Question about JVC Televison & Video
When i plug my usb in sometimes movies work other times they don't saying "Video Not Support" any idea how how to fix?
  • 778 Answers
Hello, Usb ports have a tendency to go to sleep. Short of reflashing the tv set, which only the manufacturer can do. There isn't anything but powering down the set and rebooting is all you can do.
Posted on May 16, 2014
Plasma tv how to
I suspect that with the age of the tv that it does not support videos from the USB drive. It will support update files for the tv itself which is normally something a technician would use it for.
Jun 10, 2017 | Televison & Video
USB ISSUES
I have music video and 3 movies download on my USB and when I tried to plug in it says unsupported format.
Mar 04, 2013 | Power Acoustik PTID7002NR Car DVD Player
It will not open. it will not open for me to put movies in.
I'm sorry to say this, but it looks like your motor that opens the slot is now unusable. It would not be a good idea to fix this, since it is really not worth the trouble. If you don't think this is the case, than check your user guide to find out what other problems it may be.
It may be a good idea to purchase a new DVD player. Try amazon for reviews before purchasing another DVD player. Sometimes DVD players aren't as good as they seem, trust me.
May 26, 2011 | RCA Televison & Video
I plug my passport in to my tv and cannot find my film
Do you see any other files?
If you see, then would you check the compatibility (or readable) of movie files from your TV? (Please, check TV manuals first.)
Although TV says it read a file, for example, 'AVI', it does not mean to play all AVI files.
When someone makes AVI, many codecs can be used like xvid, x264 for video and mp3, ac3, aac and so on.
If you don't see any of your files, copy those movie AND photo files into any usb flesh drive. Then plug in and test.
May 25, 2011 | Western Digital 1TB My Passport Essential...
Problem with usb port don`t work
Step 1
Before you start working on the USB port, make sure that your device is not the problem. If the computer says that the there is a new USB device but that it cannot use it, typically there is a problem with the device's driver and not the USB port. If this is the case, your best option is to re-install or upgrade the device driver. Try inserting the device to another computer. If the device works, most likely the problem is with the computer and not your device.
Step 2
Try rebooting the machine. Rebooting a computer resets all of the software to the default state and will clean up many issues. The start up process also checks all of the devices on the computer and can sometimes fix a USB port. First shut down the machine. Connect the USB device up to the computer and start it. This reboot will sometimes fix a bad USB port.
Step 3
Try attaching the USB device on to another USB port on the same computer. If the device now works, the old USB port probably has a hardware or BIOS issue. Skip to step 5 to try to fix a bad USB port through the BIOS. Fixing a hardware problem on a USB port requires working on the motherboard which is typically more expensive just adding a new USB ports.
Step 4
Uninstall your computer's USB device bus manager. The device manager controls the USB access and sometimes gets corrupted. Fixing the USB device manager requires administrator rights on the machine. The best way to uninstall the device bus manager is to right click on your computer's icon and select properties. This will bring up the hardware settings for your machine. Click on the hardware tab and select the device manager. The device manager lists all of the devices on the computer. The next step is to open up the "Universal bus controller" option. Right click on all of the items under this option and uninstall them. Once all of the devices have been removed, restart the machine with the USB device connected. Upon reboot, windows re-installs the USB device manager. Most of the time, this will fix the USB port.
Step 5
The next thing to try is to check the BIOS. Restart the machine and enter the BIOS setup screen. You should check to make sure all of the USB ports are active. If they are, you should try resetting the BIOS settings to the defaults. The BIOS reset will sometimes fix USB port. But if it does not you will have to consider upgrading the BIOS. Upgrading a computer BIOS is very dependent on the motherboard manufacturer and you will have to visit your computer manufacturer's web site for detailed instructions.
Step 6
The last trick to try to fix a USB port is to repair your OS. Sometimes the USB drivers can get corrupted and break the USB ports. You can reinstall the system files onto the computer which should fix the USB port. Your data files should not be changed in this process, but it is a good idea to do a full backup of the computer ahead of time. In windows, an OS re-install is done by loading up the windows installation CD/DVD and selecting the repair windows installation. Just follow the steps and you often have a fixed USB port at the end of the process.
Please rate me if this solution works for you
Thanks......Have a great time.
Aug 12, 2010 | Dell OptiPlex 210L PC Desktop
When I hook up my Sansa mp3 player to either delete or load music my computer says it doesn'r recognize the usb port
Hello
I am not saying that this is the correct solution, but is works for me each time. Just plug the mp3 player into one of the usb ports on at the back of your computer case.
One other thing you can try is:
Simply UNPLUG YOUR COMPUTER FROM THE POWER SUPPLY. Yes that’s it! Note that this does not mean just turning off your computer because modern computers don’t really turn off when you press the power button as the motherboard still gets power.
First to explain, the motherboard is where all of hardware of the computer is connected to, including the USB ports. Sometimes the motherboard needs to be “rebooted” also because something can go wrong, i.e. all your USB ports suddenly stop working. The small microprocessor on the motherboard will reload the drivers and your USB ports should be back to recognizing all devices!
So first turn off your computer using Shut Down or pressing the power button and then UNPLUG it from the wall outlet. Let it sit for about a minute and then plug it back in.
Hope this can help you in fixing that pesky “USB device not recognized” Windows error!
Kind regards
Andrea
Nov 13, 2009 | SanDisk Sansa m250 MP3 Player
Uploading Flip videos to Windows Movie Maker
Flip Video Converter is a gorgeous application for Flip video camcorder (the Flip Ultra, the Flip Ultra HD, the Flip Video Mino, and the Flip Video Mino HD) users to import Flip video files into Window Movie Maker for editing, like crop out black sides, trim video clips, merge multiple flip videos into one file, and add special effects.
spacer.gif icobuy.gif Buy Now spacer.gif icon-downarrow.gif Free Download Flip Video to Windows Movie Maker spacer.gif How to use Flip Video Converter
How to import Flip video files into Windows Movie Maker (avi, mpeg-1, wmv)?
Step 1: Connect Flip video to Computer
Slide USB latch down. USB arm flips up automatically and then plug it into USB port on computer. Save your flip video files to your computer with FlipShare, a built-in software that makes organizing, editing, and sharing video incredibly simple.
Step 2: Launch Flip Video Converter
Open the captured Flip video files from your hard disk, and add them into Flip Video Converter, you can load one or more flip video files or the whole video folder at one time. The loaded files would be shown in the info list.
Step 3: Edit video-Trim, Crop, Effect
Trim: By setting the start time and end time for flip video, you can get your most wanted video clips.
Crop: Drag and drop the dashed-lines around the video, you can cut out the unwanted black sides.
Effects: You can get personalized videos by adding vivid effects, like Gray, Emboss, and Old film.
Step 4: Output Settings
Profile: Select your target video type from the drop-down list. AVI, MPEG-1, WMV is fit for Windows Movie Maker.
Output: Specify the output folder the ready-to convert files.
Settings: Click it, you can set exact video audio parameters in the pop-up window.
Merge into one file: Tick it, you can join several flip video files into one file.
Aug 08, 2009 | Pure Digital Flip Video Ultra Camcorder
When i plug in the jumpdrive on any computer it says USB device not recognized, please help
Well, it’s a super simple solution! No need to edit the registry, uninstall drivers, or anything of that sort.
Hope this helps someone fix that pesky “USB device not recognized” Windows error!
P.S. if it is a laptop, power up the laptop with just the batteries, not plugged in to fix this issue.
Give this a try and come back to tell us if it worked or not.
May 18, 2009 | Lexar FireFly 2GB USB 2.0 JumpDrive
Sound and video playback do not match
No button or any control to rectifier this problem. Depend the movies quality when you fast forward the system control and audio video processing or it call out MPEG2 chipset they run like double speed sometimes it not fast enough then you end up with sound and video not SYNC however you can fix that by remove AC lead for 30sec then plug in back now it should work OK or when you fast forward use X8 or X16 NOT X32 times specialy with DVD copy
Alternatifly if your DVD player still under warranty it might have a update firmware to correct this problem
Cheers
Nov 01, 2008 | Philips DVP5140 DVD Player
SimpleTech hard drive not found by my computer
This may or may not help, but it worked for me! After about 4 hours of trying everything (Device Manager/Uninstall, Disk Management, etc..) nothing at all would work. The USB external hard drive would power up but when you plug it in, the New Found Hardware will pop up and search unsuccessfully for drivers for a PLUG AND PLAY external drive!?!?!
In any event, I simply plugged another USB drive into my laptop (and desktop) and viola! The new hard drive was recognized and installed immediately as 'plug and play' should do. I then unplugged the new drive and tried plugging in the one that was recognized and all of the sudden....IT WORKS AGAIN!!!!
This fix might not help anyone who doesn't have a second USB external drive, but you could try plugging another USB device in and get it to load and then unplug it and try your drive. It worked for me on my laptop and then I did the same thing to my desktop (which also wouldn't recognize it) and it worked on the desktop too! Problem solved for me, thank GOD!
Hopefully, this bypass can save you a few hours of google time and unwanted anguish. Like I said, you may not have another USB drive but try plugging in any other USB device until it loads and then unplug it and then plug in your USB drive that wasn't working. It worked perfectly for me.
Hope it helps!!!!
-BIRDMAN - BIRD ^v^
Oct 02, 2008 | SimpleTech SimpleDrive 250GB, 7200RPM,...
Televison & Video Logo
24 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
