Question about Haier Heating & Cooling
Control panel goes off after about 3 sec. when i plug in the unit no problem on the electrical outlet. thanks.
  • 31 Answers
Is there a self resetting circuit breaker on the main circuit board? Happens if the unit thermostat is turned up or off?
Posted on May 16, 2014
3 Suggested Answers
  • 94 Answers
SOURCE: When I plug the unit in, it powers up the
Buy a new one you have a bad circuit board.
Posted on May 02, 2011
mc1bean
  • 3053 Answers
SOURCE: aloha, I am renting my
Aloha, bro.
I was born and raised in Hilo, graduated Hilo High school, back in the stone age.
Hey, your problem to solve this issue, is real easy. Don,t even touch the air conditioner, as you don,t want to risk and mistakes or damage.
Here is what you do, make sure power is off to the outlet. Best way is go to breaker panel and turn off all power, to test to make sure outlet is dead with plugging in something you know that works, radio, or lamp or screw gun, you know.
Then take off plate of out let, properly is a standard screw driver or Phillips. The outlet it self normally will have two screw , one top and one bottom. Undo those, pull out out let, then most outlets will have set screw to hold in wire or a push in type with a little like tap. You will see when you open it, but pretty easy to figure out as its simple. take pull out the wires from the out let. Normally will be a black and white( if you have two outlets, will be green wire normally for ground, But should have two white wire and two black wire. Get yourself two **** connectors. Take the two white wires , put together (twist) so you can **** connector on it. So same with both black wires. Put everything back( make sure **** connectors are good and tight, and no exposed wires outside of **** connectors. Put plate back on. Now what this does, is only makes that outlet dead, but allows power to continue on same circuit that other outlets might be sharing. More than likely they wont get inventive and run a extension cord to it from another outlet, especially if you tell them out let is burnt out from air conditioning problem, and don't want fire to happen. Oh, when your all done with outlet, make sure you turn main power on. I hope this helps you, Mahalo bro. Mike
Posted on Jun 28, 2011
When I turn on my Sony TV, ti stays on about 30 seconds then shuts off, What do you think is wrong?
Do a Power Reset.
1. Turn off TV.
2. Unplug the power cord of the TV from the electrical outlet.
3. Let the TV remain without power for 60 seconds.
4. Plug the power cord back into the electrical outlet. (If the television is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the television.)
5. Turn on the TV.
If issue persists after doing the steps, reset the TV to factory default settings.
1. Turn on the TV.
2. Using the supplied remote, press and hold the UP arrow button.
3. While holding the UP arrow button press the POWER button on the TV itself.
4. When the TV goes off, release the POWER and UP arrow button.
5. The TV will turn on by itself and the initial setup screen will be displayed. Just follow the on-screen prompts to finish the setup.
Sony KDL 46V5100 random shut off 15 20 sec
Feb 25, 2016 | Sony Televison & Video
My dehumidifier seems to work fine than after about 5 mins. the fan slows down and there is an electrical draw of power for only about 2 secs.then the fan picks up speed till it gets to normal running...
Very interesting. Try plugging the unit into another outlet. One that's not on that same circuit. It may be, that there's another power draw on the circuit, the unit is currently plugged into.
Please let me know what happens. Thanks.
Apr 27, 2011 | Kenmore 54701 Dehumidifier
I am getting a EEAF fault code and the smoker will not heat. What is wrong?
To RESET control panel:
If control panel shows an error message, turn electric smoker off, unplug unit from outlet, wait
ten seconds, plug unit back into outlet, then turn electric smoker on. This will reset control panel.
ASSEMBLY, CARE & USE MANUAL
WARNING & SAFETY INFORMATION
MODELS 20070106, 20070206
Nov 25, 2010 | Masterbuilt 20070106 Electric Smoker
Kenmore frontload washer, model#11047087600-- F71 error code displayed--what does it mean? thanks Rene
The F70 and F71 error codes on this model of washer indicates a communication problem between the user interface control board and the central control unit (main control board). These error codes can sometimes be caused by a power surge or glitch through the electrical lines. Try unplugging the washer to completely disconnect electrical power. Wait 1 minute and then plug the washer back in to the see if the fault code clears. If it does, then the washer may work normally.
If the code reappears, then you could have a wire harness connection problem, a failed user interface control board or a failed central control unit. I recommend calling a service technician to properly diagnose and repair this type of problem so that the correct component can be replaced.
Be sure your unit is plugged into a 3 prong grounded outlet as well.
F71 is a "heatbeat failure" which means that your front interface control board is shorted and will need to be replaced. it's actually fairly easy to replace and can definitely be done by yourself. To access the part, just pull the unit forward and remove the 3 screws coming in from the back of the top panel. Remove the top panel by pulling it back, up, and off. Then remove all the screws going into the top of the control panel. Remove the dispenser drawer and remove the screws coming in through the dispenser. Remove the screws coming from the inside of the dryer going forward into the control panel, then remove the control panel (it's just clipped in on the bottom. After that you can disconnect the wire harnesses to the front interface control board and replace that part.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jul 06, 2010 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
I have a Kenmore Elite HE5 and it displayed the error code "F70". I unplugged the washer for 30 min and plugged it back in - and now it won't even turn on.
Jun 29, 2010 | Kenmore Elite HE4 Electric Dryer
My Dryer Kenmore Elite HE5 show the Code F70...
Dec 31, 2009 | Kenmore Elite HE4 Electric Dryer
What is the code F70? Kenmore Elite HE5 dryer
Nov 08, 2009 | Kenmore Elite HE4 Electric Dryer
Clothes not dry and get F70 code
Jan 03, 2009 | Kenmore Elite HE4 Electric Dryer
Kenmore HE5t washer
Sep 06, 2008 | Kenmore 67082 Electric Dryer
I don't understand..
button on front control panel has a lock emblem underneath it or on some models has a button marked" hold 3 sec to lock controls " hold button down untill control lock light goes out
Jul 22, 2008 | Whirlpool GEW9250 Electric Dryer
Heating & Cooling Logo
37 people viewed this question
Top Haier Heating & Cooling Experts
Tom Chichester
Matt
Matt
Level 1 Expert
Terry Hair
Are you a Haier Heating and Cooling Expert? Answer questions, earn points and help others
