several places on the internet. search for "kitchenaid worm gear"
Feb 01, 2010 | KitchenAid KP2671 Professional 6 Series...
I need a worm wheel for a Honda minitiller FG100.
You can buy parts for this from www.petessmallengine.com
I had to replace the tine shaft w/worm wheel assy. This is usually the weak point in the transmission. The worm is made out of brass.
Jan 03, 2010 | Honda 25cc 4-cycle Mini Tiller
Cannot access anti-virus websites
Download STINGER antivirus and scan with this tool.
Variants Can Detect:
BackDoor-ALI,BackDoor-AQJ,BackDoor-AQJ.b,BackDoor-CEB,BackDoor-CEB!bat,BackDoor-CEB!hosts,BackDoor-CEB.b,BackDoor-CEB.c,BackDoor-CEB.d,BackDoor-CEB.dll,BackDoor-CEB.dr,BackDoor-CEB.e,BackDoor-CEB.f,BackDoor-CEB.sys,BackDoor-CFB,BackDoor-JZ,BackDoor-JZ.dam,BackDoor-JZ.dr,BackDoor-JZ.gen,BackDoor-JZ.gen.b,Bat/Mumu.worm,Cleanup,CoreFlood,Coreflood!psexec,Coreflood.dldr,CoreFlood.dll,CoreFlood.dr,Danmec,Downloader-DN.a,Downloader-DN.b,Downloader-UA,Exploit-DcomRpc,Exploit-DcomRpc.b,Exploit-DcomRpc.dll,Exploit-Lsass,Exploit-Lsass.dll,Exploit-MS04-011,Exploit-MS04-011.gen,Exploit-MSExcel.k,Exploit-MSExcel.l,Exploit-MSExcel.m,Exploit-MSExcel.n,Exploit-MSExcel.o,Exploit-MSExcel.p,Exploit-MSExcel.q,Exploit-MSExcel.r,Exploit-PDF.b,Exploit-PDF.c,Exploit-PDF.d,Exploit-PDF.e,Exploit-PDF.f,Exploit-PDF.g,Exploit-PDF.h,Exploit-XMLhttp.d,Exploit-XMLhttp.d.gen,Exploit-XMLhttp.d.gen.b,Exploit-XMLhttpd.d,FakeAlert,FakeAlert-AA,FakeAlert-AB,FakeAlert-AB!htm,FakeAlert-AB.dldr,FakeAlert-AB.dr,FakeAlert-AC,FakeAlert-AD,FakeAlert-AE,FakeAlert-AF,FakeAlert-AG,FakeAlert-AG.gen.b,FakeAlert-AG.gen.c,FakeAlert-AH,FakeAlert-AI,FakeAlert-AJ,FakeAlert-AK,FakeAlert-AL,FakeAlert-AM,FakeAlert-AN,FakeAlert-AntiVirusPro,FakeAlert-AntiVirusXP,FakeAlert-AO,FakeAlert-AP,FakeAlert-AQ,FakeAlert-AR,FakeAlert-AS,FakeAlert-AT,FakeAlert-AU,FakeAlert-av360,FakeAlert-AW,FakeAlert-AZ,FakeAlert-AZ!htm,FakeAlert-B,FakeAlert-B.dldr,FakeAlert-B.dr,FakeAlert-BA,FakeAlert-BB,FakeAlert-BC,FakeAlert-BD,FakeAlert-BE,FakeAlert-BE.gen,FakeAlert-BF,FakeAlert-BG.dldr,FakeAlert-BH.dldr,FakeAlert-BI,FakeAlert-BJ,FakeAlert-BK,FakeAlert-BL,FakeAlert-BM,FakeAlert-BN,FakeAlert-BO,FakeAlert-BO.dldr,FakeAlert-BP,FakeAlert-BQ,FakeAlert-BR,FakeAlert-BS,FakeAlert-C,FakeAlert-C.dr,FakeAlert-C.gen,FakeAlert-D,FakeAlert-E,FakeAlert-F,FakeAlert-G,FakeAlert-H,FakeAlert-I,FakeAlert-J,FakeAlert-K,FakeAlert-L,FakeAlert-LastDefender,FakeAlert-M,FakeAlert-N,FakeAlert-N.dldr,FakeAlert-O,FakeAlert-P,FakeAlert-Q,FakeAlert-R,FakeAlert-S,FakeAlert-S.dll,FakeAlert-SpyKiller,FakeAlert-SpywareGuard,FakeAlert-T,FakeAlert-U,FakeAlert-V,FakeAlert-W,FakeAlert-WinwebSecurity,FakeAlert-X,FakeAlert-XPAntivirus,FakeAlert-XPSecCenter,FakeAlert-Y,FakeAlert-Y.dr,FakeAlert-Z,Fribet,Generic FakeAlert,Generic FakeAlert.d,Generic FakeAlert.e,Generic!atr,HideWindow,HideWindow.dll,HTool-T2W,IPCScan,IRC/Flood.ap,IRC/Flood.ap.bat,IRC/Flood.ap.dr,IRC/Flood.bi,IRC/Flood.bi.dr,IRC/Flood.cd,JS/Autorun.worm.ci,JS/Downloader-AUE,JS/FakeAlert,JS/FakeAlert-AB.dldr,NTServiceLoader,ProcKill,Proxy-Agent.af,Proxy-Agent.af.dr,PWS-Banker.dldr,PWS-FireMing,PWS-FireMing.dll,PWS-FireMing.dr,PWS-Gamania.gen.a,PWS-Narod,PWS-Narod.dll,PWS-Narod.gen,PWS-Sincom,PWS-Sincom.dll,PWS-Sincom.dr,rootkit,VBS/Autorun.bj,VBS/Autorun.worm.au,VBS/Autorun.worm.ay,VBS/Autorun.worm.bi,VBS/Autorun.worm.bj,VBS/Autorun.worm.bs,VBS/Autorun.worm.by,VBS/Autorun.worm.ca,VBS/Autorun.worm.cy,VBS/Autorun.worm.dm,VBS/Autorun.worm.dn,VBS/Autorun.worm.dn!atr,VBS/Autorun.worm.dn!txt,VBS/Autorun.worm.dv,VBS/Autorun.worm.dz,VBS/Autorun.worm.en,VBS/Autorun.worm.k,VBS/Autorun.worm.k!bat,VBS/Autorun.worm.zd,VBS/Autorun.worm.ze,VBS/Autorun.worm.zl,VBS/Autorun.worm.zn,VBS/FakeAlert-AB,VBS/IE-Title,Vundo,Vundo.dldr,Vundo.dr,Vundo.gen.h,Vundo.gen.i,Vundo.gen.j,Vundo.gen.k,Vundo.gen.l,Vundo.gen.m,Vundo.gen.n,Vundo.gen.o,Vundo.gen.p,Vundo.gen.r,Vundo.gen.s,Vundo.gen.t,Vundo.gen.u,W32/Anig.worm,W32/Anig.worm.dll,W32/Autorun.worm,W32/Autorun.worm!inf,W32/Autorun.worm!ini,W32/Autorun.worm.a,W32/Autorun.worm.aa,W32/Autorun.worm.ab,w32/autorun.worm.ac,W32/Autorun.worm.ad,W32/Autorun.worm.ae,W32/Autorun.worm.af,W32/Autorun.worm.ag,W32/Autorun.worm.ai,W32/Autorun.worm.aj,W32/Autorun.worm.ak,W32/Autorun.worm.al,W32/Autorun.worm.am,W32/Autorun.worm.an,W32/Autorun.worm.ao,W32/Autorun.worm.ap,W32/Autorun.worm.aq,W32/Autorun.worm.ar,W32/Autorun.worm.as,W32/Autorun.worm.at,W32/Autorun.worm.av,W32/Autorun.worm.aw,W32/Autorun.worm.ax,W32/Autorun.worm.az,W32/Autorun.worm.b,W32/Autorun.worm.b.cfg,W32/Autorun.worm.ba,W32/Autorun.worm.bb,W32/Autorun.worm.bc,W32/Autorun.worm.bd,W32/Autorun.worm.be,W32/Autorun.worm.bf,W32/Autorun.worm.bg,W32/Autorun.worm.bh,W32/Autorun.worm.bk,W32/Autorun.worm.bl,W32/Autorun.worm.bm,W32/Autorun.worm.bn,W32/Autorun.worm.bo,W32/Autorun.worm.bp,W32/Autorun.worm.bp!reg,W32/Autorun.worm.bq,W32/Autorun.worm.br,W32/Autorun.worm.bt,W32/Autorun.worm.bw,W32/Autorun.worm.bx,W32/Autorun.worm.bx!inf,W32/Autorun.worm.bx.gen,W32/Autorun.worm.bz,W32/Autorun.worm.c,W32/Autorun.worm.cb,W32/Autorun.worm.cb.dr,W32/Autorun.worm.cc,W32/Autorun.worm.cd,W32/Autorun.worm.ce,W32/Autorun.worm.cf,W32/Autorun.worm.cg,W32/Autorun.worm.ch,W32/Autorun.worm.cj,W32/Autorun.worm.ck,W32/Autorun.worm.cm,W32/Autorun.worm.cn,W32/Autorun.worm.co,W32/Autorun.worm.cp,W32/Autorun.worm.cp!bat,W32/Autorun.worm.cq,W32/Autorun.worm.cr,W32/Autorun.worm.cs,W32/Autorun.worm.ct,W32/Autorun.worm.cu,W32/Autorun.worm.cv,W32/Autorun.worm.cw,W32/Autorun.worm.cx,W32/Autorun.worm.cz,W32/Autorun.worm.d,W32/Autorun.worm.da,W32/Autorun.worm.db,W32/Autorun.worm.dc,W32/Autorun.worm.dd,W32/Autorun.worm.dd!inf,W32/Autorun.worm.de,W32/Autorun.worm.df,W32/Autorun.worm.dg,W32/Autorun.worm.dh,W32/Autorun.worm.di,W32/Autorun.worm.dj,W32/Autorun.worm.dk,W32/Autorun.worm.dl,W32/Autorun.worm.dn,W32/Autorun.worm.do,W32/Autorun.worm.dp,W32/Autorun.worm.dq,W32/Autorun.worm.ds,W32/Autorun.worm.dt,W32/Autorun.worm.du,W32/Autorun.worm.dw,W32/Autorun.worm.dx,W32/Autorun.worm.dy,W32/Autorun.worm.e,W32/Autorun.worm.ea,W32/Autorun.worm.eb,W32/Autorun.worm.ec,W32/Autorun.worm.ed,W32/Autorun.worm.ef,W32/Autorun.worm.eg,W32/Autorun.worm.ei,W32/Autorun.worm.ej,W32/Autorun.worm.ek,W32/Autorun.worm.el,W32/Autorun.worm.em,W32/Autorun.worm.eo,W32/Autorun.worm.ep,W32/Autorun.worm.eq,W32/Autorun.worm.f,W32/Autorun.worm.g,W32/Autorun.worm.gen!job,W32/Autorun.worm.gen.cl,W32/Autorun.worm.gen.za,W32/Autorun.worm.gen.zb,W32/Autorun.worm.h,W32/Autorun.worm.h!lnk,W32/Autorun.worm.i,W32/Autorun.worm.j,W32/Autorun.worm.l,W32/Autorun.worm.m,W32/Autorun.worm.n,W32/Autorun.worm.o,W32/Autorun.worm.p,W32/Autorun.worm.q,W32/Autorun.worm.r,W32/Autorun.worm.remmants,W32/Autorun.worm.s,W32/Autorun.worm.t,W32/Autorun.worm.u,W32/Autorun.worm.v,W32/Autorun.worm.v!bat,W32/Autorun.worm.w,W32/Autorun.worm.x,W32/Autorun.worm.y,W32/Autorun.worm.z,W32/Autorun.worm.zc,W32/Autorun.worm.zf,W32/Autorun.worm.zg,W32/Autorun.worm.zh,W32/Autorun.worm.zi,W32/Autorun.worm.zj,W32/Autorun.worm.zk,W32/Autorun.worm.zm,W32/Bagle,W32/Bagle!eml.gen,W32/Bagle!pwdzip,W32/Bagle.ad!src,W32/Bagle.dldr,W32/Bagle.dll.dr,W32/Bagle.eml,W32/Bagle.fb!pwdzip,W32/Bagle.fc!pwdzip,W32/Bagle.fd!pwdzip,W32/Bagle.fe!pwdzip,W32/Bagle.fm.dldr,W32/Bagle.gen,W32/Bagle@MM!cpl,W32/Blaster.worm,W32/Blaster.worm.k,W32/Bropia.worm,W32/Bugbear,W32/Bugbear.a.dam,W32/Bugbear.b!data,W32/Bugbear.b.dam,W32/Bugbear.gen@MM,W32/Bugbear.h@MM,W32/Bugbear@MM,W32/Conficker,W32/Conficker.sys,W32/Conficker.worm,W32/Conficker.worm!inf,W32/Conficker.worm!job,W32/Conficker.worm.gen.a,W32/Conficker.worm.gen.b,W32/Deborm.worm.ah,W32/Deborm.worm.gen,W32/Doomjuice.worm,W32/Dumaru,W32/Dumaru.ad@MM,W32/Dumaru.al.dll,W32/Dumaru.dll,W32/Dumaru.eml,W32/Dumaru.gen,W32/Dumaru.gen@MM,W32/Dumaru.w.gen,W32/Elkern.cav,W32/Elkern.cav.c,W32/Elkern.cav.c.dam,W32/Fizzer,W32/Fizzer.dll,W32/Fujacks!htm,W32/FunLove,W32/FunLove.apd,W32/Gaobot.worm,W32/Harwig.worm,W32/IRCbot,W32/IRCbot.worm,W32/IRCbot.worm.dll,W32/Klez,W32/Klez.dam,W32/Klez.eml,W32/Klez.gen.b@MM,W32/Klez.rar,W32/Koobface.worm,W32/Korgo.worm,W32/Lirva,W32/Lirva.c.htm,W32/Lirva.eml,W32/Lirva.gen@MM,W32/Lirva.htm,W32/Lirva.txt,W32/Lovgate,W32/Mimail,W32/Mimail.c@MM,W32/Mimail.i!data,W32/Mimail.q@MM,W32/MoFei.worm,W32/MoFei.worm.dr,W32/Mumu.b.worm,W32/Mydoom,W32/Mydoom!bat,W32/Mydoom!ftp,W32/Mydoom.b!hosts,W32/Mydoom.dam,W32/Mydoom.t.dll,W32/Mytob,W32/Mytob.gen@MM,W32/Mytob.worm,W32/MyWife,W32/MyWife.dll,W32/MyWife@MM,W32/Nachi!tftpd,W32/Nachi.worm,W32/Netsky,W32/Netsky.af@MM,W32/Nimda,W32/Nimda.dam,W32/Nimda.eml,W32/Nimda.gen@MM,W32/Nimda.htm,W32/Nuwar,W32/Nuwar.dam,W32/Nuwar.sys,W32/Nuwar@MM,W32/Nuwar@MM!rar,W32/Pate,W32/Pate!dam,W32/Pate.dam,W32/Pate.dr,W32/Polip,W32/Polip!mem,W32/Polybot,W32/Polybot.bat,W32/Sasser.worm,W32/Sasser.worm!ftp,W32/Sdbot,W32/Sdbot!irc,W32/Sdbot.bat,W32/Sdbot.cli,W32/Sdbot.dll,W32/Sdbot.dr,W32/Sdbot.worm,W32/Sdbot.worm!ftp,W32/Sdbot.worm.bat.b,W32/Sdbot.worm.dr,W32/Sdbot.worm.gen,W32/Sdbot.worm.gen.a,W32/Sdbot.worm.gen.b,W32/Sdbot.worm.gen.c,W32/Sdbot.worm.gen.d,W32/Sdbot.worm.gen.e,W32/Sdbot.worm.gen.q,W32/Sober,W32/Sober!data,W32/Sober.dam,W32/Sober.eml,W32/Sober.f.dam,W32/Sober.g.dam,W32/Sober.q!spam,W32/Sober.r.dr,W32/Sober.r@MM,W32/Sobig,W32/Sobig.dam,W32/Sobig.eml,W32/Sobig.f.dam,W32/Sobig.gen@MM,W32/Spybot.worm,W32/SQLSlammer.worm,W32/Swen,W32/Swen@MM,W32/Virut,W32/Virut!mem,W32/Yaha.eml,W32/Yaha.gen@MM,W32/Yaha.y@MM,W32/Yaha@MM,W32/Zafi,W32/Zafi.b.dam,W32/Zindos.worm,W32/Zotob.worm,W32/Zotob.worm!hosts
Download v10.0.0.482 [2,641,920 bytes] (01/10/2009).
Hope this will be helpfull
Thanks & Regards
Nanda Kishore :)
Mar 25, 2009 | Microsoft Windows XP Professional
THE SHARPER IMAGE Deluxe 4-piece Professional Corkscrew Set Logo
529 people viewed this question
Top THE SHARPER IMAGE Home Experts
Donni Steen
Tom Chichester
Are you a THE SHARPER IMAGE Home Expert? Answer questions, earn points and help others
