Question about Sharp AR-5320 Black and White Copier
Serviceman code for sharp ar-m318 - Sharp AR-5320 Black and White Copier
  • 190 Answers
SOURCE: error code Sharp AR-M 257
The F2-04 error code you are getting is that you are using the wrong toner.It may be form sharp,but it toner chips is different.Only the chips swapping at the toner back can help you.
Posted on Jan 27, 2009
  • 62 Answers
SOURCE: sharp ar-m350u error code h5-01. How do I fix
vheck this link out http://www.fixya.com/support/t1570580-remove_h5_01_error_code_sharp_arm550n
Posted on Apr 15, 2009
  • 990 Answers
SOURCE: sharp ar 407
Hello sir;There have a procedure to reset;
1, press "program", "interupt", "clear", "interupt"
2, enter 14, then press start,then enter 0, press start again. then press clear.
Posted on Apr 28, 2009
SOURCE: sharp ar-m205 error code E7 11
U HAVE TO UPGRADE THE FIRM WARE BY ENTERING SIMULATION 49-1 THE VALUE IS d THEN UPDATE THE FIRM WARE IF U HAVE IT
Posted on Jun 06, 2009
M2Tech1
  • 313 Answers
SOURCE: ERROR CODE U2-40: SHARP AR 5127
ERROR CODE U2-4 COULD BE RELATED TO THE MEMORY BATTERY BEING DEAD ON TEH MAIN BOSRD IF IT IS AN OLD MACHINE SO YOU COULD CHECK THSI OR REPLACE AND TRY WITH NEW
Posted on Jun 12, 2009
SHARP AR 5516 SHOWING RED HUMAN/STAR SYMBOL, please what could be the problem?
That's a serviceman light and the star (circle of dots) means your machine is due for a developer change.
Apr 25, 2017 | Sharp Office Equipment & Supplies
Copier show f9-88 sharp ar-m318/
That is a board communication error. Most of the time a simple restart of the machine will fix that. If it continues to come back it might be a hardware issue where some boards will need to be replaced, or sometimes fluctuating power can cause this error. Make sure you have the copier on it's own outlet/breaker.
Copier Collin Houston TX Copier and Imaging Expert
Jun 30, 2014 | Sharp AR-5316 Advanced Digital Imager...
Sharp ar 5516 maintenance reset
sharp ar 5516 showing ( - - - ) what's the solution
Sep 02, 2012 | Sharp AR-5316 Advanced Digital Imager...
Hi, Can someone help with resetting error H2-00 on sharp 168d
H2 00
[Content]
Thermistor open
[Detail]
The thermistor is open.
The fusing unit is not installed.
Cause Thermistor abnormality
Control PWB abnormality
Fusing section connector disconnection
[Check and remedy]
Check the harness and the connector between
the thermistor and the PWB.
Use TC 14 to clear the self diagnostic display.
To enter the serviceman test command mode, press the keys as
follows:
[#] key → [*] key → [C] key → [*] key
Enter 14 Start to clear the code.
Oct 26, 2009 | Sharp AR-168D Black and White Copier
After a power outage my printer is flashing H 4 can you tell me whats wrong? The printer is a Sharp AR-153E
Enter the serviceman simulation mode, press the keys as follows:
Clear → Density select → Clear→ Density select
then enter 14 and hit start. This will clear the H4 (low temperature) code. If you still have a problem, the code will come back. Then you will have to replace either the thermastat (fuse), thermistor or possibly the heat lamp.
Oct 03, 2009 | Sharp AR-153E Copier
I have a sharp 1r-168d copier. I have replaced the fuser assembly and now have a H2-00 error. I am unable to enter the servicemans mode to clear the self diagnostics
follows:
then enter Sim 14 then hit the start button and restart the machine.
Jun 23, 2009 | Sharp AR-168D Black and White Copier
I want code to reset the developer ccounter
After you replace developer, press #, interrupt, c , interrupt keys in that order. Display will go off, press 42 print 01 print for developer reset. Press Interrupt key twice and press 20 print 01 print for serviceman reset. Press CA key .
Apr 19, 2009 | Sharp AR-5316 Advanced Digital Imager...
SHARP AR 5316 error H4
The problem is in the fusing unit try these steps:
STEP1: Press continuously CLEAR then INTERRUPT then ZERO then INTERRUPT
STEP2: The panel display will turn off it means that you are inside the simulation if not repeat again step1.
STEP3.Then type 14 then press the print button
If these steps doesn't work you must call an authorized serviceman to check your machine, maybe something is busted on the fusing unit like thermostat or fusing lamp.
Mar 01, 2009 | Sharp AR-5316 Advanced Digital Imager...
How to install scaner kit
The scanning features is built in with the MFP. What u need to do is connect to the MFP, install the viewer driver, u can start scanning...
http://www.copiers.toshiba.com/media/downloads/support/drivers/GDI/vwr20-v101-drivers.exe
Apr 25, 2008 | Toshiba e-Studio 205 Copier
Sharp AR-5320 Black and White Copier Logo
75 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
CheckitRight
CheckitRight
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
