I've taken apart my asus k55a to replace the keyboard and I'm left with a metal piece that I took off somewhere near the DVD inside but I can't find where to put it back!can anyone help?!
    Problem Solver:
  • 15 Answers
Describe this part? meaning shape, are there any wires coming off it, ect!!! if you can take a picture and add it that would be even better.
Posted on May 17, 2014
  • 20 Answers
SOURCE: no display after taken apart. HELP!
take it appart againg and check all connectins are secured it sounds like the screen plug is disconnected
chris
Posted on Oct 29, 2007
  • 239 Answers
SOURCE: Toshiba satellite P25-S607, DVD inside: Mashita UJ 811 doesn't work
http://www.csd.toshiba.com/cgi-bin/tais/su/su_sc_docTOC.jsp?moid=438069&rpn=PSP20U&ct=UG&soid=470129&BV_SessionID=@@@@1849588803.1200582589@@@@&BV_EngineID=ccccadeddfdjedicgfkceghdgngdgnn.0
Here is a phone number too (800) 457-7777. Try that and also maybe the spring you are talking about came from the locking switch on the bottom under the bay, Check that and see if it still springs back for you, Hope that help you out somewhat. Thanks Bear001
and(800) 457-7777.
Posted on Jan 17, 2008
IB4G2008
  • 3587 Answers
SOURCE: putting keys back on acer 3100 laptop
yes..this is particularly a delicate operation. do you have a magnifying glass and small pliers..
Posted on Apr 03, 2008
kim_cu
  • 70 Answers
SOURCE: gateway 450sx no power
Needs physical repair. No help without some new parts. The "little piece" latch is necessary. The bay thinks there is a device there and there isn't. The POST (Power On Self Test) program won't allow it to startup if a device is missing.
Posted on Jun 19, 2008
  • 43 Answers
SOURCE: sony vaio aw11m- took it apart now cant put back
You need a technician to reassemble it. There are no diagrams detailing every screw.
Good Luck!
Posted on Oct 31, 2009
How do I remove the screw plate that holds the cd driver, Asus K55A-HI5014L laptop?
Hi, go here: https://search.yahoo.com/yhs/search?p=how+to+replace+the+cd+drive+in+a+asus+K55A&ei=utf-8&hspart=att&hsimp=yhs-att_001&type=sbc_dsl
Nov 29, 2014 | ASUS K55A-HI5014L 15.6 Laptop i5 2.5GHz...
Tip
Replace DELL Laptop Keyboard Key
Sometimes with Dell laptops, the keys on the keyboard gets stuck or damaged or fells off the keyboard. There are many different ways to repair your broken keys. Just put your mind to it and you will be able to repair it yourself.
You can place an order to replace your broken key or you can repair it you have all the parts intact.
You should have a key cap, 2 or more retainer clips (plastic pieces), which goes under the key cap.
Following is the installation guide to replace and repair Dell laptop key.
To install your key on your laptop keyboard, start out by observing your metal plates on the keyboard.
Always be sure to look at the metal keys because they differ in every keyboard.The larger metal hooks can be at the top, bottom, right or left side. The position of the metal hooks determines the position of plastic pieces.
Here you can see that it has one large metal hook at the top and two metal hooks at the bottom.
Take the larger plastic piece and observe that it has two larger sticks at the bottom, two holes at the middle and two shorter sticks at the top. The bottom sticks are going to go into the bottom metal hooks. The smooth part faces away from the keyboard.
Take the smaller plastic piece and observe that it has a small bar at the bottom, two sticks at the top and two sticks at the middle. The sticks in the middle are going to go into the middle holes of the larger piece and the bar is going to click on to the top metal hook. The smooth part faces away from the keyboard.
Place the smaller piece on the larger piece and insert its sticks to the holes of larger piece.
Push it evenly to insert completely. Get a thin object or blade and stretch the plastic pieces upwards so that it clicks together.
Take your letter key, put it in the middle and push down evenly from all four sides.
You’ve just repaired your Dell laptop keyboard.
Source: LaptopKey
on Dec 16, 2009 | Computers & Internet
Asus k55a-rbr6 Cd Drive not recognized in Devices and Printers, will not run any CD.
The Asus K55A-RBR6 optical drive uses the Windows built-in driver. The drive may have failed or it could have a power or cable issue. To check for a power issue, try ejecting the optical drive by pushing the disc tray into the computer. If the drive tray ejects and retracts, it has power.
First, go to the Device Manager and check if there are any driver issues identified by Windows. (Click Start > Control Panel (in the right hand column. Click on either System and Security > System or Hardware and Devices and then select the Device Manager. Expand the section for DVD/CD-ROM drives and look for a yellow triangle with an exclamation point or a red triangle with an x. Try to uninstall the driver and then reboot the machine. Windows will try to restore the driver. (You should alsocheck Windows Update for any optional drivers. Start > Control Panel > System > Windows Update.)
Check that you have installed the latest available BIOS upgrade (407), from http://www.asus.com/Notebooks_Ultrabooks/K55A/#support .
The laptop uses a SATA slimline internal optical drive. The drive needs a power connector from the internal power supply and a SATA cable connected to the motherboard. You can access these if you disassemble the laptop. You may want to try just replacing the drive (~$25 at many vendors). If the second drive doesn't work, then try replacing the SATA cable and make sure it's well seated at the motherboard and the optical drive. There aren't extra power cables in most laptops but you should check for damage. Alternatively, get an external USB optical drive to replace the internal drive.
I hope this helps.
Nov 15, 2013 | ASUS Computers & Internet
Unlock
on my laptop there is a button that locks the keyboard,see if it is the same with you
Jun 30, 2013 | ASUS Notebook K55A-DB51 15.6inch Core...
Where is the motherboard on a RS267LA fridge.....I am unable to find it
85ecd490-aad2-4579-82ce-02ebc502ee07.jpgThe DA41-00104W Main Control Board should be near the compressor and covered and mounted upright like a book. Click here to see a photo of the location=> HERE location #26 I am here if you have questions, Thanks Sea Breeze
May 14, 2013 | Refrigerators
I had my mini Maglite taken apart and a small (tiny) metal part fell out....I found it but now I don't know how it goes back on ....it was somewhere near the light bulb area. John
There are 2 tiny clips that hold the bulb in and make contact with the rim of the barrell. They can be difficult to get back in without prying the plastic piece out of the end. Once you pry it out, it never works the same.
Oct 05, 2009 | MagLite Camping, Backpacking & Hiking
My dishwasher won't drain
was it loose? I don't think it goes in there.
Nov 02, 2008 | Danby 22 in. DDW396 Free-standing...
Putting main deck line cover back on inside vcr
this sounds like the carriage tray, it's the metal plate that the vcr slides in and out. It should have a door on the front side and it may have at least 2 screws and sometimes four. The only problem is aligning up the tray to be exact. in the power on mode the vcr tray should be pushed outward like the tape is sticking partly out of set.
Sep 01, 2007 | Televison & Video
Computers & Internet Logo
57 people viewed this question
David Payne
David Payne
