Question about Intel Acbel Power Supply Supports ATX 12V v2.0/ EPS 12V v2.1/AMD ATX-GES (PSACBEL) Power Supply
How to make a pc power unit work without a motherboard?
I'm making a "ghetto" cd player from my old CDRom, and my old power unit (it says acbel on it) isn't puting any power out without it being pluged into my motherboard. How can i make it work without damaging it?
  • 24 Answers
Here is a step-by-step solution I found online. Hope it helps!
How to power up an ATX Power Supply without PC
Posted on May 29, 2014
If you want to switch on PC Power adaptor alone, take bigest multiwire connector and shortcut GREEN wire with BLACK wire. GREEN is PS_ON and BLACK is Ground. There should be only one green and several black wires. All black are Ground.
Posted on May 28, 2014
There are two pins on the atx connector you need to bridge. You can wire a switch to the pins too if you want so you can toggle on and off. Otherwise, there is a guy on eBay (seller id: antronst) that sells a connector with the pins already bridged with a on/off switch and a resistor wired in to provide some stability for five or six dollars.
Here is a diagram. Make sure it is a standard atx power supply. Some old Dells had goofy wiring.
http://www.techpowerup.com/articles/other/22
Posted on May 24, 2014
How do i change dvd rom unit?
  1. Locate where your CD or DVD ROM drive connects to the motherboard and make a note of this. Make sure you know exactly how the gray cable was connected.
  2. Have the new DVD ROM drive handy and unplug and/or slide out (depending on setup) the old one. Unplug the cables from the appropriate places. You do not have to unplug the one going to the DVD ROM. Wiggle back and forth gently and then pull out.
  3. Attach your new cables and reattach to motherboard and power supply where you removed the old ones.
  4. Reattach the power cord and cables, but do not close up the computer entirely yet.
  5. Test your new DVD player by placing a disc in the drive and ensuring the green light comes on and you hear it power on. If this happens without a problem, then close up the case. If not, then check to make sure cables are securely fastened in the correct motherboard slots and to the power supply
May 18, 2010 | Computers & Internet
Cdrom driver not working
You don't update the bios unless you change to a newer processor,
that isn't supported by the version you have, if you find the system
is less stable then before, reflash to the old Bios.
There is no download for a cd or dvd rom, you only have downloads for chipset, graphics, sound, touchpads, ethernet, and a few other things.
Cd, dvd roms, use windows drivers,So you don't have to look for drivers.
There is something wrong with the unit, if you can plug in any other
cd or dvd and see if it works, to rule out motherboard problem.
If it works, you can see if is under warranty or you will have to get a new one.
Any questions, post back.
Feb 07, 2010 | MSI CR600-001US Notebook
NEED HELP ON PIONEER HEAD UNIT
get a variable power supply(ac to dc) that will get you 11-14 volts . You wont need a lot of amperes to run the deck.I had a buddy that just used a little car battery charger in his shop when he was jammin in there-kinda ghetto but hey it worked fine
Jan 14, 2010 | Pioneer DEH-2100 CD Player
No matter what i do cd rom not detecting
check whether the powe plug has been inserted properly and the power plug is working fine. Even though if the power plug inserted is working fine and CD ROM not detecting means CD ROM was damaged.
Sep 04, 2009 | Intel Motherboard
When I insert a cd inthe cdrom my pc restart!
check the cable connected from cd rom to the motherboard..try to replace it...
Feb 19, 2009 | ASUS P5LD2-VM Motherboard
I cannot boot windows xp
Hi praph_wicked, normal order would be, floppy drive first, CDROM second & Primary hard disk drive third.
How ever if your bios does not comply you can always press the F8 key every two seconds & that should bring up (Please select boot device). Which will look like this;
Choose the CDROM drive with the windows CD in it.
If you have just one CDROM drive, make sure the jumper on the back side of the CDROM is set to "Master". If you have two CDROM drives connected, set one as master & the other to slave.
If using an IDE cable for the two CDROM drives. The CDROM at the end of the data connector is to be set as master, the 2nd CDROM connects to the next IDE connector & Its jumper is set to slave.
Mike
Dec 13, 2008 | EliteGroup P4M800-M7 Motherboard
Cd/dvd player is not working
Hello, Follow the instruction:
Press power button and enter BIOS menu. (Bios menu: while PC make sound beep press button "delete")
You can see there BIOS menu. (Be carefully, don`t change anything if you can`t understand something) You have to find there general settings and in general settings you will see boot button.
There will be many boot buttons, but your settings must be that:
First boot: FDD (do not change it)
Second boot: HDD (do not change it)
Third boot: CDROM (if it is not, change it to CDROM or DVD/CDROM)
Sep 05, 2008 | Microsoft Windows XP Professional With...
I am not able to boot from cdrom of my system
Enter pc bios. can you see your cdrom listed in the MAIN menue? Goto Boot. Set your cdrom to first boot device.
Make sure you have a bootable CD in the cdrom. Still can't boot to the cdrom? Think about swapping it out or getting a new one.
Jan 17, 2008 | MSI KM4M-L Motherboard
Cd rw/dvd rw now working
If you know how to open your laptop, you can try seeing if the cable to the CDROM is connected properly. On startup, does your computer recognize the drive? If it's not the cable, you need a new cdrom drive.
Jan 10, 2008 | Dell Inspiron 1150 Latitude D600 14.1 LCD...
Installation problem
yah.. borrow some PC with cdrom working.. compy all files from installer cd to USB flash drive.. then install cam to your pc without cd rom.. or you can download installer from internet..
Jan 01, 2008 | Philips J44414
Intel Acbel Power Supply Supports ATX 12V v2.0/ EPS 12V v2.1/AMD ATX-GES (PSACBEL) Power Supply Logo
246 people viewed this question
Top Intel Computers & Internet Experts
Tony
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
