Need a manual for mitsubishi db130g sewing machine
Need manual to make shore set up right
    New Friend:
  • 12 Answers
I need to know what the settings need to be on the Kenmore 158 machine to use the buttonholer?
You'll have to provide more information about the sewing machine. 158 indicates the manufacturer. However, there are a lot of Kenmore sewing machines from that manufacturer. The 158.1340 manual is available here: https://www.manualslib.com/manual/150291/Kenmore-1340.html .
Page 40 (41 in the linked format) begins the section on buttonholes. With the buttonhole attachment, you need to set the stitch to the second narrowest zig-zag stitch. You can use any stitch length. The description of using the buttonhole attachment starts on page 45.
Without the buttonhole attachment, you set the stitch selector to each part of the buttonhole as you reach them. The stitch length dial has to be set to an appropriate length in the block for buttonholes. The top and bottom tack bars use the same stitch selector. There are separate ones for the left and right sides of the button hole.
I hope this helps. Please add a comment with the rest of the model number on your sewing machine for specifics with your machine.
Jan 04, 2017 | Kenmore Sewing Machines
User guide
from the cotton holder you run the thread across to the thread tensioner you pull the thread through this then you thread it through the hole in the little arm that goes up and down with the needle you then bring the thread down to the needle passing it through the holder at the top of the needle then you thread the cotton through the needle make shore the needle is in the right way this should work
Aug 31, 2013 | Sew Pro ZZ401 Sewing Machine
Correct threading of mitsubishi db130g sewing machine
AtlasLevy.com call or email them for instructions on how to do this. I thought there might be a video on Youtube didn't find one. However, he does say anyone can call or write for threading on any machine.
Good luck
Dec 08, 2012 | Sewing Machines
Where can i find the operating manual for mitsubishi ls2-130
First of all, thank you very much for choosing FIXYA today for your online technical support needs.
Here is a link to the Mitsubishi Sewing Machines Support website which has links to the instruction manuals for all their products:
http://www.mitsubishi-sewing-machines.com/products/lockstitch-machines/
I was unable to locate the exact model number you quoted, but the LS2-1130-BOB / MOB / HOB models were the closest listed.
To see the instruction manuals for these machines, just click on the link, which is the underlined and blue highlighted text just above.
When you get to the SUPPORT WEBSITE, just click on the exact model number which most closely matches your machine.
Then look on the right hand side of the next page and click on the INSTRUCTION MANUAL icon.
When it asks you if you want to open or save the document, select OPEN.
This will open a new web browser page automatically for you and allow you to view the information at the website indicated and the contents of the Owner's Manual.
Here is the direct link to the Instruction Manual for the LS2-1130-BOB model in case you have trouble with the above instructions and remember to select OPEN when prompted:
http://www.mitsubishi-sewing-machines.com/servlet/com.univ.collaboratif.utils.LectureFichiergw?ID_FICHIER=1300714861663
You may need ADOBE READER installed on your computer to read PDF documents, although many computers already have this type of utility pre-installed.
You can download this free at WWW.ADOBE.COM if necessary.
Click on the DOWNLOAD ADOBE READER button on right side of the ADOBE home page when you get there, then follow the onscreen instructions to install the software on your computer.
I truly hope that was helpful to you.
Good luck and take care.
Joe.
Nov 13, 2011 | Steam Fast Sewing Machines
Tension adjustments- bobbin metal or plastic-needle size- for sewing on jean cloth
Most machines can sew on jeans fabric, but you may need to go slowly or even hand-turn the needle when crossing thick seams to keep from bending or breaking your needle.
Bobbin: It won't matter if you use plastic or metal bobbins.
Needle: You should use a heavier needle - you can purchase 'jeans' needles, or use the heaviest sharp or universal needle you have.
Tension: For tension adjustment, you can follow the guidelines in your sewing machine manual but you'll also need to adjust the tension based on sewing on scraps of the fabric. If you are sewing light-weight denim, the settings are pretty much the default/normal settings. As you increase the weight/thickness of the fabric and seams to cross, you'll need to loosen your pressure foot tension. If you use decorative 'jeans' thread or topstitching thread, you'll need to loosen your needle tension.
*Always test on scrap fabric to make sure the stitches are forming properly. It is best to make small adjustments to your tension settings, then test, then adjust and test, until it is right. If you sew that weight of fabric often, make note of your tension settings inside your machine manual to save you some time the next time you sew.
I hope this helps.
Apr 01, 2011 | Brother XL-5130 Mechanical Sewing Machine
Need the tension settings for a Magnolis 7034D machine. Kids turned them all.
Hi
There are a partial manuals available for Janome Magnolia machines available on their site.
http://www.janome.com/documents/File/ManualFile/Inst%20Book%207034D%20(English).pdf
The tension settings are included on page 27 of the manual.
Hope this helps!
Sep 29, 2010 | Janome 7034D Sewing Machine
Where can i get the instruction manual for my mitsubishi dy 340 industrial sewing machine please
You will be able to get in contact with the Mitsubishi website from where all your details can be found.
Please contact or post a query to the site forum.
Log on to:
Sep 14, 2010 | Sewing Machines
I need a manual for a Mitsubishi industria sewing
Hi there, Have you tried www.2instructions.com ?
They have alot af manuals.
Apr 23, 2009 | Sewing Machines
Televison & Video Logo
94 people viewed this question
Top Televison & Video Experts
